Keep cruise control? or delete...
Old Jun 9, 2008 | 07:19 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
I have an 85 Z28 with cruise control, only camaro ive seen with cruise control actaully...
and well it doesnt work, the wires to the servo are cut...why i dont know, previous owner. and ive tried connecting them, cruise still doesnt work. Im not sure whats wrong with it. The cruise computer is still in the dash(i saw it).
I mean i would probably never use it, but do you think its worth it to keep it, was it a rare option on these cars?
If i keep it...i still dont know whats wrong with it.
Old Jun 9, 2008 | 07:59 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Keep cruise control? or delete...
Not a rare option and, if it was, it would not generate more value. If it doesn't work and you won't use it, I'd remove it.
Old Jun 11, 2008 | 08:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
in 1985 it might actually be a easy fix... maybe not.
It might be as simple as the switch on the column is broken (not uncommon to have a broken wire.)
Personally since it does not weigh that much I would leave it alone, unless your that hard up to get that .01 extra MPG...
John
Old Jun 11, 2008 | 09:05 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Not rare at all. Almost half (47.2%) of all '85 Camaros had cruise. If you want to use it, fix it. I drive only highway miles and couldn't live without it. But it all depends on your type of driving. If you don't think you'll use it (as you said), then you can just leave it.
Old Jun 11, 2008 | 09:09 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
thats odd because the last two firebirds i had have had cruise control but the previous owner cut the wires..maybe people had problems with them.. i still wouldn't cut the wires on it though.. lol
Old Jun 12, 2008 | 07:52 AM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Mine sometimes does not work, just flip it a few times andit comes on. I would not delete it, I love to use it on highway, besides sitting low and having feet free are nice on trips to Orlando. Andrew
Old Jun 12, 2008 | 10:05 AM
okfoz's Avatar
Most of the problems that I have had with Cruise has been with the Switch on the turn signal lever... Secondly the Vacuum controller under the hood....
I bought one car and the guy had no idea why the cruise did not work... Before I bought the car I noticed that soemthing was unplugged... When I asked him if anything did not work he told me the AC and the Cruise... A lightbulb went on and I said, Thats what that was for and plugged in the harness to the Vacuum Controller... I used Cruise all the way home...
John
Old Jun 12, 2008 | 04:32 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Well, ill keep it, who knows maybe i might like it.
the signal lever switch is old as hell, theres no lettering on it. so its probably something to do with it. Ill also trace the vacuum hoses and reconnect those wires (maybe ill just get some lil switches, to test it temporarily to rule out the cruise.)
Old Jun 13, 2008 | 08:01 AM
okfoz's Avatar
THere is a thread on here some where about Cruise control You can test your switch pretty easy. I want to think that you have the same system that I have on my 87. Here is a quick guide on the contacts at the base of the column...
John
Old Jun 13, 2008 | 11:25 AM
Axle/Gears: 3.08
I had the signal stick replaced on my '89 Jimmy (same type of stick) and it didn't even cost very much, and wow did it make a big difference in appearance!!!! It's now the only thing that looks and works like new on the whole vehicle!
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
