View Poll Results: what's your option code level?
16.67%
16.67%
66.67%
Voters: 6. You may not vote on this poll
what option code IROC-Z do you have?
Old Jan 28, 2010 | 09:08 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
i have option #3 on my 87 IROC-Z. yep im bored. and there was only #1,#2,#3 option code levels correct?
Old Jan 28, 2010 | 09:21 PM
Drew's Avatar
Re: what option code IROC-Z do you have?
Sort of. Depending on the year there were up to 4 option levels.
Old Jan 28, 2010 | 09:35 PM
Engine: 305TPI
what was included in level 4? 1le?
Old Jan 28, 2010 | 09:39 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
My 1LE was
option code 01 1SA
Aero package #4 WW4
Old Jan 28, 2010 | 10:11 PM
Drew's Avatar
https://www.thirdgen.org/forums/hist...ckage-4-a.html
But keep in mind 1SD didn't exist every year. Take 1987 for example, 1SC was the hotdog package. Typically 1LE's were strippers, hence 1SA.
Old Jan 28, 2010 | 10:17 PM
Krik's Avatar
Engine: 5.7 TPI
I'm driving a 20 year old stripper!
Old Jan 28, 2010 | 10:27 PM
Engine: 305TPI
thanks i looked at the thread earlier and thats where i got 1le in option #4 from. is there a thread telling about what all the rpo codes mean?
Old Jan 28, 2010 | 10:31 PM
Drew's Avatar
Probably not, since it changes by year and almost universally no one on these forums is very well versed in more then a couple years. For example in that thread it was do-able cause we knew the subject and had the resources available. Probably the closest to a complete resource would be the Camaro White Book, but for what's a $12.95 book, I doubt it's worth anyones time to type it all out.
To add additional confusion, the option packages meant different things on different models.
Old Jan 28, 2010 | 10:38 PM
Drew's Avatar
I should clarify... 1SD existed in 87, but not on the Irocz
Old Jan 28, 2010 | 10:55 PM
Engine: 305TPI
ok thanks anyway so what is 1sc?
Old Jan 28, 2010 | 11:03 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i can't comment on that with out getting myself in trouble
Old Jan 29, 2010 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jan 29, 2010 | 01:38 PM
Krik's Avatar
Engine: 5.7 TPI
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
scottmoyer
Sep 7, 2015 07:06 PM
