VIN HELP PLEASE!
Car: 1983 z28 H.O. Camaro
Engine: 305 rebuilt carbed. .030
VIN HELP PLEASE!
Hey fellas, I took my car into smog today and they had
issues with my VIN. They couldn't figure out wether iit was
a factory 4bbl carb and if the cat. was the correct one.
Is there anyone that can run my VIN and maybe e-mail
me the page for proof?
VIN - 1G1AP877XDL143925
Thank you !
Thank you !
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
Re: VIN HELP PLEASE!
http://www.fbodymotorsports.com/83camaro
If its an '83 it very well could have been a Crossfire injected car that was converted over to carb. The 8th digit is a 7 which means TBI.
I am always told that I have engine code H, due to the fact
I have the H.O. 5.0 4bbl L69 with fiberglass hood, Lear Seigler interior and t-tops,
rather than the standard Z28. I guess it was introduced
March of 83, and just over 3,200 produced.
But there is no H in my vin so what is 7?
If its an '83 it very well could have been a Crossfire injected car that was converted over to carb. The 7th digit is a 7 which means TBI.
gives you the body type.
Mine are 87 -coupe 2 door plain back
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the 8th digit of the vin is the engine. do you still have the rpo codes ?
Car: '83 Z-28
Engine: 5.0 CFI
Sorry I meant the 8th digit is the engine type. 87 means 2 door coupe. The second "7" is the type that tells the engine type.
I'll edit my first post to avoid confusion and me looking stupid
1G1AP877XDL143925
1G1AP877XDL143925
Car: '83 Z-28
Engine: 5.0 CFI
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
"G" is the high-output L69 4bbl.
"7" is the questionable-output LU5 cross-fire.
If so, somewhere down the line someone put in a l69 block
with the factory 416 heads. It also has the duel snorkel air filter.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Guys, the OP has an '83 here. The 10th digit is a D which indicates 1983. VIN 7 is the 190HP L69 5.0L HO carbureted engine.
The Cross-Fire engine was VIN S that year.
ok thanks now how can I prove that to smog without buying a car fax??
Ok thanks scottmoyer ill try this..
Do you think this is good proof?
It kinda looks like something I could type up myself lol
This came straight from GM in their restoration packet. You can download the entire packet for your year from the media archives website. Do a quick search and you'll find a link to it, cuz I gotta run. That should be sufficient.
Car: `86 SS / `87 SS
The L69 was 8th digit 7 in the F and G platforms in 1983.
The LC2 used 8th digit 7 in 1984-1987 Buick Turbo Regals.
The LC2 used 8th digit 7 in 1989 Pontiac Turbo Trans Ams.
And L69 was 8th digit G in 1984-1988 F and G.
And on that note, was the official rating of the F-body 1983 L69 a few hp lower than the 1984?
Holy s*** I passed smog today!
I managed to pass a 29 year old car in california today I can't believe it.
Thanks for all the help fellas
Thankfully people of all walks of life and car ownership (even those who take their cars to a shop for most work) can participate and contribute to the board.
