Date off the Assembly Line
Car: 1989 Camaro IROC-Z
Does anyone know how I can find out the date my 89 IROC-Z came off the assembly line?
Thanks very much!
Thanks very much!
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Date off the Assembly Line
you can see the week and month if you look on your body tag code on the rad support
look for a two number and a letter together code at the beginning of a line
such as 08E
august 5th week
such as 08E
august 5th week
Axle/Gears: 9-bolt/3.45
Except that md65000's car is an '89, and it doesn't have the same kind of tag as an '82. The tag on the radiator support changed in the mid-'80s. And about half of the '87s received no tag at all, most-likely because the tag meant nothing, other than to reference the car's build sheet number.
And the locations of those newer tags tended to vary by plant and model year. Sometimes it was in the traditional center-ish location on top of the support. But it might also be found nearer the passenger side of the top of the support. But it means nothing anyway because there's no encoded information on it.
You'll find the month and year of production on a label on the driver's door jamb. But the exact date can be found with the last six digits of your VIN. I don't know how to find it that way, but perhaps someone who does know will chime-in.
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
Transmission: Borg Warner T-5 5 Speed
Axle/Gears: Borg Warner 9 Bolt 3.45 LS
I remember on my old camaro I found the build sheet inside the passenger seat cover. Do the 3rd gen's have a build sheet hidden anywhere?...
Nevermind, I just did a search. I may snoop around for it later...
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
I don't know what any of this stuff means either. It's still cool to have it though...
In this thread, David M shows that he apparently knows how to find your exact build date using the last six digits of your VIN:
https://www.thirdgen.org/forums/hist...ght=date+build
And in this other thread, we covered the meaning of the later style body tags; showed that its location varied; and there are some pix:
https://www.thirdgen.org/forums/hist...light=body+tag
It should be this later style tag that's on md65000's '89. And all that tag represents is part of the job sequence number on the build sheet, nothing else.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
