is this a common car combo?
Old Sep 23, 2008 | 02:50 PM
chattersonm's Avatar
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
ned rpo help
even though most of these are probably stock options i want to know what they mean.
ar9
b9k
dx5
d35
d7h
e57
e72
e92
ga3
ga4
gu6
j50
k61
mb1
mm5
na5
pc5
po6
p20
um7
ups
u79
van
vk3
v73
yt9
1ay
19b
19i
19q
19a
thats all the ones that i dont know
some of them might be wrong cause i have very poor handwriting lol.
but for now i have to go to work, i will be back later if anyone knows any of these
Old Sep 23, 2008 | 04:42 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: ned rpo help
I think almost all of those will be in the RPO decoder on the home page of TGO. IF you dont do that i use this once in a while http://www.c2e.info/rpocodes/
Old Sep 23, 2008 | 09:42 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
Re: ned rpo help
thx alot lol, i couldnt find anyother complete lists
Old Sep 24, 2008 | 08:32 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: ned rpo help
IF you come up empty, try using Goolge or yahoo, then typing the RPO you want information on then RPO in the search,,, for example "RPO 19a"
If there is information on it It will spit back to you some links to look at.
BTW the 19Q, 19A, 19I & 19B are all BLACK somethings... usually Interior components...
Old Sep 24, 2008 | 09:43 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
Re: ned rpo help
lol i was trying to find out what color my car was originally, so that i could re-paint it. but i cant tell if it was black or gunmetal grey because it has both of the numbers for the paint and maybe it was both idk. or maybe one is interior. lol
Old Sep 24, 2008 | 11:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: ned rpo help
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
B9K : ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY
DX5 : STRIPE, 3 SIDE
D35 : MIRROR, OUTSIDE REAR VIEW
D7H : GEAR, SPEEDO DRIVEN
E57 : ?
E72 : BODY LENGTH, INCR I8 INCH
E92 : ?
GA3 : ?
GA4 : ?
GU6 : AXLE REAR, 3.42 RATIO
J50 : BRAKE SYSTEM, POWER
K61 : GENERATOR, 97 AMP
MB1 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
PC5 : WHEEL, 15 X 7, STEEL, STYLED
PO6: ?
P20: ?
UM7 : RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR
UPS : ?
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
1AY : Stock Orders Processing Option (DEALER ORDERED CAR)
19B : TRIM COMBINATION, CLOTH, BLACK (B) (91)
19I : INTERIOR TRIM, BLACK (I) (91)
19Q : MOLDING COLOR (BLACK)
19A : STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK******
Old Sep 25, 2008 | 01:21 AM
Engine: 2.8 v6 MPFI
Transmission: LB8
Re: ned rpo help
E57 : ?
E92 : ?
GA3 : ?
GA4 : ?
PO6: ?
P20: ?
UPS : ?
thx lol
Old Oct 5, 2008 | 06:57 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: ned rpo help
Have you figured it out yet?
At the bottom of the RPO label it will have the paint codes. It will say "WA-" and then have an "L" and four digits and a "U" and four digits .. upper and lower. The digits will be the same if the car was all one color, or different if it was 2-tone. With those numbers and the make and year any bodyshop supply store can look it up for you.
Old Oct 10, 2008 | 09:48 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: ned rpo help
A couple more . . .
PO6 - couldn't find. However, P06 is for Wheel Trim Discs
P20 - Styled Wheel Hubcaps
UPS - also couldn't find. However, UP5 is for Radio, AM Stereo - FM Stereo - WX, Seek/Scan, Auto Rev
No luck on the others.
Old Oct 11, 2008 | 07:38 PM
okfoz's Avatar
Re: ned rpo help
E57 - BODY EQUIPMENT FORWARD CONTROL, GRUMMIN-OLSON, STURGIS, MI
E92 - DOOR DYNAMIC SIDE IMPACT - DELETE
GA3 - FLEET INCENTIVE ALYESKA PIPELINE COMPANY (TRK CKGMLST)
GA4 - FLEET INCENTIVE PERFORMANCE CONTRACTING GROUP (H/K/U/W-TRK CKGST)
UPS - FLEET SALES UNITED PARCEL
Some of those do not add up...
