Crossfire roll call!
Transmission: World Class T-5
Axle/Gears: BW 3.45
How many Crossfires do we have on this board?
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Re: Crossfire roll call!
my 1982 TA was originally a Crossfire car...does that count? I'd like to return it back to it's original setup whenever I can get/find all the CFI parts.
Axle/Gears: BW 3.45
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Mines still ticking at 79K miles,But with a BAD idle dang CrossWIRE/Catchfire
Axle/Gears: BW 3.45
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Both of my '82 Trans Ams were CFI. Previous owners converted them over to carb. I plan to make the Recaro T/A CFI again.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Chazman the difference I really feel since the change is cruising 65 - 70mph. The steel DS was the source of the vibration I was experiencing. She seems to rev a little smoother/quicker from a start but then that could be my imagination. I would think a manual car with a lightweight flywheel and JG1 DS could have a real world difference
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
I have an 82 Z that I plan to have back on the road pretty soon. I also have an entire running 83 Z for parts if anyone needs something.
Car: 1982 Trans Am
Engine: SBC 400
yah, but at the prices some people want you would think they were made with gold. For a system that has such a bad rep, people want more money than what I'm willing to spend. I really need to just find a good donor car...see, everything in my engine bay is stripped of any and all CFI equipment, including everything else that was stock. It makes it a real PITA to piece it all back together.
Car: 83 T/A, 83 S.C., 86 S.C. & IROC
Engine: 305 CFI &TPI
Transmission: 4L60E, 700R4
Axle/Gears: 3.23, 2.73
1983 LU5 Trans Am. It's still sitting in the garage with the interior out so it could dry out. It's next on the project list after I get my '86 sports coupe converted over to TPI with the 411 computer. I'm planning on keeping the TA as a crossfire car.
Car: 1983 Camaro Z28
Engine: 350 CFI
Transmission: 700R4 automatic
Axle/Gears: 3.08?
I've got a 1983 Z-28. The previous owner swapped the CFI setup onto a rebuilt 350 block from a 94 G-van and did an okay job of it. Still confused as to WHY he did it, hahaha, but its running great right now.
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Original owner of 82 CrossFire Camaro. Still all original for the major part and interior. It is showing its age in a few areas but is generally in good shape. Was always my second car and has lived most of its life in a garage. But it has also seen rain and snow on some cross county trips.
White exterior with the Dark Claret interior. 44K+ on the clock but the speedo cable was broke at the cruise control for a couple of years, so it most likely has 50-52K on it.
The second set of Eagle GTs is now over 20 years old and probably has less than 10K on them. Time to replace thought **** now if Goodyear still made the tire it would be even better.
Dave
Dave
Axle/Gears: BW 3.45
I can't tell how many times I've been at cruise night with the hood open, and have someone walking by stop and say, " Hey, that's Crossfire"
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
83 DT500 T/A Pace car here......in rough shape........but I got it! And I know where an Indy 500 C/F pace car is in a bone yard Need parts? LOL
I don't have them anymore, But I had a '82 Z28 pace car with a crossfire, and a loaded with every option '83 Z28 crossfire, the '83 ran much better than the '82, probably because of the 700r4, I parted the '83, because it was hit in the rear, I was going to use the rear disc axle on the pace car, but my '87 Convertible came along so the '82 went, and I sold all the parts off for the '83, I did keep the Dynomax cat back off it and put it on my '87, The motor and trans I sold to guy who put them in a '48 Chevy. Chris
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
my '82 was LG4/t-10 when i bought it in 1990,but in
1994 swapped in an'84 vette"L83"crossfire 350-was
dissapointed with the stock performance,so modified
and ported the manifold,ported the heads,added a 1/4"
lidspacer-those mods woke up the L83 bigtime
since 1994 has been totally reliable and running great.
All the manifold work (welding and porting)was a bit
of an ordeal,but would do it all over again if i end up
with another C/F third
Axle/Gears: BW 3.45
Car: '82 z28
Engine: L83 5.7
the lidspacer was made out of a piece of 1/4" thick
aluminum plate -just traced it out using a spare gasket,
used an electric sabre saw to cut it out
the spacer was added because i wanted more clearance
above the enlarged runner intakes(more plenum
volume is good too
volume is good too
) Re: Crossfire roll call!
