1989 Iroc on ebay... repaint?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
Door decals aren't right... think it's a repaint?
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: 1989 Iroc on ebay... repaint?
More than likely. They were at the back of the door on an '89, right?
Man, that was hard to read with all those caps!!
Good luck with that, buddy! I think the seller has been smoking a little bit of the first part of his ebay seller ID!!
OH YEA THE RESERVE IS 10G'S
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
repaint..yes. there would be no reason to change the decal otherwise. and dont forget the '90, they where on the rear also
Yeah, an '89 IROC should have the IROC stickers on the back of the door so most likely it's been repainted. I definitely don't think this car's going anywhere for $10k. It's a lower mileage car but I think the number of aftermarket parts actually hurts the value of the car. I'm not sure if it would sell with a $7500 reserve.
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
Low mileage or not, that's a $3,500 car IMO.
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
That car don't look too bad- On the outside that is. . .I think the dash looks cheesy. . . And hmmmmmm @ no picture of the engine whatsoever. . .
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
yeah i was wondering why no engine pics! One other thing that struck me was when he stated the car runs a little rough with the cold start injector....doesn't it send a red flag there. From 1988 and up, all tpi engines (assuming that iroc has it), were eliminated from the "ninth injector"....85-87 had them. I don't believe that TBI engines had cold start injectors either... So who knows what's in this car!
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Sure things . . .
- It's an '89 - VIN's 10th digit is a "K"
- The decals are incorrect for an '89. They have been altered or car has been repainted and errored in the decals.
- It's has the L98 350 TPI (or did originally) - VIN's eigth digit is an "8".
- It's an IROC because it has the 350 TPI in the VIN.
- The '89 L98 did not have a cold start injector.
And my personal opinion is that due to the type of mods, this car isn't likely going to fetch that much $$$ unless that one customer out there, who wants exactly what that car has, he has shows up with a wad of cash burning a hole in his pocket. But I could be wrong.
Car: 1991 Trans Am
A couple things don't add up. The seller is claiming the car has been stored since 1992 (owned it 19 years and drove it only the first 2 years they owned it), it was taken out of storage in 2003 and drivin 47 miles then put back into storage. The part that doesn't add up here is the fender replacement for someone stopping short on them in 1999, while the car was supposedly in storage?
Car: '92 Formula, '92 TA, '91 ZR-1
Engine: 350, 305, LT-5
That cheese nugget shifter looks like something out of a late seventies Car Craft magazine feature car.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
with the new dakota gauges there is no way to prove it only has 52k miles might as well not even post the mileage now its worthless
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
According to the window sticker its well equiped (this young guys eyes are still pretty sharp
) it also has:
Power Disc Front & Rear brakes, Limited Slip Differential, Power Antenna, Power Driver's Seat, Power Mirror. . .Well, to sum up IROC-Z Preffered Equipment Group #1.
If it weren't for the dash and the unknown engine I'd be intrested in it.
) it also has:Power Disc Front & Rear brakes, Limited Slip Differential, Power Antenna, Power Driver's Seat, Power Mirror. . .Well, to sum up IROC-Z Preffered Equipment Group #1.
Sure things . . .
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
I think the car is trying to tell you something. Its winking. ;-) Its got one headlight cover on...but not the other.
mustangman65_79
Aug 11, 2015 03:17 PM