John
Old Oct 23, 2008 | 06:27 AM
Engine: 2.8 v6 MPFI
Transmission: LB8
41u - primary color, extrior, black
84L - secondary color exterior, hawaiian orchid
just wanted to know what one looked like because i guess thats what my 1986 sc came factory with and it is currently all red...lol. someone painted it i guess
Old Oct 23, 2008 | 08:13 AM
Engine: 2.8 v6 MPFI
Transmission: LB8
Re: ned rpo help
here are some pictures if that will help lol
the confusing this is that the 84L code is for hawiian orchid but my paint color says black exterior main and medium grey secondary right under it... lol
Attached Thumbnails is this a common car combo?-car-rpos.jpg   is this a common car combo?-car-rpo2.jpg   is this a common car combo?-l_5c695b8cf6efa4431b3fa0de69113edd.jpg
Old Oct 23, 2008 | 09:03 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: ned rpo help
Going by the paint code "WA" numbers at the bottom of your SPID give this
WA - U8555 Black (Code 41) - Upper color
WA - L7782 Gunmetal Metallic (Code 84) - Lower color
One question does the VIN on the label match your car's VIN. The reason i ask is to make sure you have the correct console top and SPID.
Old Oct 23, 2008 | 09:55 AM
okfoz's Avatar
Re: is this a common car combo?
I think you might need another RPO finder, here are some colors that I found...
84L DK HUNT CLUB RED MET (93)
84L HAWAIIAN ORCHID (96)
84L CORDOBA RED (97)
84L BRITISH TELECOM GREY, OPEL (99)
84L YELLOW (01) (SATURN)
84L OPERA RED GLASS (03)
41U BLACK (02)
41U ARINOS GREEN MET (BRAZIL) (02)
41U GREEN MET (CATERA)(02)
41U BLUISH BLACK 3, (02), HOLDEN
Going back to 1986 the colors were actually...
41U - BLACK
84L Medium Gray Metallic
It is hard to say actually how rare the combo is... I think it might look pretty good in Black/Charcoal...
it goes to show you that they often use the same code for several colors, or different options...
John
Old Oct 23, 2008 | 04:44 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
41U BLACK (02)
41U - BLACK
John
yea it is kinda weird but i just need to find someone with the same rpo codes that didnt have a repainted car xD
Old Oct 24, 2008 | 01:39 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: ned rpo help
[QUOTE=chattersonm;3896870]... cause i have very poor handwriting lol.
QUOTE]
Originally Posted by chattersonm
thx alot lol...
... or maybe one is interior. lol
thx lol
... and it is currently all red...lol.
lol
That's a lot of LOLing. We get that you're good natured... you don't need to lean on the LOL crutch! It makes me picture you as being bouncing off the walls insane. I'm not trying to be a jerk. It just stood out to me and I couldn't help but point it out, and it's impossible to do so with tact... so actually that probably does mean i'm being a jerk.
Old Oct 24, 2008 | 09:56 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
Re: ned rpo help
[quote=JeremyNYR;3927654]
QUOTE]
i honestly never "lol" its just kind of a habit when i am on the computer to use it cause it just feels like it completes my sentences. i was about to use it there to. and there..
Old Oct 26, 2008 | 01:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Re: ned rpo help
hey, i'm glad you didn't take offense. I catch myself doing the same kind of thing pretty often. I just happened to notice you do it a couple times in one post and then i looked back through the post and realized it was an epidemic!
Old Oct 26, 2008 | 03:07 PM
okfoz's Avatar
Re: ned rpo help
We all have our crutches and habits... I personally overuse the ellipsis... I think you might be hard pressed to actually find a handful of meaningful responses that I do not use the three dots... < there I go again ...
John
Old Oct 27, 2008 | 10:27 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Re: ned rpo help
John
I'm a major 3 dot offender myself...
Old Oct 27, 2008 | 10:56 AM
Engine: 2.8 v6 MPFI
Transmission: LB8
i try to think that the 3 dot thing just makes it look like you are sad...or kinda blah, so i try not to use it unless i really have to.
but in anycase, does anyone have a picture of a black sport coupe with medium gray second color. cause i want to see what it looks like before i really decide its what i want for my car.
Old Oct 27, 2008 | 11:44 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Re: ned rpo help
Equally guilty myself...lol!
Ghettobird52
Jul 5, 2024 11:18 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
