Stupid question L98
Old Jul 13, 2006 | 01:54 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Stupid question L98
Are all L98's speed density cars? Im looking to buy an Iroc w/ an L98 but dont want to buy a MAF car. BTW i searched and had no luck .
Old Jul 13, 2006 | 02:08 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
90-92 were SD, all years prior were maf
Old Jul 14, 2006 | 01:54 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Old Jul 14, 2006 | 08:00 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
no one has asked:
Why do you not want MAF? its not like its inferior, they went back to it on the 4th gens.
Actually if your doing a swap the 88 - 89 will give you the most power if you convert it to MAF..
OH, and before I forget, if you want a SD IROC, you HAVE to buy a 1990 car...
JOhn
Old Jul 17, 2006 | 11:23 AM
Car: 1992 Z28
no one has asked:
JOhn
07-14-2006 12:54 AM
Because I have a procharger and a speed density setup in my garage with a tuned prom and everything. I just wanted to do a motor swap. Ive heard tuning SD is easier than MAF. Ve tables and stuff.
Old Jul 17, 2006 | 11:55 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
It's actually the opposite, MAF is easier to tune than SD and is more forgiving on upgrades such as cam, rocker arms for more lift, intakes etc etc because it relies on the MAF more than the MAP sensor which SD runs off of.
Old Jul 17, 2006 | 02:35 PM
okfoz's Avatar
If thats all your doing is wanting to do a swap then there is no problem, other than the Throttle bodies and LH runners on 87-88 there identical to the 89-90, everything should swap over.
If you want the SD then just put it on.
The difference between the 85-88 setups is the Cold start injector, you can leave it unplugged and use it as a hole plug if your going to use the original runners. IF you use the 89+ style runners you NEED the 89+ Throttle body as the LH runner supplies the IAC for 85-88 cars, that tube feeds into the Cold Start Injector, but if you elimiate that then there is no problem.
ANY L98 should work in this case as there otherwise pretty much the same except for the electonics:
To recap
87 ~ 88 - Same
89 - Cold Start Injector removed and TB changed slightly
90 ~ 92 - Changed to SD. Otherwise the same as 1989.
Of course there were cam differences too from year to year.
JOhn
Old Jul 24, 2006 | 02:58 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Maf cars "learn"
SD cars adjust each time for what it is.
I bet a S/C would play tricks on a SD car.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
