this is a disgrace
Old Jan 25, 2007 | 10:01 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
this is a disgrace
not only is it another 4x4 conversion, but they used a ford drivetrain!
http://cgi.ebay.com/ebaymotors/1994-...QQcmdZViewItem
Old Jan 25, 2007 | 10:20 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
yep, saw it on Z28.com...too bad they didn't use a Chevy K5 Blazer drivetrain...looks nicely executed otherwise even if it is hillbilly...BTW, can you see a t-case shifter anywhere in those pics?!
Josh
Old Jan 25, 2007 | 10:33 PM
johnnyboy's Avatar
you can't see it, but the seller said that it's on the driver side under the door on the outside of the car so you have to open the door to shift it, i guess they did save the body kinda by not cutting another hole in it. it is a pretty decent job for what they did, but a ford drivetrain?!! nobody wants to see a gm body over a ford frame and drivetrain, if it was a foxbody 'stang over a blazer frame and drivetrain it would be better.
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I've looked thru the pictures and don't see a T-case shifter either.They may have used a full time case with manual hubs or electric shift.My '88 Jeep GW had it's shifter under the edge of the front seat.Then my '95 Jimmy has a part time case with shifter in the console.Would be interesting what T-case/trans/front -rear end they used.But you're right screaminformula would have been nice if they had used a GM running gear.I wonder how they handled the gauges/eletronics that are still in there.
Old Jan 25, 2007 | 10:37 PM
johnnyboy's Avatar
Q: Where did you put the 4x4 shifter?
A: The shifter is in the driver side,under the door on the out side.
taken from the questions to the seller on the page
Old Jan 25, 2007 | 10:48 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
probaly one of the better 4 wheel drive conversions ive seen minus the whole transfer case shifting, but still people like this should not be allowed to own F-bodys period ever
Old Jan 26, 2007 | 12:42 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
actually its good they didnt use a blazer chassis
so that way only one gm vehicle got ruined, instead of two
Old Jan 26, 2007 | 10:19 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Well at least it is a 4th Gen car and that means one less of those on the road.
Old Jan 26, 2007 | 11:18 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I can't see any 3rd gen resemblances here....Oh, I know, :locked:
acorn1108
Members Firebirds
Apr 23, 2015 08:55 PM
FireInMe17
Mar 27, 2012 04:12 PM
88TransAmGuy
Members Firebirds
Mar 14, 2012 10:10 PM
trevorsmith82
Nov 3, 2011 06:38 AM
