Group Purchases Take part in, suggest, or discuss Group Purchases here. Make sure to read the rules before doing so.
9 bolt posi cones!!
Old Feb 15, 2007 | 11:17 PM
player 88's Avatar
Engine: 360 .060 over TPI
NEW OEM 9 bolt posi cones !!
I have found a source for 9 bolt posi cones in Australia, I am trying to get a realistic number of people who would want a pair, so I can work deal on a bulk buy. I can get a quantity discount, so please let me know many you want. These are NEW OEM cones.
Currently at 1 or 2 at a time the price will be approx $70-80 per cone (2 per rear end= Approx. $150). Plus shipping. Shipping in bulk would be very resonable vs. 2 at a time.
ALSO, I can get the GTO HP diff spring tuning spring kit. This replaces the stock springs with the current HP springs from the GTO, we can also get bulk pricing on these too. the go for around $75 per kit for 1 at a time.
My idea would be that I would buy them up front and then bring them over in one shipment and then send them and each person could then pay me back one at a time. Let me know if this sounds OK
Again we can get better pricing if we buy in bulk for both items
thanks
Steve
Old Feb 15, 2007 | 11:53 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Im down but I need them pretty soon.
Old Feb 15, 2007 | 11:54 PM
old Phart's Avatar
Car: 1989 IROC
Engine: L98 350
Axle/Gears: 3.45 posi 1LE
I would like 1 set (2) of posi cones and the GTO HP diff spring kit on a GP. Thanks.
Old Feb 15, 2007 | 11:57 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'm interested in the posi cones & springs.
Old Feb 16, 2007 | 12:04 AM
player 88's Avatar
We are up to the following in 10 minutes of posting!!
4 cone pairs
1 spring kit
I will be ordering 3 set of cones at least and spring kits.
Old Feb 16, 2007 | 04:32 AM
AllenGTA's Avatar
Car: 1987 Camaro Z28
Engine: 5.0 TPI
I want a set of cones too. But I'm in the UK. Player 88 is there any way we can sort it so you can send me a set to the UK? or can you pass on the details of the supplier in Australia if not.
Cheers.
Old Feb 16, 2007 | 07:20 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'm in need of a set of cones asap. I'd may be interested in a set of springs aswell.
question: even when installing a new set of cones, isn't a shim kit required? I'll need a shimming kit aswell.
Old Feb 16, 2007 | 08:28 AM
player 88's Avatar
Cheers.
No problem, I can ship a set there too.
Steve
Wow keep them coming and let other know! I would like to place the order by the endof the month!! (February)
thanks
STeve
current status:
We are up to the following in approx 12 hours of posting!!
6 cone pairs
2 spring kit
I will be ordering minimum 3 set of cones and spring kits.
Old Feb 16, 2007 | 08:37 AM
player 88's Avatar
Good question:
When new, the diffs came with no shims, only the springs provided preload. The shims are to make up for the maching of the old cones and wear of the case. With these NEW OEM cones, less shiming, if any, is required, it depends on much wear your case has. The HD spring kit should also help with that.
FYI - personnelly I have a set of shims that I got with my rebuild kit and they are actually the pinion shims for use on the pinion gear, between the inner bearing and gear. NOTE: The orginal pinion was shimmed between the inner pinion bearing race and the housing, not between the pinion bearing and gear. However, I will try and get some info for them also.
thanks
Steve
Old Feb 16, 2007 | 01:15 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
do you have any actual prices of what the cones and the spring kit would cost if bought in bulk?
Old Feb 16, 2007 | 01:44 PM
player 88's Avatar
Not as of yet, But I am hoping we cna get the price down enough to cover he shipping. Currently if ordered 1 pair and a spring kit the price would be around $200-220 US + plus shipping.
If we could get it down to around that incuding shipping it would be good. I would like to see approx. $40 off per full set.
The more sets we buy the better the price will be.
