Last of the 3rd Gens
Car: 1992 Firebird
Engine: 305 TBI
I am one of those that like keeping their car original and have discussed that on various threads. I'm kind of glad I did now. My car is one of the very last 92 Birds built (build date of 8/92) and so it will be nice to be a original representation for people to see, and one for anyone restoring a 92 in the future. Although I would not consider my car a "benchmark" car, it does still have most of the original decal and stickers, date coded hoses and the wiring and hose routing are all original too. These will probably be helpful in years to come. People don't realize how hard it actually is to keep a car original, so I hope it pays off for someone in in the future. ps: does anyone know of the # of the last 92 Bird built or a way to find out what it is? thanks.
Re: Last of the 3rd Gens
August 27, 1992 was the last day for the ThirdGen Firebird and Camaro.
The last Firebird's VIN, according to David M, was 1G2FS23T3NL227568
Thread linked below about the last Firebird:
https://www.thirdgen.org/forums/hist...-firebird.html
Leonard has the last ThirdGen Camaro, which is also the very last ThirdGen built:
http://www.last1992camaro.com
Car: 1992 Firebird
Engine: 305 TBI
JT, thanks so much. I knew about the last Camaro, saw that thread before. I was curious as to the Birds and had never seen that thread. It looks like mine was farther away then I thought as mine is #225782, about 1500 before the last, probably built in the 1st or 2nd week of Aug. Still, it's one built in the last month. I will say this, that although mine is in no way rare, I have owned it 14 years and have never seen it's twin in person, including 3 years at STARS. Some don't like the 92's because of the gfx, but I'm glad I got one. Thanks again JT.
I believe if you contact a local GM dealer, they can provide you additional information, such as build dates, if you want to narrow down a date for your vehicle. I know David M, who works for a GM dealership, can do as such.
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
I been trying to get that info on my camaro dealer says they can't go pass 2000 at least in mi been getting the run around
For your 1988? You'll most likely have to contact GM Media Archive and pay a fee to get an invoice. That will include some dates on it. Link is below:
http://www.gmmediaarchive.com/
The GM dealers appear to only go back around 1990-1991 and newer, unless the car is Canadian.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
The store of the last 3rd gen was a neat read, i head about it before, but did not know all the details.
VIN: 1G2FS23T3NL227568
Year: 1992
Make: Pontiac
Model: Firebird
Style/Body: 2 Door Coupe
Engine: 3.1L V6 MFI
Country of Assembly: United States
07/03/1996 RICHMOND, VA Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
06/12/1997 RICHMOND, VA Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
05/28/1998 RICHMOND, VA Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/23/1999 GULF SHORES, AL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
09/08/1999 GULF SHORES, AL 112,000 Motor Vehicle Dept. TITLE (Title #:24871041)
12/29/1999 AL State Agency RIGHT FRONT IMPACT WITH A NON-BREAKAWAY SIGN (Case #:9121557)
Ouch! Moment of silence please...
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
haha wow and it was a POS v6 too
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Data on the last Firebird
RPO Description Matches
1SC PACKAGE-OPTION 03 (1SC) 18,423
1SZ PACKAGE OPTION- (1SZ) 21,331
19Q MOLDING COLOR,BLACK (19Q) 2,433
41U EXTERIOR COLOR,PRIMARY,BLACK (41U) 2,471
6XS COMPONENT FRT LH COMPUTER SEL SUP (6XS) SUSP(6XS) 12,126
7XS COMPONENT FRT RH COMPUTER SEL SUP (7XS) SUSP(7XS) 12,126
8UY SPRING-COMPTR SELECT RR LH SUSP(8UY) 16,468
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 11,377
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 11,405
829 SEAT BELT COLOR - MED DK GRAY (829) 11,405
9UY SPRING-COMPTR SELECT RR RH SUSP(9UY) 16,468
AAA Unknown 21,257
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 22,334
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 21,980
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 20,734
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 20,734
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 18,825
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 20,734
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84) 22,096
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1) 12,985
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 15,872
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 22,220
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 22,062
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4) 12,985
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7) 17,357
D3V GEAR-SPEEDOMETER DRIVEN (25513046) (D3V) 12,403
D8N SENSOR VEH SPD (10456088) (D8N) 19,151
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80) 19,212
E5Z ADAPTER - SPEEDO - DELETE 22,334
E9Z KEY - SPEEDO - DELETE 22,334
FE1 SUSPENSION SYSTEM,SOFT RIDE(USED WITH RS PACKAGE Y86) SOFT RIDE SUSP(FE1) 20,395
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 13,231
IPC TRIM,INTERIOR DESIGN (IPC) 21,980
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) 21,243
K60 GENERATOR,100 AMPERE 100 AMP(K60) 13,869
LH0 ENGINE,3.1L(3.1T),V6(EXPORT) 3.1T(LH0)(EXPORT) 13,859
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 19,979
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 19,979
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 20,205
N24 WHEEL,15X7(CAST ALUMINUM) AL WHL(N24) 14,319
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36) 21,278
QPH TIRE ALL- P215/65R15/N BL R/PE ST TL AL2 (9591591) TIRE(QPH) 20,395
T96 LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04) FRT FOG LP(T96) 18,323
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3) 22,334
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 9,061
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 22,334
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 22,334
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 22,334
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 16,875
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 20,779
W68 PACKAGE,FIREBIRD SPORT APPEARANCE APPEARANCE PKG(W68) 17,267
AAA Unknown 21,257
Must have been a sweet ride with the 3.1 and the soft ride suspension. Third Gen Firebirds really went out in style. At least Leonard was able to do the right thing for the Camaros.
If memory serves the last 2 weeks were almost all base firebirds and Camaros, they saved the parts and pieces for Leonard's car... If you find the thread on Leonard's car you will see the Black Firebird.
