Need help with vin and build date.
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Since comp nine went down I'm having trouble finding info on this car. Door sticker is gOne. Ints a 92 RS. Vin is 1G1FP23E8NL118482. If someone would help me out that would be great.
Re: Need help with vin and build date.
Are you looking for the SPID sticker? It will be located on the inside lid of the storage bin (left-rear driver side).
If the SPID is missing, you should be able to visit your local GM dealer and get the list of RPO codes since it's a 1992.
No trying to track down the actual build date of the car. SPid is missing though I believe. Someone has redone the interior at some point and it's gone. Any know how to tell by the last digits?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Try the drivers door,their should be a date on one of those stickers.
It's unreadable
My understanding is that information is also available at the GM dealership. I know David M (https://www.thirdgen.org/forums/member.php?u=5054) works for a dealership and can (or has) pull records that does have build dates. Might try contacting him if you don't go to a dealership.
