Is it a 305 or 350??
Car: 1989 Iroc
Engine: 5.7L 350 TPI
im not sure if chevy and pontica used the same rear ends in both cars, but my 1989 IROC-Z has a 350/700r4 with 2.77 gears.
hope this helps
John
hope this helps
John
Thanks for the welcome. I did look it up and it seems that Borg Warners only came with 350's. Thing is my Borg Warner seems to be connected to a 305. From the info i read the block should be a 350. I'm confused.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's not right. LOTS of 305 cars have them. It might be true for one particular model of car, or one particular year, or something like that; if so, I've never heard of it or seem it in cars around me, but I could be wrong; but it's certainly not a general and universal rule.
Your car has whatever motor it happens to have in it, regardless of whatever rear happens to be in it. My car is an 83, and I put a rear in it with PBR brakes on it (clearly, not available in 83); that doesn't tell what kind of engine I have in it at the moment.
Your motor is identified by its casting numbers. All the rest of that, is not very useful.
If you want to know what your engine is, post the casting number on the block. Conveniently located right out in the open in plain sight (NOT), on top of the bell housing flange on the driver's side. The last 3 digits (which are enough) can also usually be found on the side of the block somewhere.
Casting number do not lie. Well, almost never, anyway.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The VIN only tells you what was in the car when it left the factory, not what it may or may not have now.
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
I know a guy who bought his 82 Z28 new and ordered it with 4 wheel disc brakes. He still has it with very low mileage. It has the BW rear end. I believe the BW rear end was the rear disc option through 89 90ish. This is the history/restoration board, so what it came with from the factory "IS" the most important part of these threads, not what the car may or may not have now.
Engine: 383 Carb
Transmission: 4L60
The 9 bolt wasn't available in 1982. The rear brakes also had nothing to do with which rear was used.
Axle/Gears: 9-bolt/3.45
True, but history documents that the Borg-Warner 9-bolt wasn't available until 1985. So something isn't kosher, or someone's simply mistaken. That top, center tenth bolt can be hard to notice sometimes--especially if it's missing, which might be the case.
Engine: 383 Carb
Transmission: 4L60
The 9 bolt didn't make an appearance until 1985 in the Firebird, and later in the Camaro. It didn't exist in 1982. If he has the original rear, it's a 10 bolt. If it has a 9 bolt, it's not original.
People with 9 bolts would have to disagree with what? There are tens of thousands of 10 bolts with disc brakes. Ordering rear disc brakes didn't make the car get a 9 bolt.
Also check your SPID label for G92, which is the code for the performance axle ratio option(3.27 with an automatic).
These would be places to begin your search, and are most likely still accurate.
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
You need to update your incorrect info on Third gen rear axles.
Leon.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Trans Am GTA Technical Specifications
in '88 the 3.27 could come with the either the 305 (with auto or stick) or 350 (of course, auto only).
There wasn't a G92 code for the Pontiacs, it was supposedly a Chevy only code.
