HELP! whare can i order a right axle at?
Old Feb 10, 2009 | 04:18 PM
redfbody's Avatar
I need a right side axle and bearing for my 88 Iroc that i bought.The axle is bent. Who makes those? Its a 10 bolt .273 posi 7 5/8 ring gear. I cant find one anywhere!!!
Thanks Matt
Old Feb 10, 2009 | 04:57 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: HELP! whare can i order a right axle at?
Thanks Matt
i got one..... intersted??
Old Feb 10, 2009 | 05:09 PM
89RS_82Z's Avatar
PICS
out of a low (60,000) mile car to
26 spline (82-89 1/2)
Old Feb 10, 2009 | 08:08 PM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
Hope you find the axle, how did you know it was bent? Did you have any vibrations while driving it? If so what rpms?
Mike
Old Feb 11, 2009 | 05:18 AM
redfbody's Avatar
Well there was a noise coming from the rear while driving but there was no vibration, put it up on the rack at work (Sears Auto) and put in drive and spun the rear wheels you can see the wheel wabble back and forth and you can here the noise. To be sure it was not just the wheel i took the wheel of the car and put it on the spin balancer spun it up and stood back to see of it was the wheel that was warped but it wasnt it spun nicely so it has to be the axle shaft and bearing.I had the same thing happen on a 2003 Must@** GT so this aint my first rodeo on axles.
Old Feb 11, 2009 | 08:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If you have the coin buy a new set from Strange Moser or curry.
Also put in new bearings and seals ..
Old Feb 11, 2009 | 09:17 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Not sure if they are available new. I would try a junkyard.
Here are some part numbers
1982 - 1988 RR axel (disc BRK) 22515440
1982 - 1988 RR axel (DRUM BRK) 22515441
1989 SHAFT RR axel (J50 & J41 or J42) 22515441
1990 - 1992 YO3 (exc J65) 26031251
1990 - 1992 (YO3, J65) 26031252
I KNOW that the B&W 9 bolt used a different shaft on the right & left as one was shorter, I assumed that the 10 bolt was the same. Apparently not as I did not find a reference to another shaft...
John
Old Feb 11, 2009 | 09:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I recently purchased new Moser axles from Summit (The 10-bolt axles are the same length). GM has discontinued them.
MSR-A102604 C Clip Axles $239.95
MSR-8254 Wheel Studs 12mm x 1 1/2 $19.95
Shop to press in the studs $20 or so.
Should anyone lack experience with bearings/seals, check the following sticky:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Feb 25, 2009 | 06:54 PM
89RS_82Z's Avatar
you still need the axle???
Old Feb 25, 2009 | 06:57 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
I have more axles than you can shake a stick at, and I'm cheap how many do you need?
Fireslash
Apr 11, 2016 06:43 PM
cheesehomer
Dec 31, 2015 08:48 AM
usafirebird
Sep 29, 2015 11:58 PM
Bigold4x4
Sep 28, 2015 05:21 PM
