buildsheet?
Old May 14, 2009 | 11:38 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
buildsheet?
i have an 83 camaro so i dont have rpo codes... and i was told that i could find a build sheet somewhere and i was wondering where this maybe....
Old May 15, 2009 | 04:58 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: buildsheet?
They can be...anywhere actually. But they're often under the carpet, under a rear seat or a front seat or even behind a door panel. On 2nd Gens, some people found it in the dashboard, behind the rear seats back, and a lot of cars had them at the top of the gas tank. On my '79, it was under the PS rear seat but it was in pieces.
Expect not to find it, or in very bad/unreadable condition.
If you don't find it, ask PHS for the original documentation about your car. They don't have the build sheets though.
Old May 15, 2009 | 12:31 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: buildsheet?
SolarGold made a good point that the build sheet can be found just about anywhere. And other the other hand there may not have been one left in your car. There is a trim tag located on the top center of the radiator support. It will give you basic information such as color(interior/exterior),trim type/style,t-top code(CC1) along with some other codes. I have a '83 Z28 and maybe able to help some.
Old May 15, 2009 | 05:14 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: buildsheet?
On my 83, I found it under the drivers front seat, not enough of it though to get all the codes, just some, and the price and some other things. Still on the hunt for a bonus one under the carpet, not holding my breath though.
Old May 16, 2009 | 12:19 AM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: buildsheet?
thanks guys anyway to tell stuff from the vin?
Old May 16, 2009 | 01:32 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: buildsheet?
The VIN will only tell you basics such as body style,engine and build plant. The Sport Coupe/Z28 share the same model designator but the Berlinetta's is unique. The VIN eighth digit is for the engine (if originally a V8 LG4 - "H" it could be a SC,Z28 or Berlinetta , the only true way to know if she were a Z28 it would be a "7" - L69 or "S" - LU5)
Old May 16, 2009 | 09:29 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: buildsheet?
well i know its a berlinletta.... but other than not i know nothing esle.....
Old May 17, 2009 | 11:08 AM
dellman83Z's Avatar
Re: buildsheet?
I basically just measured things out or just looked for ways to identify what I got. I measured the sway bars and the diameter matched the F41 specs. I found the axle code and determined I had the G92 rear end with 3.23 gears, along with the obvious J65/G80 rear disc and posi. I also have the custom interior, its thick carpet and the sides of the console are carpeted. I also have a light grey interior, almost white, which I like because its very rare I see a third gen with this interior. Factory t tops can be identified by a CC1 code on the radiator core support. There are also the paint codes there along with what type interior you got. I have a Z28, so I think some things you may not have with the berlinetta. I hope this helps you out.
Old May 17, 2009 | 06:35 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: buildsheet?
Dellman you Z28 sounds very similar to mine. Those are good points about that you made in doing a search on the early cars. BigJon your Berlinetta would have come with the custom interior and the deluxe luggage compartment(RPO-B48) standard. Again the trim tag on the radiator support will give you trim codes/color/style.
Old May 17, 2009 | 07:35 PM
TA84QC's Avatar
Car: TA
Re: buildsheet?
You will find it under the central consol under the arm rest ... All the codes are there and they will tell you all you want from your car ... very usefull for the restoration ... Good luck!
Old May 17, 2009 | 07:39 PM
JT's Avatar
JT
Community Administrator
Re: buildsheet?
I don't believe the original poster's 1983 will have that sticker as I don't believe it was yet implemented.
Old May 17, 2009 | 10:19 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: buildsheet?
i believe that rpo stickers came out in 85... my thing is nothing inside the car is stock... so i was wondering what it did come with i will have to check the gears and stuff and see what i have
Old May 18, 2009 | 09:18 AM
dellman83Z's Avatar
Re: buildsheet?
I saw that when posting on how similar our cars are. Its nice to see actually. Mine does not have power anything, but at least does have A/C. It was really rare to have the G92 for our year. I think id I was back in that day, I may have ordered it exactly the way it is now.
Old May 18, 2009 | 03:09 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: buildsheet?
ya nothing in mine is power either wish i like i do have a/c but i brought a block off plate to remove it
Old May 18, 2009 | 03:19 PM
Scooby Doo's Avatar
Car: 92 Trans Am Convertible
Engine: 5.0L
Re: buildsheet?
I was dissappionted when I did not find one when I replaced my carpet, but then later on when I was having the car painted they found one behind the door panel.
It was not near as informative as the RPO sticker.
Old May 18, 2009 | 03:23 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: buildsheet?
i am gonna have tolook under my carpet or door panels i guess
Old May 18, 2009 | 04:10 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: buildsheet?
It started sometime during the 1984 Model Year. I have the RPO SPID sticker in my car. I don't believe cars have it earlier than that. Maybe late 83 MY if you are lucky but I am hedging my bets that 84 was the first year for the sticker in the console and later the rear compartment.
Old May 18, 2009 | 05:34 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: buildsheet?
Dellman in researching my Z it is interesting how few cars were ordered with G92. Whoever ordered my car checked off everything but the LS seats and the special Camaro interior.
L695speed I would think it was sometime in the '84 model run. My '83 is a late June build and didn't have a SPID. The console lid was split on top and the plastic was cracked making me think it was the original.
BigJon that's somewhat unusual for a Berlinetta not to at least have power windows. Does she have the 2.8 or the 305?
Old May 18, 2009 | 05:35 PM
JT's Avatar
JT
Re: buildsheet?
I got the same (trim buildsheet) for my 1992 Trans AM Convertible (mine is bright red, too, by the way). Mine was up behind the passenger instrument panel, around the HVAC unit. That is not the master buildsheet. The was one of few "buildsheets" in the car, though.
Old May 19, 2009 | 12:36 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: buildsheet?
when it says LB9 does that mean 081 heads? i have to order them from a factory depo and they want the option code - LB9 is the best i could do for those heads for a 90 camaro - anyone know?
Old May 19, 2009 | 09:34 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: buildsheet?
Does anyone know if you can get a rpo sheet reprinted from the dealer? My 87 TA came without the sticker (you can see where it was at one point) in the console and I'd like to know what options the car came with before tearing into the thing too much.
Old May 21, 2009 | 01:56 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: buildsheet?
Jon like I told you and many other people have in this thread they can be anywhere and everywhere in your car, so far there are two with my car, the original owner gave me the one he had and when I was pulling the carpet up under the back seats I found one too, altough not in the greatest shape you still could read some of it. The best thing I can recomend is start looking anywhere, take the seats out look under the carpet behind the dash in the door panels...etc.
So when ya wanna get to work I'll come right over...we gotta move your car BTW!
grassyflats
Feb 11, 2010 09:52 PM
scottmoyer
Jan 21, 2010 05:05 PM
wildjeff
Jun 29, 2006 12:59 AM
HH83L69
Jul 11, 2005 06:34 AM
Randy82WS7
Mar 22, 2004 11:02 AM
