Gas Tank Size
Old 05-31-2007, 03:03 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Gas Tank Size
I have a 1984 firebird with the Iron Duke 4cyl.
How big is the tank?
My gas gauge doesn't work and need to know the size of
the tank so I don't run out until I can fix it.
Old 05-31-2007, 03:55 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Gas Tank Size
I just filled mine every 150 miles, but I got about 12 - 14 MPG with my 305. My tank is approx. 15 gal.
Old 05-31-2007, 04:06 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Gas Tank Size
From the service manuals I have for my '83 Z28('83 factory service,Chilton's '82-'85,Haynes '82-'84 & '82-'92)it looks like all models(I4,V6,V8)use a 16 gal(US)tank.I've seen 15.8 listed in a few places also.I have to find my '83's owner's manual to see what's listed in there.
I have a problem with the fuel sending unit too so I use the trip odometer(and regular to be safe).I would figure 13 gals to be safe but that is what I do.
j dezzy's Avatar
Car: 87 TA
Re: Gas Tank Size
I think that all the 3rd gens have 15.5 gallon tanks. i know all 4 of mine have so far.
Old 05-31-2007, 06:31 PM
buffaloman's Avatar
Re: Gas Tank Size
Thanks to all. A trip odometer is nice, but the base firebird speedo doesn't have one. I have to write the miles down. Only gauges you get is a speedo and gas. This is the car I purchased last fall on this forum with no interior. I drove it 150 miles this week and only took 3.2 gals to fil up. 37,000 miles on the car. Still had the factory shock on it. Yes I replaced them with some I had from parting cars out.
Old 05-31-2007, 07:26 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Gas Tank Size
Mine took 17.4 gallons to fill up, at three different gas stations, I'm starting to wonder how accurate the pumps are at 3+ bucks a gallon.
Old 05-31-2007, 07:28 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Re: Gas Tank Size
You're not filling up the tank or your speedo is whacked. The mileage and the gallons used should have told you that. No Camaro/Firebird has ever gotten anywhere close to 50mpg, even a 4cyl.
Old 06-01-2007, 03:47 AM
j dezzy's Avatar
Car: 87 TA
Re: Gas Tank Size
wow. I've never seen a 3rd gen with anything other than a 15.5 gallon tank...but that's just me...
Old 06-01-2007, 04:47 PM
buffaloman's Avatar
Re: Gas Tank Size
Well, lets not get on the milage thing just yet. This was the first week I drove the car and I may have written the milage down wrong. Put I do know this. It is 28 mile to work. Tuesday and wednesday drove back and forth to work 112 miles. Thursday drove to work and to the bank 38 miles I also made a test drive Monday day before going to work. Not sure how far it was. I'm going to fill up Monday morning and just drive the car back a forth to work and I can then tell if the speedo is correct.
Old 06-11-2007, 11:01 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Gas Tank Size
Must be nice. There are quite a few of us (me included) who have the 12 gallon tank instead.
Old 06-12-2007, 04:26 PM
AmorgetRS's Avatar
Re: Gas Tank Size
I don't think anyone has every shown real documentation that a Thirdgen got any different gas tank then the standard "15.5" gallon. The earlier ones with the external fuel pump held a little more gas, but were the same size. The later baffled tanks just allowed you to drive for a bit longer because it kept the pick up submerged. GM documentation on that let to confusion that the tank was actually bigger.
Old 06-13-2007, 01:11 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Gas Tank Size
Old 06-13-2007, 09:04 AM
Klortho's Avatar
Car: 1987 GTA
Re: Gas Tank Size
Not really, I'm beginning to think this is where the gas stations are making their money. I know that I have a 15.5 gallon gas tank. But to take 17 gallons to fill it up, someting flags
Old 06-13-2007, 04:23 PM
Jay
Jay's Avatar
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Gas Tank Size
I have an 18 gallon tank in my car. It came from a 92 Formula 350 that I bought for parts. If it was an original tank or not, I don't know.. but it IS an 18 gallon tank.
Old 06-13-2007, 06:04 PM
AmorgetRS's Avatar
Re: Gas Tank Size
How do you know that?
Old 06-13-2007, 06:59 PM
Car: 1989 GTA
Re: Gas Tank Size
Did the 92 Formula have A/C?
Old 06-13-2007, 07:15 PM
Car: 1989 GTA
Re: Gas Tank Size
This shows 3 different tanks for 3rd gen Firebirds.
http://www.1aauto.com/1A/GasTanks/Pontiac/Firebird. Some are 53 Litres, some are 59 litres.
The most I've ever put in was about 2 weeks ago. 45 litres. (11.9 gallons) And that was squishing an extra 2.5 litres in after the click. I could hear it coming up the filler neck to where the nozzle goes in. I have an 89 GTA. Talked to another person with an 89 305 GTA and he pulls out a gas receipt showing 61 litres of fuel. Both of our cars are air conditioned cars. So no 1LE difference. How he put so much more in, I don't know. I'm lucky to even be able to put in 40 litres most of the time.
Old 06-13-2007, 07:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Gas Tank Size
Attached Thumbnails Gas Tank Size-fueltank001.jpg   Gas Tank Size-fueltank002.jpg   Gas Tank Size-fueltank003.jpg
Old 06-13-2007, 07:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Gas Tank Size
Old 06-14-2007, 02:51 PM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Gas Tank Size
It appears that the Export gast tanks were the largest when they were equipped for "Leaded" gasoline....
I have to wonder Why?
I do KNOW for a fact that the Actual tank from an 87 LB9 and 87 LG4 cars are close enough to where I was able to swap the sump from one to the other... My donor cars tank was horribly rusted, so I used my original tank which was almost like new...
