Disc- Brakes and Posi Question
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
How rare are rear disc brakes with posi on a 1982 Camaro? I've looked all over the internet but have found nothing useful.
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Re: Disc- Breaks and Posi Question
As others will say, there's no way to know. GM did not keep records of what cars were built with what options back then. I know in the world of '82 Pace Cars the rear discs are "rare" -- but again, there's no way of knowing how many total '82s had them.
That sucks, okay another question how desirable are they? Also thanks for your help.
The 82-88 J65 set-up is generally reviled here on TGO. That said, I experienced no issues with it. The system requires the use of the parking brake on a regular basis to function well. See the recall below.
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
JamesC
Transmission: World Class T-5
Axle/Gears: BW 3.45
There was enough demand for the 4 wheel discs, that GM actually ran into parts shortages for the system. Sometimes, you'll run across a WS7 early Trans Am, for example. That was a WS6 car with drum brakes, built during the shortage.
JamesC
JamesC
Here's the former:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Check below for other options:
http://www.flynbye.com/
JamesC
Okay thanks for all your help.
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
