Overhead console
Car: 89 Formula
Transmission: TH 700R4
Overhead console
Was a T-roof car required to have the overhead console?
I saw a pic of T-roofs WITHOUT the console--so I am just curious.
thanks
thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Overhead console
The console was optional I want to think only a few years, 1987 would have been the last year.
John
John
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Overhead Consoles were standard equipment on all 84-86 berlinettas. There are two different models, one that is flat for the hard top cars, and one that has a bend in it right around the map light location that is for t-top cars. The parts in them are interchangable, but the actual console unit are different.
I thought that they might be available in 1988 but someone said no.
The T-top model is flat where the Hard top version had a curve to match the headliner.
John
John
Car: 04 Silverado
Engine: 4.8
Transmission: auto
https://www.thirdgen.org/forums/hist...-c-t-tops.html
Car: 04 Silverado
Engine: 4.8
Transmission: auto
yea sorry i had the two confused. As mentioned, wiring harness, 4 screw mounts (pre-drilled holes already in your roof), two screws for inside the dome light encasement and the console is all you need to do a complete plug and play swap.
As you can see from my signature at the bottom, i have added one to my firebird, and it took all of maybe an hour? Give or take, as i've had a little experience in dropping the roof liner and where the plugs were. So very simple that someone may have added it, as i do not know when the roof console was absolutely discontinued from production.
Hello John, you might have seen my post, could you answer my question about the overhead console?
I would think that the Hard top console would work better but its an ebay $50 gamble if you found one. But the thread was so mish mashed and hard to follow I really did not catch what you were wanting up front until I looked at the pictures, I was not really sure what the "Socket" was that you were speaking of.
John
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Yes, I guess it got a little scrambled. I was speaking about the swivel light, in factory cars there was a hole to allow the depth of the socket base, in my car the hole was never drilled
this is what is causing the confusion about which overhead console would have been used if any
As you can see in the pic posted below (factory), the hole allows the swivel light to seat properly, on my C&C car there is no hole hence I cannot fit the socket.
As you can see in the pic posted below (factory), the hole allows the swivel light to seat properly, on my C&C car there is no hole hence I cannot fit the socket. Senior Member
Car: 1991 Z28 1LE
