1986 Trans AM WS6?
Car: 1990 Iroc Z Convertible
Engine: LB9
1986 Trans AM WS6?
Just bought a 1986 TA parts car, it was originally an LG4 auto. On the dash there is a little badge that says performance suspension, does this mean that it has the ws6 suspension? If it does have ws6 what gears will it have? This site states that 86 LG4 auto's got the 2.73 rear.
Car: To many to list
That badge doosent mean it has WS6.I think there were a few different level suspension packages.If it were a WS6 it would have a hollow front sway bar and 16" wheels,and stiffer springs.Search for WS6 suspension and you will find everything you need.HTH
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
THe WS6 was available with the LG4 in 87 for sure, I could only assume it was the same in 1986.
The best way to tell is the RPO sheet, but if that is missing then if you have the 16" rims that were on the 87 Formula then that would also be an indicator.
Other than that break out the calipers and measure the sway bars. I forget the measurements.
John
John
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Badge was used for Y99 and WS6 supensions. Look for the 16" HiTechTurbo rims like others mentioned for WS6
Easy way to find out what rear it has or used to have is take down the axle code stamped on the front of the passenger side axle tube.
Car: 1983 Daytona Trans Am
Engine: LG4
Originally posted by 84L69TA
My 83 LG4 TA had WS6.
My '82 LU5 car had WS7 and my '83 LU5 car has WS6.
How many early thirdgens have you had 84L69TA?
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Pilotrick50
Sep 2, 2015 12:48 PM
drathaar907
Aug 10, 2015 07:44 AM
