Decoded my VIN and found something strange Please Help me understand
Old Jul 10, 2012 | 04:27 PM
aco2451's Avatar
Car: 92 Camaro RS T-Top
Engine: 305 TBI
Transmission: Automatic 700R4
Ok, so I went to camaroz28.com and used their VIN decoder to see what my 92 RS is all about because my car doesn't have any stickers that I can look at (the only two stickers I have on the drivers door has been covered in spray paint.)
First, a little back story, bought the car from craigslist for $500 about 1 1/2 years ago. It has a Rebuild Salvage title due to it being abandoned on the side of the road and then the wrecker service that picked it up auctioned it off. So the kid I bought it from had no keys and tried to bypass the VATS and broke the ignition cylinder (said he had it running) but it then quit one day and he got tired of messing with it.
So, I'm getting ready to do a LT1 & 4l60E swap from a b-body and I was told by the mechanic helping me that I may want to look for a new posi rear end. So I've done a lot of research and I figured I would do a VIN decoder on the car and find out what I have.
From the decoding I found that everything is true to the car, but the one thing I need help on is that it's showing that I have a drum rear end with 3.42 gears. Which after more research from the 92 Camaro information page here on TGO's home page found that a 3.42 rear end wasn't offered with a LO3/auto the only 3.42 it shows is for the V6 in a manual.
So, Is it possible to have 3.42 gears? would it be a posi? because if it's posi then I may just end up doing a rear disc conversion.
Any help will be greatly appreciated.
Adam
Old Jul 10, 2012 | 05:11 PM
yo soy el warg's Avatar
Re: Decoded my VIN and found something strange Please Help me understand
Adam
Did you look in the rear glove box or storage compartment lid for your RPO list that would tell you what came originally on the car. They put them there on the '92 Camaro so if it isn't there someones removed it.
Old Jul 10, 2012 | 05:32 PM
AmorgetRS's Avatar
What VIN decoder? The VIN doesn't list what rear end you have in the car.
Old Jul 10, 2012 | 05:42 PM
aco2451's Avatar
Engine: 305 TBI
Here is a link from my decoding
http://www.camaroz28.com/forums/vind...FP23E7NL113791
hopefully it will work
Old Jul 10, 2012 | 05:54 PM
JT's Avatar
JT
Community Administrator
The VIN decoder that you used, unfortunately, isn't quite specific to your VIN. It's a generic VIN decoder.
Here is a VIN decoder that will give you specific information for your vehicle:
http://www.compnine.com/vid.php?vin=...113791&x=0&y=0
As the above shows, your vehicle, from the factory, came with the 2.73 gears.
Old Jul 10, 2012 | 05:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
RPO's or not, the car is 20 years old. Anything could have happened in that interval. Best bet is to drop the diff cover and ID what you have. The 10-Bolt FAQ will be of help, I thlink.
JamesC
Old Jul 10, 2012 | 06:04 PM
aco2451's Avatar
Engine: 305 TBI
Thanks JT that helps me out a lot.
I think what got me was that the rear axle that was listed wasn't even an option.
Looks like I need to start looking for a posi rear disc to put under it for the LT1 swap.
Thanks again for the quick replies
Old Jul 10, 2012 | 08:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
There is a plate(tag) on the rear with the rear size, hopefully it wasn't removed.
Old Jul 10, 2012 | 08:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's a code stamped into the front (engine) side of the passenger's side axle tube, about 2" in towards the center from the shock mount. You will need to break out the wire wheel and get the rust cleaned off to find the code. Believe it or not, Haynes actually has the axle codes by year, standard/posi, GM/Borg Warner... Mine's a 2HL, a 3.42 open. If you don't want to crack (open) the housing, that is.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
SlowAZ28
Sep 2, 2015 05:19 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
