Rust protection from the factory?
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I dont have too much rust on my 87 IROC except for the battery tray but I see some that are rusted thru!
Did GM put any coating to protect against rusting on these cars?
I know the Berettas (90+ from what I've seen) were given a "dip" of some kind to protect against rusting.
They did come with a 6yr or 60000 mile rust though warranty. This was only if the rust came the inside and other limiting factors.
The rear wheel well lips were the worst offenders.
Car: 89 Camaro RS
Engine: 305 TBI
In 87 GM started to galvanize the body panels.. so that is one reason yours has done so well. Plus taking proper care of it .. like if you drive in the winter.. keeping it really clean..
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The rocker panels on both my 83 SC and 84 Z28 Camaros were galvanized. The rest of the 84 rotted out from around them
I wish they had done the entire undercarriage...
yeah and the seam sealers were bad back then, so when that would crack water would run in straight to bare metal. cause they seam sealed it before they primed and painted so there was no protection on the metal. this happened to most lower door hem flanges
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
The battery tray was the only area on my 82 bird that saw any rust. The underbody is completly rust free. But then I go though it every few years, clean it and undercoat it. I'm the orginal owner!
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I noticed a cool galvanizing on the underbody of my 82 Z. I was like hey its kinda shinny. Cool
Axle/Gears: 9-bolt/3.45
I remember something about that rust and corrosion protection warranty when I ordered my '87. It might be galvanizing, but that's not what they called it. Their "process" actually had a name, but I don't remember what it was.
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
A couple things as a winter state owner, Not sure on validity, but sounds good:
When temp is below freezing, road salt and melt is not much of a concern and it's hard to wash a car in extreme temp. If ice builds up behind wheels, etc...this can keep additional salt off metal areas that would normally get reapplied from more driving.
Washing the car whenever warmups happen is a good idea. I have to deal with rust on all my panels at this stage, and so far, got a nose (bumper took a couple hits, although not rust) and front fender off eBay but still working on shipping for that. Having custom parts for the ASC droptop, not sure a replacement panel can be had so I have to make repairs before it becomes something major. Was trying to get a line on a trunk hinge, etc.
Be cautious on the road, people haven't seemed to make much improvement in their driving I've found!
Bill
Bill
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I have all the original paperwork for my 67,500 mile 87 L98 IROC-Z and it's called the Pennzoil Pennz-guard. When my car was delivered to it's 1st owner by the dealer, they gave papers entitled Pennz-Guard Coatings Limited Warranty. It has the cars information and mileage when given to the new owner and what was to be protected. Mine has rustproofing, paint sealant, and fabric protector checked off to designate coatings to be applied.
There is only surface rust on things like brackets, some rear suspension, driveshaft, rear sway bar and 9-Bolt, otherwise everything else is perfect. This coating is still there and whatever it's on still looks new.
It was even in the engine bay, but I shined that up. (the coating really doesn't matter as the car never saw lousy weather and never will) But, it is still there in places I can't reach under the hood, on the underbody, and some front suspension. As for the fabric protector and paint sealant I have no idea, but the car still runs nice original paint and a mint interior. Matter of fact, it still has the little Pennz-guard sticker in the lower drivers' corner of the windshield from when it was put there new in 87.
Hey, congratulations on finally finding your car!
But that rust protection/appearance/fabric protection package you described sounds more like a dealer applied package. Are you sure that's from the factory?
Thanks.
And nope, it's dealer. Worked great though.
This is the only type of protection I can think of that someone might take as "factory."
But now that I think about it, I recall SM talking about a coating also. Not sure if it's the same as the one I'm describing.
This is the only type of protection I can think of that someone might take as "factory."But now that I think about it, I recall SM talking about a coating also. Not sure if it's the same as the one I'm describing.
My car has a dealer installed Rusty Jones undercoating. It's a beeswax based solution that was heated and sprayed on. It remains soft even today. Not a factory option. I believe that the 87 model year started galvanizing the metal panels. Not positive though
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
On the options page of the 85 dealer book it states
"All camaros feature precision, robotics-aided assembly and anti-corrosion measures that have stood up to brutal corrosion testing"
but it doesn't say what the measures were!
Right after I took delivery of mine I had the Rusty Jones undercoating done also
More people with coatings! They seem to work good, but my car was always a nice weather only car so it's difficult to say.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
My car was aftermarket rustproofed and undercoated at some point by a previous owner as well. It is also a survivor with only minor surface rust and original paint.
But again, my car was only ever driven in summers, so I don't know how much it helped versus just skipping bad weather.
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
My Firebird has a rubber-like factory paint from 2/3 down on the doors, to the bottom of the rockers. Until I purchased it 5 years ago, the car had NEVER been driven in the rain, and all the raw metal parts were still shiny. While I dislike unit-body because rust can easily ruin it, I suppose that most of us have been lucky in that area.
Owning a 2nd car for bad weather sure helps.
gta892000
Sep 16, 2015 12:37 AM
cars, factory, guard, happened, iii, jones, pennz, pennzguard, pennzoil, penzguard, penzoil, protection, rust, rusty, undercoating, undercoatings, vehicles