As I started in an earlier posting, I was planning ordering all at once, I'll pay for the entire lot up front and ship it over in one package, and pay duty, taxes etc. Then once in country I would then devide them up and mail them out each person. I would let everone know when they are in give them a final priceand then they can either pay me back via Paypal or Money order etc.
The shipping, taxes, broakerage fee, and duty would add back about $20-40 per set up total. So it is worth while doing this way, otherwise the shipping on a small package that far would be $$$
Let me know if that sounds OK.
thanks
Steve
Old Feb 16, 2007 | 02:44 PM
ceub's Avatar
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
I might be interested in a set of cones.
cj
Old Feb 16, 2007 | 09:45 PM
CashMunson's Avatar
Engine: 408 LS
i'd be interested if i could get an actual GP price on both.
Old Feb 17, 2007 | 07:57 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Are the cones the same for both 2 and 3 series diffs?
Old Feb 17, 2007 | 10:09 AM
AllenGTA's Avatar
Engine: 5.0 TPI
Steve
In that case, put me down for a pair of cones and the springs too. If I'm going to do it, might as well do the whole thing properly.
Now where was that topic for the Diff covers group buy
Cheers Steve.
Old Feb 18, 2007 | 02:05 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Whats the advantage with the spring kit? If it's only $75 more, mine as well spring for those too...
Old Feb 18, 2007 | 04:12 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
What kind of time frame are we talking? I'm in for a set of cones and springs, but I'll be rebuilding my rearend within the next 60 days. Can't wait any longer than that.
btw. Thanks for your efforts on this.
Old Feb 18, 2007 | 06:04 PM
law's Avatar
law
I`ll take two sets!!!!!!
Old Feb 18, 2007 | 08:39 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I'll take 2 cones and 1 springset also! I'll be tearing down in about a month. Thanks!
Old Feb 18, 2007 | 08:47 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would like a set but I cant afford them ATM. When this is all going to happen I would possibly be interested if I can pay for them then. I would be down for cones and springs.
Old Feb 18, 2007 | 10:41 PM
player 88's Avatar
I would like to get the ordered placed the first of March. I expect delivery to me approx. 2-3 weeks later. I would then ship them out, I would ask for payment once I recieve them. Once I get a final number of cones and springs, I can get final pricing and shipping costs. The pricing will be based on the numers of units ordered, volume is the key to lower price, so pass the word! I still expect the price for cones and springs to be around $200 delivered. So if that is too much $$ please don't say you want a set and not pay for them when I ask for payment.
I will be ordering some extra sets for myself and to cover others who miss out.
I will request pricing and shipping based on numbers as of 1 March 07.
thanks
Steve
Old Feb 18, 2007 | 11:57 PM
law's Avatar
law
Old Feb 19, 2007 | 01:22 AM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
I'll take a set of cones and springs here.
Old Feb 19, 2007 | 08:42 AM
player 88's Avatar
good question YES they are the same. internals are indentical.
Also I won;t get actual pricing and delivery until I get a final count on quantity.
Steve
Old Feb 19, 2007 | 09:03 AM
player 88's Avatar
Updated count total for cones and springs
16 pairs of cones
11 spring kits
Just as an FYI- the spring kits are stiffer then the stock srpings and will add a littel extra preload the cones. this will help make up for some fo the wear in the carrier it's self.
You still may need to add some shims to the carrier to take up any slack and compensate for wear. The shims are the same as the pinion bearing shims fo rhte 9". I just order some extras from RATECH for $13.00. I also order solid pinions spacers and shims for $18, these eliminate the crush sleeve.
"B" or "P" Model GM Axle p/n 1104 $13.00
(64-71): Pinion Shims -
GM Axle
7.750" (9 bolt) GM Axle: P/N 4115 $18.00
Solid Pinion Bearing
Spacer with Shim Pack 9
bolt
www.ratechmfg.com
Ano affliation- no endoresments etc, etc. I just used them because It was very easy and convienent.
