weird options?
Old Jul 16, 2006 | 10:39 PM
kyle88transam's Avatar
Car: 1986 Trans Am
Engine: soon to be a iron block 5.7 lsx
Transmission: 4l80e
Axle/Gears: 9 inch
weird options?
Ok so I changed a fuel pump in my car the other day and noticed I have an aluminum driveshaft, and on another thread they said the 1le cars had baffles in the gas tank "It's got baffles that prevent fuel starvation during hard turns when you have 1/4 tank or less". I have the normal one piston front brakes and drum brakes on the rear. My car is a 1988 Trans Am with a 305 TPI and 700r4. Were thes seperate options that my car could have recieved or did the factory just throw some other parts in? What else did the 1le package come with?
Old Jul 16, 2006 | 10:58 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
https://www.thirdgen.org/IROC-Z-1LE-performance-package
This link should answer all your 1LE ?'s I'm glad my car wasn't a 1LE, because I'd feel bad about the "custom" things I've done to it. I do like the gas tank and drive line idea. I think i'm going carbon fiber when I upgrade the driveshaft. It's as strong and lighter. I want a 1LE tank though. Daniel U
Old Jul 16, 2006 | 11:27 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
all 1le's got the brake upgrade. And as far as the aluminum driveshaft it could have been swapped in in the last 18 years especially since 4th gen driveshafts bolt right in. I'm not sure which year it started but my 87 didnt have baffles and i swapped it in for a tank from a 92 because it was damaged and it does have baffles. Maybe 88 started with baffles my 88 i have no idea if it did or not. My guess would be yes because it can corner alot more than my 87 and if i have under 1/2 tank of gas in the 87 it used to sputter from fuel starvation. the 88 never has?
also in response to daniel. why go with CF? It's expensive and doesn't gain any significant hp over an aluminum one. Just stick with an aluminum one it'll save you about $650 and just get a safety loop if your worried about it messing up the car if it breaks.
Old Jul 16, 2006 | 11:31 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
The 1LE tanks also had a swinging fuel pick up that helps when hard cornering and you're low on fuel(.5 gal.)
Old Jul 17, 2006 | 12:13 AM
JT's Avatar
JT
Community Administrator
Originally Posted by kyle88transam
Ok so I changed a fuel pump in my car the other day and noticed I have an aluminum driveshaft... Were thes seperate options that my car could have recieved or did the factory just throw some other parts in?
JG1 – is the RPO for the optional Aluminum driveshaft. My '88 Trans Am has it too. It is similar equipped as yours. Aside from the Aluminum driveshaft, it also has the LB9 305 TPI, 700R4 and 2.73 gears.
Old Jul 17, 2006 | 12:28 AM
David M's Avatar
Car: '84 Z28
Engine: L69
JG1 aluminum driveshaft
Also to add to the confusion all '92 Z28's with the TPI 305 (LB9), manual trans. (M39), and t-tops (CC1) got an aluminum driveshaft as well.
Old Jul 17, 2006 | 12:39 PM
Car: 1986 Trans Am
Transmission: 4l80e
Axle/Gears: 9 inch
Thanks guys I pretty much knew it wasn't a 1le. I just wasn't sure if the options I had were diffrent than others out there.
Old Jul 20, 2006 | 05:49 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Man I had a 85 camaro. I couldn't do a dounut to save my life. I had to keep cranking after I took a sharp turn. It was a carb motor though. Now the 87 with the tpi has had NO problems with it starving for fuel, unless you want to count the time I forgot to put gas in it. lol. The only thing I hate is how the stock gage dosen't stay in one spot. It moves every time the car moves. Adam :-)
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
