how do I find the Production numbers for 91 with the 305 ho and 5 speed
okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
You dont, there are no combination production numbers, probably the best you could accomplish is to take the total number of 305 TPI, total number of M5 trans, and go from there. You might be able to do some math and get a general idea... I have NO Idea what the production numbers were but here is an example.
If there were 50,000 cars made in 19xx
10,000 of all 19xx them had the 305 TPI
10,000 of all 19xx had the M5
You could probaly guess that 2,000 19xx cars had the combo, but thats as close as you get...
John
John
Ok but how do I get the numbers to start with ?
There was no 305 HO motor in 91... last year for that motor in the F car was 86, and there were very few then.... so I'd say there were zero
okfoz
close
- Join DateMar 2001
In 1991 the LB9 was referred to as the "HO" engine in the Pontiac dealer brochures.
John
John
GTA4ME
close
If his car is a base model Firebird it has a L03, which is a TBI.
okfoz
close
- Join DateMar 2001
Could be a Formula as well, lots of people call them Firebirds, forgetting, or ignoring the fact that its a Formula....
But your right, if it is a base Firebird then it would only have the LO3.
John
John
Yes it is a Formula I was not thinking
the codes are
Gu6
lb9
mk6
mm5
ws6
w66
the codes are
Gu6
lb9
mk6
mm5
ws6
w66
