Mice!
Car: 1984 Camaro 'Vert
Mice!
In trying to bring my Firebird back to life, I found out the horrid disadvantage of barn finds. For 3 years mice called my car home. I intended to just take out the carpet, seats, and maybe a few cracked plastics from the inside.
Inside I found a mouse graveyard with exploded remains, urine stains, and seat foam everywhere. I think I can still smell it even when I'm not close to the car. I stripped everything out of the inside and cleaned everything in sight. Will the smell go away? Please tell me you guys have seen worse?
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
Re: Mice!
the worst i had was some droppings under the carpet in the front, thats it, and it didnt smell, im guessing was the inside out somehow, and it should be fine, you know, soap and water, lol
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: Mice!
man that sucks one day I took out my rear seat, and found a nest under it but I got lucky they must have been camaro loving mice, because they didnt even tear anything up
Re: Mice!
I'm going to revisit the car today. It has been sitting bare since saturday when i de-rusted and painted the interior metal, and at least tried to patch a hole in the floor. I need to get a little more paint on there, investigate and fix the patch if neccisary, etc. I'd think that the smell of that much stuff drying would probably overcome the smell of about everything else. But I also know the smell of dead mice is one of nature's most powerful smells... We'll see.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Mice!
Re: Mice!
Paint over them? Why whatever could you mean....I was running through the car with sandpaper getting rust off, then used a shopvac on the car to get any loose stuff out, including what the mice left...
Then I hit a bunch of spots with that rust remover gel, which seems to act a lot like acid, then I rinsed that up and dried the metal off, then I prepped and painted.
But no.. I didn't specificly try to get the nasty looking stains off if there wasn't rust behind them. I hit alot of the car with that rubberized undercoating after I primed and painted, both in an attempt to make the metal more resistant and to help deaden noise. I figured any particulate matter left by the mice that still happened to be there would be hidden by the textured surface of the undercoating... lol
Car: 1991 Chevy Camaro...
Engine: 406 With Many Mods..
Transmission: Turbo 350...Hurst Quarter Stick...
Axle/Gears: 373 Gear..Posi Rear End...
hw4mike
Jul 2, 2010 09:56 PM
Gawd Dang Mice they should stay in the Clock and out of CAMAROS !!
