Engine number
Old Jun 22, 2003 | 12:55 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Engine number
Today since ive learned that there is a number on the right cylinder head. So i went out to have a look and i found this number: V0826CHB i think i got it right but i was so hard to see. Now what can you read from this number???
Old Jun 23, 2003 | 02:24 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Can you tell anything from this number??
Old Jun 23, 2003 | 05:05 PM
WildmanDRL's Avatar
Car: 1989 Firebird Formula
Engine: 350 TBI (LO5 K)
Axle/Gears: 7.5 10 bolt peg leg
It doesn't look like the right number.
Try this site. It tells you where to look and lists all the numbers to decode it.
http://www.mortec.com/location.htm
Old Jun 23, 2003 | 05:11 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Hmm i was told that you could get some info from the number on the cylinder head on the right side of the engine
Old Jun 23, 2003 | 07:32 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Scania, check on the block on front of the engine on the right hand side where the head and block meet. There will be a little lip there with hopefully the same VIN as the one on your dash as long as motor is original. Hope this helps
Old Jun 27, 2003 | 11:22 PM
cs2000's Avatar
The engine code is correct for your car. V= Engine assembly plant, Flint, Mi. 0826= 08= August, 26= 26th day, CHB = 5.0 TPI with auto trans. Chris
Old Jun 28, 2003 | 04:07 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Thank you very much!!
:hail: :hail:
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
MY87LT
Aug 17, 2015 08:43 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
