GTA emblem question
Old Apr 18, 2010 | 12:18 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
GTA emblem question
Did all '87 flame red GTAs come with bright red emblems? Mine did, and I'm trying to decide if I want to replace them with the same color or if I want to go with the matching flame red ones like on the 88+ models. I would really like to keep it correct for the year, but I know the matching ones would sure look better.
Old Apr 19, 2010 | 10:34 AM
92GTA's Avatar
Re: GTA emblem question
I can't answer your question but if you know they are original then by all means replace them with ones that are the same! Matching color might look better but it's not original. I for one like factory oddities, my 92 is full of them lol!
Old Apr 19, 2010 | 11:03 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
No, not all Flame Red '87 GTAs came with Bright Red emblems. Either style would be considered correct for that year. If you changed them, no one but you would know. As for me personally, I would want my car to be original.
To date, I have not been able to uncover the reason for the differences in application, (plant usage, supply issues, quality control, etc.) No directive(s) from Pontiac regarding this have come to light that I have seen.
Old Apr 19, 2010 | 03:54 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Thanks guys.
Old Apr 21, 2010 | 08:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It may be a simple mistake in the factory. Or there may have been a time when the flame red was NA, so they simply substituted the red as they ran out of the Flame red, or possibly the person on the line simply grabbed the wrong set.
I suspect the plant simply ran out, or there was a problem with the flame red ones.
John
Old Apr 24, 2010 | 10:02 PM
Chet's Avatar
Car: GTA
FYI my flame red '88 GTA came with bright red emblems, so it wasn't just 87s...
If I ever repaint, I'll be getting matching emblems.
Old Apr 24, 2010 | 10:51 PM
yo soy el warg's Avatar
I've seen the "silver" and "charcoal" rocker emblems interchanged on camaros that I knew were factory originals, but were not correct for the cars. Nobody has any clue why?
Old Apr 26, 2010 | 09:31 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
OK, there you go.... the first person I've seen with an '88 that had Bright Red emblems. Thanks for posting this, Chet.
Seeing this info, it may have simply been an issue of the plant using what was readily available as the car was going down the line. I recall one of the '87 GTAs that AUTOWEEK used for testing test was Gunmetal and the car had Black emblems on it... that looked pretty cool in photos.
Again, Chet.... thanks for this.
69 Six Pack
Oct 5, 2015 07:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
