How to ID L98 versus LB9?
I am a new user, and I know this question has been asked 100 times already, but I cannot find it posted.
Would someone point me where to look?
I am going to look at a supposedly L98 1992 Z28 this weekend (8th VIN digit is an 8). I have seen photographs of the engine, and it is obviously a TPI engine. However, just because it left GM as a 5.7 does not mean it is still a 5.7 11 years later.
I would really like to find a way to identify whether it is a 5.0 or a 5.7 engine. It is an automatic, so no indication there.
Also, the engine is still in the car so visibility is limited.
I know this must be posted somewhere on this site, but I have looked for an hour and have not found it yet.
Bill S.
Bill S.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm not number one on this subject....but...I think the actual engine looks the same from appearence. (sorry if I'm wrong everyone) Me....I can tell the difference from a 5.0 and a 5.7 like night and day if it has an aftermarket exhaust system. If anyone has any info.....as far as the appearence goes....please post...cause I'd like to know too...
They look the same externally. The easiest way is to try and find the casting plate on the driver's side against the firewall. With these late model blocks they actually cast in the 5.0L or 5.7L If it isnt there you can always run the block casting number on www.mortec.com
iroc22,
Thanks for the information.
Just to clarify, I assume the plate is on the block itself and not the heads or intake. Also assume it is above the transmission.
Should I be able to see it from above, or is it attached to the back of the engine so that I need a mirror?
Just saw on this site that all L98, 1LE, and B4C cars have an oil cooler. Since 1LE and B4C are pretty rare, I was wondering about using this as a suggestion (but not proof) that the enginer is correct. What do you think?
Sorry for the additional questions, I am just getting excited about possibly getting another "fun" car.
Bill S.
Bill S.
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I judge them from the air intake (which I thought differed) and the speedo which is sometimes 140 MPH for the full 350 small block.
Mine also had dual enhaust but can't say for sure that's 5.7 only but was one thing that impressed me when buying my ride.
Mine's an 89 so I'm not as up to speed on the later cars.
Another Bill S. ...just great!
Bill S.
Bill S.
Re: How to ID L98 versus LB9?
Bill S.
Bill S.
Engine: L98 350 TPI
Originally posted by iroc22
The intake's were the same on the 305 and 350. You could get the 140mph speedo with either engine; it was part of the G92 package. The dual cat package could be had on both engines once again as it was part of the G92 package (RPO N10).
Bill
I was thinking the route of the lead in hose to the plenum to be specific. As the package you refer to, wasn't the default to have the 140 on the biggest engine unless it was an order for the smaller one? I'm just trying to get a fix on this and not mislead anyone. Thanks
Bill
Bill
Yeah I'm fairly certain that all 350's got the 140mph speedo, while the 305 had to have G92 specified to receive the bigger speedo.
Speedos can be swapped out tho. I'm curious to the same thing(how to tell a 350). I have a 350 in my 86 T/A which originally came w/a 305(both tpi). I know it's a 350 because I put it in there! My 89 Formula 350 was the donor car. I never plan on selling this car--but in the event of something happening--whoever runs my vin will come back w/a 305. Since it's an 89 motor(has the oil cooler on it--but lines aren't connected)will it have that pad w/the 5.7 on the pass side rear of the block? I have the dual cats to put on it, also has the dual fans and the 140 speedo w/3.27 gears(was a G92 car)--so all the 350 clues are there--except for the vin.
cdartz,
Thanks for the photograph. It really clears up where I should be looking.
Bill
cdartz,
Bill
Chris Artz
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Well the routing may be different on the birds but on the Camaros (which he is talking about) is the same for both engines.
My car has 2.73's or 2.77. I only know from the 70 mile an hour trick in drive.
Car: ‘92 Z28
Look for the VIN on the block. Stamped on a pad forward of the passenger side head. It won't be the complete vin, the 1G1FP part is deleted. You will have to probably move some stuff out of the way, but this is the most accurate way to make sure it is the original engine. While you are looking for the VIN, there is another alphanumeric code there too. Note that and reference it in the white book or post it and someone here could figure it out. If I find a pic of mine, I will post it.
Good Luck.
Good Luck.
Good info. I have been wondering if my car had the original engine in it or not. It pulls to hard according to the butt dyno to be a stock 305. We shall soon find out.
Originally posted by 87WS6
What all came with G92? I have 145MPH speedo and I have the LB9 engine. Not the L98. I checked the RPO decoder and it listed G92 as rear axle ratio performance stuff. Says nothing about speedo.
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Isn't the redline on the L98 5500 and the LB9 5000? that would be an easy way to tell. but if it isnt the original engine, you can always check the block.
Car: 87 formie
Engine: none
Transmission: none
on my car theres still the sticker on the inside of the hood, by the passenger side that says what engine it is. but in most cases u hardly see those on a car.
Car: 1990 TPI Camaro IROC-Z (G92code)
Engine: LB9 5.0 TPI (w/ G92 option)
Transmission: T5 manual 5-speed
Axle/Gears: GU6 option 3.42 posi
Well G92 usually consisted of a package of stuff. When G92 was specified on an auto LB9's (up until 88 or 89) it included a disc brake rear end with 3.23 gears, oil cooler, 145mph speedo and limited slip unit. The only difference between the manual and auto LB9 before 89 IIRC was the higher geared rear end (3.45) in the manual cars. Even with G92 I'm pretty sure all the auto LB9's still were rated at 190 though and the manuals 220.
Last edited by nedaCFilms; Jul 28, 2012 at 08:04 AM. Reason: would like to add a picture
