Two Q's about interior lights
Car: 85 Z28
1. Did any Camaro's come with a rear light that illuminated the inside of the hatch area? If so, could someone post a picture of where this light is located? It would be really handy have a dome light for the back of the car, either when the doors were opened and/or when the hatch was opened. Was this ever an option?
2. Did any Camaro's come with a light for the inside of the center console compartment between the seats? On my 89 Vette, there is a light in the lid that comes on when you open the lid. Did Camaro's have a similar light in the lid or inside the compartment?
Car: 1986 Z28
Engine: 305 5.0L
Re: Two Q's about interior lights
cant figer out flash on the camara but my 86 z28 has hatch light right underneath hatch lid where it connects. if no one else take a pic i will in the morning.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
https://www.thirdgen.org/forums/elec...-controls.html
Here is a pic of the one i made, it seems to be going over cool with members on here, its the same instructions as the ash trey light conversion but its in your center console and you tap into the shifter light for the power to it, if you need any help ask on here and i will post up as much info as i can
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
89, cool little mod. Did you come in through the clock stem hole?
JamesC
Car: 85 Z28
89 - I saw your thread earlier and thought it looked really nice as well. I hoped that maybe the factory had also put a light in the same hole as you used for your LED. It's a pain to dig my garage door opener out of the dark console at night.
https://www.thirdgen.org/forums/inte...hose-sexy.html
Apparently some cars weren't equipped with the rear light just as some didn't have the front kick panel lights. Strange.
JamesC
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
If I'm not mistaken the dome light shines directly into the console lid, so why can't you see?
I replaced my dome light bulb with this.
http://www.superbrightleds.com/specs/universalPCB.htm
My kick panel bulbs and license plate bulbs with these (second bulb down)
http://www.superbrightleds.com/specs...specsHP360.htm
Note: I havent fitted these into the license plate sockets
With the 12-LED dome light and 9-LED/ea. kick panel bulbs my interior is brighter than an amusement parks spotlights. Now add a PCB (12-LED) to the rear and OMG you'll go blind...haha. I plan to see if I can fit a PCB led kit into the rear hatch area. Size matters when it comes to LED's as they are usually bigger than their stock counterparts.
Car: 85 Z28
For the console lid, it would be nice to have a light that comes on when the lid is open or when the dash lights are on. I could open the car door, but it would be nice not to have to do that. Admittedly, this isn't the world's biggest problem, but it's a minor annoyance that I would like to fix.
thats why i put mine in there got tired of turning on the dome light to see my opener
ambainb
Apr 25, 2016 09:21 PM
The_Phoenix
Feb 4, 2016 07:10 AM
