91 firebird ws6
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
91 firebird ws6
i have a firebird (obviosly) but am not to sure what it is exactly, and how rare it could be
k first, it has ws6 suspension i think, cuz it says it on the centercaps, and says "performance suspension" on the glovey
it has a formula hood, and the fiberglass wing with the v-notch type dealy in the middle of it (very batmanish)
engine is 305 tuned port, with a 5 speed and im not sure what the gearing is but it is bucknasty high, aiding in burnouts,, and i can't verify if its stock or not, also it appears this car had dual cats, because there is 2 new sections of pipe welded in where the cats would be
it also has t-tops, and the 16 inch aluminum rimz
my questions are,, is this a formala,, or just a ws6? or both?
and how do i know if i have the G92 option, cuz thsi car feels geared, and im hoping i got the 230 horse 305 and if anyone has an idea how many of there there are, tell me,, i have a feelign its pretty rare,
oh and its inside peanut butter,,,, outside jelly
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Re: 91 firebird ws6
Check your SPID for W66 (Formula) code. G92 on spid equals G92. Sounds like an original G92 5-speed/5.0 TPI/3.42 Formula to me.
Also, go here and download Aviator857's program to decode your entire SPID (RPO's): http://www.geocities.com/fbodyvin/download.html
Car: 91 formula ws6
Re: 91 firebird ws6
spid? is that the vin on my driverside lowerwindshield,, i got IG2FS23F0ML206279 on the windshield,,, hard to say if the 0's are o's tho,, so im gussing they are zeros
that RPO decoder wont go on my c.p.u it keeps telling me to insert a disk,,, so i gladly inserted my fist
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 91 firebird ws6
The SPID is the sheet that would be in the locking compartment in the rear hatch. This will tell you all about the options that came on the car.
Engine: Twin 454's
Re: 91 firebird ws6
Klortho answered where you will find your SPID (it's a sticker with all your RPO's on it).
HTH.
Car: 1991 Z28 (sold)
Re: 91 firebird ws6
the rpo codes will either be in the rear glove compartment or center console lid
use this RPO decoder, it involves no downloading http://www.camarosource.ca/php/camar...year=1971&tm=1 just scroll down
sounds like an awesome formula to me, post up pictures man
Car: 91 formula ws6
Re: 91 firebird ws6
console? as in center console?
i cant find anywhere to download this framework garbage!!! it always has the site moved or something!
Car: 91 formula ws6
Re: 91 firebird ws6
no numbers that i can see in center console,, maybe because the assclown painted the interior,,,
the only numbers i can see in the "rear glovebox" are on the inside of the little door, very close to the hinge,,, there is a few random numbers,,, some of them are doeble stamped... i.e a 4 stamped over a 1,,, etc
wtf do i do now?
wtf do i do now?
Car: 91 Formula WS6
Transmission: five speed
Re: 91 firebird ws6
wtf do i do now?
wtf do i do now?
Axle/Gears: 9-bolt/3.45
Re: 91 firebird ws6
For Firebird's, when it was in the console, it was not on the lid, it was on the side. So if you opened the lid, it was on the side of the storage compartment that faced the driver, so you'd be able to see it from your seat.
But in the last years of the generation, the label was moved to the inside of the rear storage compartment lid. The numbers you've described sound like they might be the lid's own part number, not the SPID label.
But from the VIN you posted, along with telling us everything the car has, you have a nicely-optioned Formula, no doubt. To begin with, the VIN irrefutably proves it very simply without debate by showing an FS(for a base Firebird) and an F(for the 305 TPI engine). The ONLY way it's possible for a base bird to get that engine is if it's a Formula... period... end of debate. And therefore, it prolly also really has all the performance options you've mentioned.
And because it's a TPI/5-speed/dual cat car, it should, indeed, have the "bucknasty" rearend ratio. That wouldn't even have been a formal option. It would've automatically come with it based on that combination of options.
Is your car rare? There are very few rare thirdgens, so no. But you've definitely got a VERY desirable car!
Car: 87 GTA
Re: 91 firebird ws6
Here is aSPID label...It has all the RPO codes on your car. Is Y84 on there? If so, GTA. Otherwise, I'm betting it is a Formula.
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Re: 91 firebird ws6
If you want to find out more info about your car, get it documented by GM Vintage Services of Canada. Their number is: (800) 263-3777 and it costs around $50 Cdn. I got my 91 GTA documented in 1998 and that is the # on the letter I got.
Car: 87 GTA
Re: 91 firebird ws6
Try Pontiac Historical Services
Here's what I got in reference to archives a few days ago...
"Hi Steve, the following information explains the ordering process for GM vehicle invoices:
The General Motor Dealer Invoice service is managed by Allied Vaughn, a tier one supplier of GM. For copies of a GM vehicle invoice, please email the attached request form to vehicleinvoice@gmmediaarchive.com <mailto:vehicleinvoice@gmmediaarchive.com> . As of March 1, 2005 the cost for this service is $50.00 per invoice. If paying by credit card, your account will be charged within two business days of fulfillment. Fulfillment is expected to take 2 to 3 weeks. If paying by check or money order, please mail your check or money order and a copy of this form to:
Allied Vaughn
11923 Brookfield
Livonia, MI. 48150
Attention: GM Vehicle Invoice
Check or money order payments may cause a delay in fulfillment, as it must clear before your order is shipped.
Invoices are available for vehicles* in the following model years:
Chevrolets since 1977
Pontiacs since 1987
Buicks since 1982
Cadillacs since 1980
Oldsmobiles since 1977
GMC since 1976
*Fleet and exported vehicles excluded
Please feel free to contact our local management team with any suggestions or concerns. Email or call:
Chris Barkoozis, General Manager
Allied Vaughn (800) 462-5543 ext 105
Chris.Barkoozis@alliedvaughn.com <mailto:Chris.Barkoozis@alliedvaughn.com>
Thank you,
Stacy Lillard
GM Media Archive & Vehicle Invoice Collection at Allied Vaughn
Detroit, MI
p.734-421-0273 x.107
p.734-261-5086
f.734-261-5216
BE SURE TO CHECK OUT www.gmphotostore.com"
Allied Vaughn
11923 Brookfield
Livonia, MI. 48150
Pontiacs since 1987
Buicks since 1982
GMC since 1976
Thank you,
Stacy Lillard
Detroit, MI
p.734-261-5086
f.734-261-5216
Car: 91 Formula WS6
Re: 91 firebird ws6
I got the Pontiac Historical Services package. Very impressive! Tons of info!
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 91 firebird ws6
1) Power Buldge Hood
2) TPI 5.0 or 5.7
3) 16" Rims
4) Aero Spoiler
5) NO ground effects
6) WS6 suspension was standard on the Formula.
7) 3.42 Axel Ratio
8) N10 Dual Cats
If you have a 1LE then its 1 of 46 made in 1991
There were a total 5,497 regular Formulas
1991 is the only year I do not have the breakdown for the Engine & Trans production.
John
Engine: Twin 454's
Re: 91 firebird ws6
Or you can go to the web page rwdtech suggested (but I personally prefer having the VIN decoder and RPO decoder program on my PC and laptops just in case I ever need it like when I see a car I'm interested in).
HTH.
Re: 91 firebird ws6
Or you can just memorize the information, with 3rd gens there is not much to remember...
John
John
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