Steve
Old Feb 20, 2007 | 11:03 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I may be interested in cones. Does anybody care to fill me in on what it takes to replace them? I'm comfortable around a motor, but I really haven't ever spent any time inside of a differential.
Old Feb 20, 2007 | 11:30 AM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
i have looked at my posi unit and the cones still look liek they have plenty of life leftion them (they have a spirial in the that is pretty deep) would the spring kit make the rear "tighter"?
Old Feb 20, 2007 | 11:41 AM
player 88's Avatar
Make sure they are not Bottomed out. if they are they you either new ones or you need to machine them. If the carrier is too far worn, then you need machine the ned of the new ones so they don;t bottom. Each side of the carrier has little "windows" in them . If you insert the cone in the carrier you see if the cone bottoms out.
athey also can bottome out on the inside of the carrier. the cones woudl need maching then. The windows are near the carrier bearing on each end. They allow lube into the housing.
Note: new cones will make up for smoe of the wear of the carrier but not all.
New 9 bolt carriers are $485 US Plus shipping.
Yes, the springs tighten up the pre load.
Attached Thumbnails 9 bolt posi cones!!-9-bolt-carrier-windows   9 bolt posi cones!!-9-bolt-carrier-windows   9 bolt posi cones!!-9-bolt-window-1.jpg
Old Feb 20, 2007 | 12:31 PM
player 88's Avatar
They are inside the carrier in the diff. Pull the axles out, 4 bolts each end. remove the rear cover. Remove the 4 bolts and carrier bearing caps, the carrier will then come out. NOTE: there are shims on each end, do not mix them up!.
Then use the process in the tech bulletin section on re-shimming. You separate the halves, they are spring loaded, and remove the insides, replace the cones and re-assemble as per the rehimming procedure and then reinstall. No re-setting up the ring and pinion, you didn't disturb it. It you can rebulid an engine or swap heads, you can do this!
C:\Documents and Settings\Steve\My Documents\personal\autos\camaro stuff\9 bolt\9 bot shiming ThirdGen_Org.htm
Steve
Old Feb 20, 2007 | 12:53 PM
wannafbody's Avatar
Car: 88 GTA
I did just want the cones but you can put me down for a set of springs also
do you know when you might be able to recive these?
Old Feb 20, 2007 | 01:11 PM
player 88's Avatar
See the above emails from me, hopefully around the end of March.
Steve
Old Feb 20, 2007 | 06:58 PM
wannafbody's Avatar
Car: 88 GTA
oh ok, I might can wait that long, deffintly not passed mid april because thats when im gonan start running my car at the track a little lol.
thanks for helping us out!
Old Feb 21, 2007 | 04:19 AM
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
Cancel me, I've found a complete rear from an 88 iroc.
never the less....good job!!
Simon
Old Feb 21, 2007 | 12:36 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I'm in for a set of cones and a spring kit.
Old Feb 22, 2007 | 01:58 PM
Mongoose's Avatar
Car: 90 Formula
Put me down for a set of cones and a spring kit. I'd like to know about getting the shims as well.
Old Feb 23, 2007 | 08:08 AM
player 88's Avatar
We are up to 20 sets of cones and 15 spring kits!!!!!!! As of 23 feb. I will be posting a list of everyone that I have received ann email and or posting from on interest in this group buy on the 27th of February for review. At that time please review and either confirm or reject your willingness to participate in this group buy. I will then place the order on either the 1st or 2nd of March.
thanks for everones interest!!
Steve
Also....................
Shim kits- a few of you have asked about shim kits. I would recomend that you go to a site like ratech www.ratechmfg.com . the shim pack is $13.00 , they the same as pinion shims. See below
Shim kit-
GM Axle
Also if you are either rebuilding your diff or swapping out gears here is great upgrade also, this replaces the crush sleeve with spacers. works much better.
bolt
www.ratechmfg.com
Old Feb 28, 2007 | 02:23 AM
wannafbody's Avatar
Car: 88 GTA
well i confirm, I want springs, and cones
Old Feb 28, 2007 | 08:03 AM
player 88's Avatar
Confirmation list
Sorry for the delay, I had a close death in the family and it has been a bit hectic.
