Couls not find several RPO codes Please help
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Ok I check every single RPO code on some different sites and several didnt come up. Matbe some of you could help me out
BV3 - ???
B60 - ???
D14 - ???
D7C - ???
D9A - ???
GH3 - ???
WW6 - ???
8OA - ???
84P - ???
If you guys could check these out for me thanks or even give me some where I have been
The list of RPO codes are on Page 7 on my 1986 Trans Am cardomain
BV3 - ???
B60 - ???
D14 - ???
D7C - ???
D9A - ???
GH3 - ???
WW6 - ???
8OA - ???
84P - ???
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Couls not find several RPO codes Please help
From the over 3300 RPO codes that I've compiled
BV3 = ORNAMENTATION, INTR, I/P, BLACK
B60 = DECAL PACKAGE, 01
D14 = ARM REST, FRT DR, RH & LH
D7C = GEAR, SPEEDO DRIVEN
D9A = SENSOR, VEH SPD
GH3 = AXLE REAR, 2.77 RATIO
WW6 = APPEARANCE PACKAGE, AERO #6
80A = STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
84P = WHEEL COLOR GRAY (91)
Typically RPO codes do not use the letter "I". It can be mistaken for the number "1" so if it looks like "I", treat it as the number "1".
Same holds true for the letter "O"; it is to be read as the number "zero".
I hope this helps.
I hope this helps.
Engine: 350/350/LS1
Thank you man That means alot to me. Now I even know my gear ratio.
Thanks a bunch
Thanks a bunch
Car: '87 IROC
Engine: LB9
Keep in mind though, that sometimes one RPO code can stand for two different things. I just found out the Z06, in Corvetter-speak is a merchandising package for performance equipment. But in Camaro-speak is an interior option.
Engine: 350/350/LS1
Hey what website did you get this from?
Car: '87 IROC
Engine: LB9
hectre13
Dec 11, 2023 08:14 AM
