Rear wheel spacers???????
My 91RS has a spacer in the left rear wheel but not the right. Its about a 1/4" thick and slides on the studs. Is there supposed to be one on the right? What is its purpose. Oh yeah, its marked "rear" on it. Thank you guys!!!!
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Z28 cam.
ABS system.
Strutbrace.
Rollbar.
sounds like you are missing one. do you have the 16 in tire? I have one on each side. They are both the same, so you might get one at a junkyard of thirdgenparts.com
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC
when it warms up Edelbrock STB maybe springs
Jeremy
92 Z conv
5-spd B&M shifter
those are the spacers for 16 inch wheels with rear drum brakes. I had to get them for my 89 firebird when i got my WS.6 wheels (16 inch) and i got them for 28$ a pair from the gm dealer. No big deal if u run w out them ur offset will be 1/8 inch off on either side out back but no rubbing at all-MIke
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
my car has them too ..only part i found that was weird was its a 82 with the factory 15x7's .... i've heard some about these spacers but nothing about them being on a 82 .... anyont have any info on this???
Hey does the spacers come from the factory i have a 86 IROC 19K miles on it and it has rear drums but no spacers do i need them? and what is the purpose of them other than the offset?
o and the purpose was to match the off set of the front wheels. If u look at the fronts compared to the backs the backs sit in a bit more than the fronts so the purpose is to even the rear with the front
Man you learn something everyday on here thanks for the info i'll be getting some spacers nows-ville
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
