Improvements over the years (squeeks,rattles, noise)
Old May 8, 2007 | 10:55 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Throughout the 3rd gen years what were some of the things GM did to make our cars squeek,rattle less ...... I would like to try stuff to quiet my 82 down bit. Since making it my daily driver rattles and squeeks are becoming more and more evident.
Old May 8, 2007 | 11:52 PM
Drew's Avatar
Re: Improvements over the years (squeeks,rattles, noise)
There are a lot of little things, but nothing that would really be a magic bullet. You could get some subframe connectors welded in, replace all the weatherstripping, replace all the rubber snubbers, etc. Most of the little things were changes in how the lock rods were insulated in the doors, and minor bracing and weatherstripping design changes. Also there are some snubber design changes and additions.
Old May 9, 2007 | 09:27 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I've got SFC, strut tower brace, and a wonder bar. I've replaced my weather stripping and the car still creaks, rattles and squeaks. I'm pretty sure most of my problem is related to the lack of a top (which also rattles).
What else can I do? One day I'll rebuild the doors which makes a lot of noise.
Old May 9, 2007 | 01:39 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
If the factory rubber bushings (sway bars / end links, LCA's, Panhard bar, rear shocks, A - Arms....) is still in place, upgrading those would help...
I have sfc's, wonder bar, stb, most of the things described above... it's much better... but I still have to do my doors & sound deaden the car too...
Raf
Old May 9, 2007 | 04:47 PM
Jproz1167's Avatar
well my doors suprisingly enough don't rattle a bit and when shut have a solid sound to them. my annoying noises are creaks in front of the car. and the hatch is always making funny *** noises. well what can a 24y/o car be expected to be like
Old May 9, 2007 | 05:31 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
what is a "snubber"?
Old May 9, 2007 | 06:04 PM
Jproz1167's Avatar
I was also considering putting T-top door wedges in my car as well. As for all the rubber bumpers & stuff they are all in excellent condition on this car. My weatherstipping is also in perfect condition.
I am curious if putting factory type seam sealant in more places would help the creaks and squeeks.
Old May 9, 2007 | 08:27 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just because the weatherstripping is in perfect shape, doesn't mean it hasn't flattened over the years. My 14k mile original car needs new weatherstripping. It still looks excellent, but I can tell that the car would be more solid with new stuff. It's usually designed to last 10-12 years, so at 20, it's time for change.
Old May 9, 2007 | 09:47 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Scott you make a good point on the weather strip.My Parents '95 Olds 88 sat under a carport covered it's whole life,only 34K miles,and you could tell the weather stripping wasn't as compliant as new.She was only 10 years old an not subjected to the elements most of it's life.Also I occassionally sprayed them done with silicone.It compresses/conforms to the shape it's at most.
The rubber snubbers are the bump stops on the doors and around the hood and hatch.Make sure the stops for the hood and hatch are properly adjusted makes a difference to.
Suspension bushings(control arms.stabilizers bars)do make a big difference.The end links on my '83 were worn out when I got her and the front bar rattled,not to mention being basically useless.Replacing the end links eliminated one noise cause.
Now if i could just find a way to tighten the loose nut between the steering wheel and the seat will help a lot.
Old May 10, 2007 | 05:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for some quieting ideas:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old May 10, 2007 | 09:13 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My '86 rattled quite a bit. My wife called the car "shake, rattle and roll". Of course with 250,000 miles what could be expected. I changed the doors and that was a big step towards a quite ride.
My '92 is a very quite car. The doors are near perfect and only my passanger door lock rod makes noise when left unlocked. I plan to deal with that in the next 60 days, although just locking the door solves that problem. 125,000 miles on her but only a summer car so that may have something to do with it.
Old May 10, 2007 | 09:36 AM
joecautela's Avatar
- Having a T-Top car the 1st thing was SFC's followed by a Hothckiss Strut tower brace. That eliminated like 90% of noise. I then spent a number of hours just tightening all the bodywork, fender bolts, suspension stuff,even mtr mounts. Anything I could lay a socket or wrench on got snugged up. Even went under the dash too. Amazing what a 1/4 turn will do to quiet things down, Joe
Old May 10, 2007 | 10:35 AM
rwdtech's Avatar
yeah, no more than a 1/4 turn though!!
Old May 10, 2007 | 11:32 AM
kaptinkafeen's Avatar
Starting with '91 and followed through to '92, didn't GM use a new bonding agent (glue) to help stiffen the cars out - especially with the convertables...
-Andrew
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
mustangman65_79
Aug 8, 2015 12:07 PM
