190 hp or 215? 305 tpi
Old 03-07-2010, 07:24 PM
1990s10's Avatar
is there anything in the casting numbers of the heads or the engine that will tell me what HP engine i have or does this have to do with what transmission is bolted to it? i do know its a roller cam engine if this makes a difference
Old 03-07-2010, 07:41 PM
AmorgetRS's Avatar
Re: 190 hp or 215? 305 tpi
Nothing different with the heads or engines. Where are you getting these HP ratings from?
Old 03-07-2010, 07:45 PM
1990s10's Avatar
if you look on this site for an 87 firebird, there is a list of different engines and it tell their stock hp
Old 03-07-2010, 07:49 PM
AmorgetRS's Avatar
Ah, yeah. Yes, based on the transmission. The only thing that may of been different between the two was a different cam, but I am not even 50% sure on that...
Old 03-07-2010, 07:57 PM
1990s10's Avatar
my engine is a true roller cam
Old 03-07-2010, 08:08 PM
AmorgetRS's Avatar
That makes no difference. They all went to a roller cam in 87.
Old 03-08-2010, 12:45 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 1990s10!!
Is this the same engine as your other post in the History/Restoration forum, with an engine code of V0226SFW, that was mated to an auto transmission?? In 1987 the auto transmissioned 305's had 190 HP!!
Old 03-10-2010, 10:24 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
My understanding is that the 305 mated to a manual tranny had 215 hp. If mated to the automatic tranny, it had 190. The "peanut cam "was changed for a more aggressive cam for the manual combo. The gtasourcepage.com lists the same numbers for GTAs.
Old 03-11-2010, 12:09 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Yes that is correct. I know for 88 and 89 LB9s that were mated to a T5 recieved the L98 cam while those mated to a 700R4 got the peanut cam. I'm not sure about other years though.
Old 03-15-2010, 05:35 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
i don't really know about that...but if you really wanna be positiv no doubts, i would have it dynoed...I think 190, but only because of what I've read.
Orr89RocZ
04-25-2016 08:28 AM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 190 hp or 215? 305 tpi