John
Old 06-14-2007, 03:09 PM
j dezzy's Avatar
Car: 87 TA
Re: Gas Tank Size
hmmm...my 87 and 84 TAs both have LG4s and they have 15.5 gallon tanks, my 91 bird had a 3.1 and it had a 15.5, my 87 camaro had a 2.8 and it had a 15.5...I've never even heard of a different tank size since this thread....
Old 06-14-2007, 06:46 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: Gas Tank Size
Looking at the '83 Camaro brochure it lists fuel tank capacity at 16.2 US gals.But cars with the L4 or CFI V8 have a capacity of 15.8 US gals.
Old 06-14-2007, 08:38 PM
Jay
Jay's Avatar
Car: 88 IROC
Engine: 5.7 RamJet
Re: Gas Tank Size
Because when I originally swapped it in, it had zero gas in it. I put less than 1 gallon in.. was a 2.5 gallon can, which was less than half full. I started the car a few times, testing other things, drove it up and down the driveway a few times.. I had done a rear end swap at the same time. Drove it to the gas station finally which is about 2 miles away, and put 18.1 gallons in it. On other occasions I have put similarly high amounts of fuel in.. 17+ gallons.
I have owned several thirdgens and all the fill ups would be in the 14-15 gallons range. This is the only one that I have seen a larger capacity.
The tank is close to empty now.. I just replaced the fuel pump. lol I'd be more than happy to have someone come fill that tank to verify, when I get the transmission and rear end back in.
I'm pretty sure it did. I think I still have the HVAC control in one of my parts piles.
Old 06-14-2007, 08:50 PM
Car: 1989 GTA
Re: Gas Tank Size
Hmmm, those pictures that Apeiron posted are rather interesting. Seems to show that the 1LE cars don't have 18 gallon tanks.
Old 06-15-2007, 08:39 AM
okfoz's Avatar
Re: Gas Tank Size
THe difference may be accounted for by the sump system, If all things being the same a few tubes compared to the pump, filter, this that and another thing may easily equate to .4 gal...
...17+ gallons. I have owned several thirdgens and all the fill ups would be in the 14-15 gallons range...
I am not sure how they rate the capacity of the fuel tank. If they rate it by the tank ONLY then the filler neck may account for more fuel. I know I can actually get more fuel in my Firebird if I park on a slight slope where the left rear of the car is the highest point. Because the way the filler neck goes into the tank, you can evacuate more air while fueling. Although I would not think that the filler neck would take 2 gal it may add 1. THe other option is if your tank is deformed somehow, if you were to take the tank and expand it, you should get more volume... not sure how well it would fit in the tunnel, but its possible.
JOhn
Old 06-15-2007, 09:15 AM
coolram62's Avatar
Engine: LU5 305 CFI
Re: Gas Tank Size
Thank you Okfoz I had a feeling that was the answer since those were the only 2 motors for '83 with EFI.
One variable to consider in filling a tank is weather conditions.I know the tank capacity is a fixed value and this may sound like a silly idea.But tempature,humidity,elevation and even moon/tide cycles can affect how much you can put in at refuel(though granted the difference may only be in tenths).
Old 06-16-2007, 02:23 PM
Jay
Jay's Avatar
Car: 88 IROC
Engine: 5.7 RamJet
Re: Gas Tank Size
Looks exactly like the tank I took out, and it actually seemed to fit in better than another tank I swapped in a different thirdgen. I forget which straps I used. I only swapped because the original tank was leaking at the filler neck. This one was like new.
Old 06-17-2007, 12:30 PM
Axle/Gears: 3.08
Re: Gas Tank Size
Brochures are not a good source of accurate information. They are a rough guideline as to features, options and specs. And they change quite frequently, even during the same production year.
Here's another '83 Camaro bruchure that states 13.3gal / 60.5L!
That's almost a 3 gallon difference from the one you sourced from. Pretty crazy.
http://www.camarosource.ca/new_site/...roch_page6.jpg
Can you provide your brochure documentation? It would be cool to compare, just for curiosities sake.
Old 06-19-2007, 01:14 AM
Car: 1989 GTA
Re: Gas Tank Size
Well this Sunday, I pulled into a car show with low fuel. By the time I got out of the show later I was on the yellow line. Drove on the highway for 15 minutes and was down past the yellow and on the empty line.
The car was running rough on the highway. Jittering back and forth. Like the brakes were sticking on and off. Pulled into a gas station on fumes annnnnnd:
45 litres again. Just a hair under 12 gallons. *throws hands up in the air*
I don't know what to say. I can't imagine driving another 2 gallons like this and then filling up like some of the posters are saying. This was a constant 55 mph on the highway and it was still straining to get the last of the fuel in. It wasn't like I was doing hard cornering and stopping.
Car has had the small tank since brand new. It's always been like this. So I don't think it's that something is blocking anything down there. No sludge.
12 gallons.
Old 06-19-2007, 07:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Gas Tank Size
12 gallons.
No matter what amount of gas you put in or think
the size is. IT STILL IS A 15.5 GAS TANK DUMMY.
Old 06-19-2007, 07:31 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Gas Tank Size
and im sure that the manufacturer didnt count the entire tank including the fille rneck as the actual filling capacity of the tank either
most likely
may be able to put 17 in it but it still rated 15.5
as per manufacturer specs
export probably had different sizes, so it seems
who knows what they had in them
regulations and rules differ country to country
hell in some countries they have to have amber lenses in the rear regardless of the make and model
theres some real funny stuff out there
Infested
05-22-2018 11:56 PM
Orr89RocZ
04-25-2016 08:28 AM
mustangman65_79
09-01-2015 03:51 PM
AkDrifted
08-17-2015 07:45 PM
kyleb24
08-15-2015 08:24 AM
Quick Reply: Gas Tank Size
