I think I found the real ones
Old Aug 29, 2011 | 01:51 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
When I bought my car the fog lights had been removed, and I've never ran across a set of OEM fogs for less than $50. So when I found these on an 86 in a juck yard for only $20 I snatched them up. Can somebody that has a set of OEM fog lights take a look at these and tell me if these are or aren't? Plus since I had the camera in hand I couldn't pass up the oppertunity to snap one of the car.
Attached Thumbnails I think I found the real ones-141_0653.jpg   I think I found the real ones-141_0655.jpg
Old Aug 29, 2011 | 03:57 PM
Drew's Avatar
Re: I think I found the real ones
Those are the real thing, yes.
Old Aug 29, 2011 | 05:31 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Wow what a lucky find! Congrats!
Old Aug 29, 2011 | 11:37 PM
puma1552's Avatar
Look good to me. Those things need some restoration though (hint: not plastic polish from Vatozone).
Old Aug 30, 2011 | 11:30 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Those are the factory fogs but the brackets are from a sport coupe.The Iroc/Z28 brackets are different
Old Aug 30, 2011 | 03:13 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Did sport coupes have angled glass, or was the glass flat like on the Trans-Am? It's been years since I saw a factory foglight SC, and I honestly can not remember.
Old Aug 30, 2011 | 03:55 PM
my82roc's Avatar
The fogs were exactly the same.Both had the angled glass.Its just the bracket thats different.
Old Aug 30, 2011 | 07:43 PM
Well that's a bummer they aren't true Z fogs but I'm still stoked that I got em and I'm gonna clean em up and rock em. When I pulled them off they were held on by only one bolt each but had two mounting holes in the bracket. I looked on the car where they were mounted and there was only one hole for the bolt to pass through.
Old Aug 30, 2011 | 08:07 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
What?
First if all, those are the correct brackets
Second, sport coupes didnt have fog lights
Old Aug 30, 2011 | 09:12 PM
my82roc's Avatar
Originally Posted by 58mark
What?
Those are not the correct brackets for a Z28/Iroc.Secondly sport coupes did indeed come with optional fog lights in 1986-87.The fog lights are exactly the same for sport coupe or Z28.Only difference is the bracket.Ive attached a pic of the Iroc/Z28 brackets.Notice the difference
Old Aug 30, 2011 | 09:16 PM
58mark's Avatar
Are you sure you don't mean the lt? I can't imagine where the sport coupe would mount fogs. Got a pic?
Old Aug 30, 2011 | 10:09 PM
coastiematt's Avatar
I thought I knew a good deal about 3rdgens... i have never heard of any car besides the Z's (iroc or z28's) having fog lights.
Old Aug 30, 2011 | 11:04 PM
Drew's Avatar
Fog lights were optional on the Sport Coupe and the LT. They used a typical Sport Coupe grill with openings for the lights.
Old Aug 31, 2011 | 06:45 AM
Gotta love it when people are so adamant that something does not exist. It's a pretty unusual option, mostly seen on the Sport Coupe convertibles. Way back in the early 90's when I got my sport coupe, there was another in town with the factory fog option. I liked the option so much, I went to the Chevy dealership and bought the fog grille. I think it was about $22. It's long since discontinued, unfortunately. Here's a pic of my grille. The grille is GM, the lights are not. I scored a set of SC mounts a few months back from another member that looked just like the ones in original post.
Old Aug 31, 2011 | 06:50 AM
58mark's Avatar
sounds like the OP is better off with what he has. I bet the SC mounts could fetch a higher price than the fairly common IROC mounts. sell them, and get what he needs
Old Aug 31, 2011 | 07:15 PM
my82roc's Avatar
The sport coupe fog light grille is the rare part.Ive pulled fogs off of several junkyard sport coupes and one LT camaro in the past.There used to be a silver SC with fogs not too far away from my house but I havent seen one for awhile
Old Sep 1, 2011 | 08:07 PM
And that is why I keep an open mind on things, cause just when you think you know a good bit, you find out something else. Thanks for the insight everyone. The car I pulled them off of did have the SC nose with the slits in it but the grill was long gone. Only hint of a grill ever being there were small pieces of plastic around the screws that used to hold it on.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
TrevinE
Sep 14, 2015 03:20 PM
earlpote
Sep 12, 2015 11:55 AM
dimented24x7
Sep 6, 2015 03:51 PM
rudolphschenker
Sep 4, 2015 02:41 AM
