help me figure out my Bose option
Old Mar 5, 2003 | 03:43 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
my cousin (previous owner) told me that when he had professionals install his Subwoofer, that they had to wait awhile to get the bose system figured out, I checked my rpo numbers and nothing came up bose, yet it has the bose speakers stock. I don't have anyones in the kick panel, and after doing a little research it seems like there should be????
my car was ordered from the factory, that would explain most of the "different" options (red leather, red paint, red 16s, t-tops, power everything (except antenna and seat))
please enlighten me
Vic
Old Mar 6, 2003 | 01:46 PM
Drew's Avatar
What is it you're asking? Are you asking if your car should have the bose sound system?
If it had bose, it would have the locking rear storage cover with the speakers mounted in it, it would have different kick panels with speakers, and it would have a bose/delco deck. I would imagine there would also be an rpo code on the SPID to denote the differences to a service tech.
It sounds like your car probably didn't come with the bose system stock. I would also question the accuracy of the red 16" wheels. To the best of my knowledge the red 16's were only used on the Z28's.
Old Mar 6, 2003 | 06:48 PM
Tonyrodz's Avatar
Transmission: auto
I know you guys are familiar w/what the Bose looks like--but here's a pic for the newbies out there.
Attached Thumbnails help me figure out my Bose option-bose-setup-3rd-gen
Old Mar 6, 2003 | 06:55 PM
Tonyrodz's Avatar
Transmission: auto
Here's a pic behind a kick panel.
Attached Thumbnails help me figure out my Bose option-copy-3-front-passenger
Old Mar 7, 2003 | 09:18 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks for the help, but it has Bose speakers in the 'regular places' (to the sides of the back seat for example) this is stock along with the red 16s, and yes it does have the rpo code for the red 16s, but not the bose speakers (not set up like those in the pics)
Old Mar 7, 2003 | 10:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it has "Bose" speakers in the sail panels beside the back seats, but not the ones in the cargo cover and all that, then somebody probably bought "Bose" brand replacement speakers at the stereo store.
And of course, if it doesn't have the RPO code for the Bose option, then it doesn't have the Bose option. Since there's no way to order anything on a car except by way of a RPO (Regular Production Option) code, then it's certain that you don't have the Bose option, only maybe some Bose speakers in your car.
Nothing in your description of your car seems particularly unusual, except for the combo of non-power seat and leather. That's weird.
Old Mar 7, 2003 | 10:01 AM
GreenRS's Avatar
Car: 1992 RS Heritage Edt.
Engine: 305(LO3)
What is the actual rpo code on the car? Could you post a pic of the set up? This is what the new set up looks like.
Old Dec 16, 2003 | 09:50 PM
jdrafke's Avatar
guys i have the bose system in my car as well. however , i bought it and i think the old owner hacked it up. it has 6x9s in the side panals and 4x6s in the front which are working off a pioneer deck. im guessing he rewired it. im wondering, is their anyway to make use of the kickpanal speakers? rewire them maybe iwht aftermarket ones?" basically im asking can i put aftermakret speakers in the kickpanal and re-wire them to work. not to worried aobut the back 4" ones
Old Dec 17, 2003 | 08:52 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
From my understanding, it is not worh taking BOSE speakers and trying to convert them over to conventional. All of the speakers I have tested have an Ohm reading of 2 or less, 4 Ohms is standard automobile aftermarket, GM uses 10, 8 and 4 Ohm speakers depending on thier application.
If you hook a 2 or 1 Ohm speaker up to a 4 Ohm amp, you run the risk of blowing the Amp, not to mention the speaker will have a tendancy to distort sooner because of the overload.
I am not saying its impossible, but if you have a Pioneer deck then you do not have Bose anymore, or at least what makes a Bose system BOSE.
What makes a BOSE system works is kind of interesting, there is more to it than the speakers and Amp.
Standard system works with the following: reciever/amplifier/speakers
Bose system has:
reciever/low voltage amp to Amps on speakers
Amps on EACH speaker piggiebacked usually
There are 1 or 2 extra relays that power the speakers.
John
Old Dec 17, 2003 | 10:14 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
You're right. My RS has leather seats but they aren't power either. :shrug:
Kat
Old Dec 17, 2003 | 07:11 PM
Tonyrodz's Avatar
Transmission: auto
So it's not worth it to try to put reg tweets or speakers into my Bose kicks?
Old Dec 17, 2003 | 11:11 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
I'd love to get my hands on one of those bose systems :lala:
Old Dec 18, 2003 | 08:28 AM
okfoz's Avatar
If you do, get the speaker wires too, they are usually a shielded pair of wires. Because the reciever puts out low voltage the shielding keeps the noise out from other things, like your altinator, and clicks from your distributor, and other noises.
John
Old Dec 24, 2003 | 11:04 PM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
bose
ive go the factory bose system in my rs, i left mine alone because it works but if someone wants a car to put a stereo system in, dont buy a bose car because be prepared for some headachs with rewiring the whole system....2nd dont ruin a factory rare piece!
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
angel2794
Sep 8, 2015 06:22 PM
Fronzizzle
Sep 8, 2015 12:10 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
