Ok, this is getting silly...
Old Nov 15, 2002 | 10:13 PM
PonchoTA's Avatar
Is there anyway (short of actually tearing into the engine, apt. mgr doesn't like that!) to verify one way or another what engine my T/A has?
I'm getting all kinds of conflicting information,
My VIN has the "H" code, for non-HO (right?) but:
As far as I know only L69 / 5-spd cars came with 3.73 open rear,
Operating cowl-induction via hood scoop
Stock twin-muffler set up in the rear (instead of single crossflow)
and, this car pulls a hell of a lot harder than a 150 hp 305 should, I don't have any times or dyno numbers on it (yet!) but I think there's a mystery that needs to be solved.
I'm probably the 30th owner on this poor thing, so there's no telling WHAT has been done to it, I'm not even discounting an engine replacement somewhere along the line.
Please let me know if you have any ideas on figuring this out!
Old Nov 15, 2002 | 10:53 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
possible mods
If in fact it has many after-market mods or replacement GM parts, a picture or pics from different areas on the car would be helpful.
If you can, put some pics up
BILL
Old Nov 15, 2002 | 11:28 PM
PonchoTA's Avatar
All the mods in the sig are the ones I've done. There isn't any evidence of anything 'unusual' about the car, other than the different rims that were on her.
I'll see if I can add a pic or 2.
Thanks again!
Old Nov 15, 2002 | 11:31 PM
PonchoTA's Avatar
and one of the (blech) outside
Old Nov 15, 2002 | 11:34 PM
90TA's Avatar
The '83 LG4 "H" 5-speed had a 3.73 rear as an option. You really can't go by the HP numbers as both automatics and manuals are listed as 150HP and you have the cowl induction as well. Look on your block for the numbers. Your engine could also have been rebuilt better or swapped(the numbers will tell you if swapped).
Old Nov 15, 2002 | 11:50 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Hi Paul
Take a peek at the front of the block, below the right cyl head.
A putty knife and some degreaser along with some good lighting will help
Eng codes break down like this:
123456 D5F 2DN100001
123456 - Motor Unit Number
D5F - Engine Type Code (305 CID V8)
2DN100001 - Engine VIN Code
Breaking Engine Vin Code on down:
2 - Pontiac Division
D - Model Year (A=1980; B=1981; etc.)
N - Assy. Plant (Norwood)
100001 - Last 6 digits of Vin
Engine Codes, 1983 8 cyl 305 4bbl:
D5B
D5C
D5F
D5H
DDB
DDC
DDD
DDF
DDH
DDJ
DDK
DDN
DGN
1983 Axle Codes, 2 digit, front pass side on axel tube:
KF - 2.93
JF - 2.93
KG - 3.08
JG - 3.08
KH - 3.23
JH - 3.23
JZ - 3.23
JJ - 3.42
JK - 3.73
Lockers:
PW - 2.73
JX - 2.93
PX - 2.93
JY - 3.08
PY - 3.08
PZ - 3.23
JR 3.42
JQ - 3.73
PQ - 3.73
I hope this helps and good luck mate !
Don
Old Nov 16, 2002 | 01:16 AM
Bill Speed's Avatar
Engine: L98 350 TPI
A bit off the topic
You should have all your part VIN locations as was described in my theft recovery thread, that may help.
I'm wondering what digital cam and hardware/software you used to put such great photos up? (compressed I gather?)
I'm using a very cheap USB system now, but want to upgrade.
I'm not very PC tech savvy, I might add.
BILL
Old Nov 16, 2002 | 08:34 AM
4L60bliss's Avatar
If its a VIN "H", then its the good ol' LG4 engine.
87irocz28350
Feb 15, 2012 03:14 PM
pa_richardson
Jun 2, 2008 04:34 PM
