Is my car a WS6?
Old Dec 8, 2002 | 05:19 PM
FRDH8R's Avatar
Is my car a WS6?
84 T/a, no sticker under the center console, but got the cowl tag. No WS6 RPO code. The car has the Performance Suspension tag on the passenger side lower plastic, and it has discs in the back.
Can anyone tell me for sure?
These are the RPO codes I pulled off the cowl:
AQ9
CC1
19U
19L
O4B
Thanks!
Old Dec 8, 2002 | 07:23 PM
jase's Avatar
It probaly is since you have that tag.Mine has that plus the rpo code.
Old Dec 8, 2002 | 08:22 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
hmm
seeing as you don't have an rpo sheet in the console, it looks like you'll have to crawl under the car, and measure the size of the swaybars, front and rear.
Drew would be able to confirm this for sure, but i think WS6 gives you a 34mm front swaybar, and a 21 or 23mm rear bar.
AQ9 decodes as front bucket seats... (should be high backs)
CC1 decodes as t-tops
19U decodes as the primary exterior color being black
19L decodes as the secondary exterior color being black
and O4B was not found in the decoder's database.
below is a link to the thirdgen.org RPO decoder.
https://www.thirdgen.org/cgi-bin/rpo/index
Old Dec 8, 2002 | 10:38 PM
90TA's Avatar
04B = 2nd Build week of April.
It might help if you mentioned what engine and trans you have.
Old Dec 9, 2002 | 12:06 AM
FRDH8R's Avatar
The motor is a 305 HO with a 5 speed. I'll get under and check the sways tomorrow.
Old Dec 9, 2002 | 12:34 AM
Guest
Guest
Posts: n/a
The sway bars should be 32/23 f/r.
It probably is WS6, having the HO engine and the rear discs.
Old Dec 9, 2002 | 11:44 AM
MdFormula350's Avatar
nice car by the way!
Old Dec 21, 2002 | 06:26 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Old Dec 21, 2002 | 09:17 PM
90TA's Avatar
Originally posted by 82FirebirdTA
Doesn't AQ9 mean Recaro?
Only for 1982 did AQ9 have the single distinction for Recaro seats.
'83 on, it was for the Lear Siegler and the Recaro seats.
Old Dec 21, 2002 | 10:00 PM
Agent13's Avatar
Engine: LG4
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
