Firebirds for Sale Post your Firebird for Sale.
[WI] 89 Formula Firebird
Old Nov 12, 2010 | 02:07 PM
djshow78's Avatar
Want a title? Post!
89 Formula Firebird
Size:  70.3 KBLess than 1,000 miles on a freshly rebuilt engine and trans. Engine is a .40 over 350 4 bolt main, has forged flat top pistons,64cc patriot performance aluminum heads w/ 2.05 intake valves and 1.7 exhaust valves and 195cc ports. overall CR is 10.5:1. Engine is TPI with custom PROM chip from TPIS out of minnesota, has TPIS bigmouth intake manifold, SLP runners, BBK twin 58mm throttle body, Accel 36 lb/hr injectors, Edelbrock 1 5/8" headers, March underdrive pulleys, A/C has been eliminated. Engine also has double roller timing chain, aluminum 1.5:1 roller rockers, stud girdles, roller cam with about 5.75 lift and 112degree lobe seperation for computer controlled engines. brand new summit distributor, crane fireball ignition box, and coil. Has 150HP N.O.S. wet kit fully installed with bottle mounted in the hatch. Engine puts out about 450 HP without the bottle. Trans is a built 700R4 with a 3,000 stall and a aluminum driveshaft. Rear end is a Richmond ring and pinion 3.73 with a Eaton Posi unit. Has drag radials on it now. Needs subframe connectors and a few small body repairs. never driven in the winter or rain. Need to sell, just returned from a deployment to Iraq. Car ran a 12.4 the 1st time at the strip after break in, spun almost all the way through 1st gear and shift points were off, havent ran it again or tuned it. Don't have time to play with it anymore. Looking to get 5,000 OBO. If any questions please ask. Thanks
Dylan
Old Nov 13, 2010 | 09:28 PM
djshow78's Avatar
Want a title? Post!
Re: 89 Formula Firebird
Would like to apologize for the car and engine being so dusty in the pics, it had been sitting awhile while I was in the middle east. It cleans up nice.
Old Nov 15, 2010 | 12:48 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Where are you located in Wis?
Old Nov 15, 2010 | 09:26 PM
djshow78's Avatar
Want a title? Post!
The car is located at my buddys shop right off I94 in Racine. Southeast Wisconsin pretty much....
Old Nov 23, 2010 | 08:55 PM
djshow78's Avatar
Want a title? Post!
I'm sure most on this forum know that this car has the WS6 performance suspension package on it, it also has an A/C delete pulley installed, Flowmaster 40 series muffler with all emissions removed. Needs a little bit of interior work like the head liner, the dash has no cracks. Car is solid and is pure muscle, I have done all the technical and go fast work. Just needs a little polishing and fine tuning, don't pass this opportunity up, make me an offer. Have over 3,000 in the engine rebuild alone! This is a steal.
Old Nov 24, 2010 | 01:12 AM
djshow78's Avatar
Want a title? Post!
bump
Old Dec 1, 2010 | 06:36 AM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
what branch are you with and what unit did you deploy with?
i might have missed it but is it a t-top car? and can i get some more pics of it.
Old Dec 1, 2010 | 01:22 PM
djshow78's Avatar
Want a title? Post!
I am in the Army, Deployed with D 2-128 IN the first time in 05. 2nd Deployment was with B 257th in 09.
The car does not have T-tops. I will get more pics for you within a couple days, car is in storage currently.
Old Dec 1, 2010 | 04:05 PM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
If it where spring i would defiantly consider getting this from you. If you still have it when it warms up please let me know.
Old Dec 1, 2010 | 04:41 PM
djshow78's Avatar
Want a title? Post!
It's looking like I may still have her in the spring. I will definitely let you know, thanks for the interest.
Old Dec 1, 2010 | 04:47 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Thanks for serving our country!
Old Dec 1, 2010 | 05:37 PM
djshow78's Avatar
Want a title? Post!
No problem, thanks for the support!
Old Dec 29, 2010 | 08:31 AM
JP007's Avatar
Car: 89 Formula
Clean title and in hand? Sent PM. Need location and contact information. I would really like to see this it this week.
JP
Old Dec 29, 2010 | 09:16 AM
djshow78's Avatar
Want a title? Post!
Yes clean title in hand, I replied to your pm. Thanks
Old Apr 16, 2012 | 12:36 PM
djshow78's Avatar
Want a title? Post!
Up for sale again....
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Linson
Aug 31, 2015 04:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