Please verfiy your name and prodcut you want and we will proceed from there.
If I missed someone please let me know that too!!
Steve
tel: 716-210-8543
Old phart- cones and springs
irocthe5.7L- cones and springs
allenGTA- cones and springs- CONFIRMED
Brisk- cones and springs
ceub- cones
sean of 30306- cones and springs
law- 2 pair cones and 1 spring set
eagle223USA- cones and springs
wheel spin- cones and springs
jim88iroc- cones
niceroc- springs
wannafbody- cones and springs- CONFIRMED
cashmunson- cones and springs
90iroc1- cones and springs
kbog54- cones and springs possilby
player 88 (me)- 3 cone sets and 3 spring sets (minimum)
total: 20 cone pairs and 15 spring sets.
Please confirm and I will get moving on this.
thanks
Steve
Old Feb 28, 2007 | 01:02 PM
Mongoose's Avatar
Car: 90 Formula
Do you have an estimate of how much each person's order will cost?
Old Feb 28, 2007 | 02:42 PM
player 88's Avatar
Now that I have real numbers, I have sent off a request to get firm pricing. I would still think it will be about $200/person for cones and springs + shipping + duties.
Once in country, then it will be approx
$10/person to mail them out. They are faily heavy. but can fit in a cushioned envelope.
So maybe 260-270 total person, and I think that maybe on the high side, but I really won't know until I get a reply back hopfully by tomorrow.
thanks
Steve
Old Feb 28, 2007 | 04:10 PM
AllenGTA's Avatar
Engine: 5.0 TPI
You've got me down for cones. I'll definately take a set.
Add me a set of springs on too.
I'm actually on holiday in NJ at the moment, so might take me a while to respond to anything.
Cheers.
Old Feb 28, 2007 | 04:13 PM
  #42
player 88's Avatar
Cheers.
DONE!!
thanks
Steve
Old Feb 28, 2007 | 04:54 PM
  #43
Car: 1988 IROC-Z
Engine: 427 SBC
A little confused. How come some people have 1 spring set next to their name, and others just have springs? What exactly is the name of this company that you are buying these parts from?
With that many on order, I hope we can get a good deal.
Anyway, I'm still in.
Old Feb 28, 2007 | 05:07 PM
  #44
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
Im definately very interested if you can come up with a final price for cones and springs.
Im guessing that he is getting them from holden or the company that bought out borg warner can't remember the name now as they still make parts for these in australia. I tried getting some from them once and they had gearsets and axles also but i gave up after they proved very unco-operative
Old Mar 1, 2007 | 11:02 PM
  #45
player 88's Avatar
OK
Originally Posted by IROCThe5.7L
A little confused. How come some people have 1 spring set next to their name, and others just have springs? NO difference, just me typing ;-)
Diff Techincs , Sydney Austrailia.
ME TOO!!!
Dana is the new owner of the Borg Warner Austraila operation
Old Mar 1, 2007 | 11:46 PM
  #46
Mongoose's Avatar
Car: 90 Formula
Take me off the list, I'm making plans for a different rear altogether now. Thanks for the effort and good luck.
Old Mar 4, 2007 | 10:53 PM
  #47
player 88's Avatar
UPDATE-
I have sent the final price request off based on volume and I awaiting a response. I should have shipping, etc. all rolled into it.
I will post the $$$ as soon as I get the reply.
thanks
Steve
Old Mar 4, 2007 | 10:55 PM
  #48
wannafbody's Avatar
Car: 88 GTA
once you get the reply and post the price does this mean we can buy them? I am ready lol
Old Mar 4, 2007 | 11:32 PM
  #49
player 88's Avatar
YES!! LOL!!!!
Old Mar 11, 2007 | 01:32 AM
  #50
Brisk's Avatar
any word back on these?