Not a lot really given the numbers made.I reckon that the number of people in the states that still have a running system would be less than 500
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
I have 2, 1 is a bone stock 83 z28, the other is an 84 H.O. which is in the middle of a swap to crossfire.... Why? because I had an 83 CFI that hda the rear end torn off by a F--king Ford pick up, the camaro drove home and the ford was towed. we found a replacement and had enough to buy an 84 fixer with the insurence. so the 84 now has CFI from an 84 corvette
My wife still misses he baby there is a big differince between bringing a dead car to life and writing the check. but that is a long story
My wife still misses he baby there is a big differince between bringing a dead car to life and writing the check. but that is a long story Thread Starter
Axle/Gears: BW 3.45
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Car: 1983 z28 Camaro
Engine: 305 crossfire injection
Car: '82 Z28 LU5
Engine: LU5 (LM7 in the NEAR futue)
Transmission: TH350
I hate to revive an old thread, but...
My 82 Z is an LU5 car. Im the... oh jeezzz... 8th, 9th, 10th owner? Im pretty sure 10th. Thats not good for a car thats only 28 years old, is it? LOL in case anyone wanted to know, Ive pulled the set-up off and am selling it. PM me if interested.
Car: 82 Z28 .... 74 Nova
Engine: 350 Crossfire Injection....383 Sbc
Transmission: th350 ... 700r4
Axle/Gears: 2:73 Posi ... 3:42 Posi
82 Z28 350 Crossfire
Running Strong
Running Strong
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
'83 Recaro edition Black and Gold T/A. About 130,000 miles. Rust free with restoration in process.
Mostly stock - even about 50% of paint is original.
Car: 1983 Pontiac Trans Am Daytona 500.
Engine: LU5 Crossfire Injected 305
Transmission: 700R4 with Shift Kit
Axle/Gears: 3.73 Posi.
83' Daytona LU5 Crossfire here. and Basking in it's glory.
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I have a 1983 Trans Am Daytona 500 CFI with 62,000 miles and the KARR still runs like a tiger
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
'83 Daytona hardtop with crossfire. My son is 13 now so I guess we better start the restoration soon.
I guess the 1983 Daytona 500s had the better Crossfires
It's been a while since I've had an English class, but I DO know you can't use "better" and "crossfire" in the same sentence.
Engine: LU5 305 CFI
This has been debated since CFI was introduced in '82. The same debate occured about 26 years earlier when Rochester FI was introduced. When the issues with the intake and TBI units are handled and the motor properly tuned a CFI has been proven to run very well.
Hello, not new to forums but just got a 1983 Z28 camaro CFI. it is in replacement to my no money 79 project, this 83 is complete with original parts, and a new crate motor, he just got a crate motor for the bottom end, the CFI and intake/TBI/ wiring is all there, basically it is a big Lego kit car, with plenty of goodies,
im glad to see a good productive forum to go to though.
kevin~
kevin~
Car: 1983 z28 lu5/350
Engine: lu5/350
1983 z/28 crossfire black and gold with saddle interior has 010 350 4 bolt block with a brand new lu5 cam with l69 heads, rebusing the tb's got brand new 84 corvette injectors all running on factory lu5 computer, 700r4-3.23. 235-60x15 fronts and 275-60x15 rears.and the hood flaps still open when you get on it.
Update: The Recaro T/A has been up and running with CFI for about a month now. Put about 500 miles on it so far. Ended up having to rebuild the engine. It got a few upgrades like a L69 cam, exhaust manifolds, 3.5" oval Y-pipe, and DynoMax cat back exhaust system. I did mild porting on the heads/intake and gasket matched the ports. The transmission is also out of an L69 car so it shifts at 6K instead of 5K RPM. It goes pretty good! MUCH stronger than my LG4 '84 T/A.
Axle/Gears: BW 3.45
I've also added L69 exhaust manifolds which exit out of a 3" exhaust. Makes me feel like the 2.93 gear has got to go. I'm thinking about a 3.42.
