The question of the pedal pads.
Old Aug 27, 2013 | 10:04 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I've seen two styles on our cars.
The hex pattern pads:
And the older style looking pads:
All of my cars have the hexagon pattern pads and were all built at Van Nuys. Anyone have info on which cars got what and why?
Old Aug 27, 2013 | 01:12 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: The question of the pedal pads.
I've Only Seen The Hex Type,The GM Factory Replacement I Have On My Clutch Pedal Is Similar To The Old Style.
Old Aug 28, 2013 | 07:42 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
1987 Van Nuys car.
I know the 1989 IROC-Z had the honey comb design with the curved edge gas pedal. I guess we just need to check to see if this was another 88+ change.
Update...I went through some photos of 1988 cars and see the honeycomb pattern and curved gas pedal. Another 88+ design.
Old Aug 28, 2013 | 07:52 PM
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by scottmoyer
1987 Van Nuys car.
Both my '85 and '83 have the honey comb pattern.
Old Aug 28, 2013 | 08:19 PM
scottmoyer's Avatar
There's an 87 Norwood car on ebay that you can see have the pedals as mine. So we know that both Norwood and Van Nuys had the same pedals in '87.
It looks like 82-86 all had the honeycomb pedals. I wonder why '87 was different.
Old Aug 28, 2013 | 08:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
Yeah, I thought it might have been a Norwood vs Van Nuys thing, but guess not.
Old Aug 28, 2013 | 10:15 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
I think my brake pad was changed out by the original owner, mine has the disc brake writing pad on my 91 T/A and all other GTAs and T/A from 88/92 i've seen have been the honeycomb type regardless if it had drum or disc rear brakes. But my gas pad is like the 88/92 style.
Old Aug 29, 2013 | 12:14 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
My 87 IROC-Z has the lined Disc Brake pedals and my 89 RS with drums has the honeycombs. Both are Van Nuys cars.
Old Aug 29, 2013 | 12:17 AM
chazman's Avatar
Axle/Gears: BW 3.45
Looks like there is some connection with '87s as Scott mentioned.
Old Aug 29, 2013 | 12:21 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
My '85 has the lined brake pad.
Old Aug 29, 2013 | 06:30 PM
Stuart S's Avatar
My Norwood '87 (TA) has the lines w/logo like scottmoyer
My '89 GTA has the honeycomb
Old Sep 2, 2013 | 09:22 PM
whyt86roc's Avatar
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
My 92 RS has the Hex style pads.. I'm wondering if they didn't change the design of them around the 90 models??
Old Sep 2, 2013 | 09:51 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Fleabay sells the pedal pads if anyone needs one...like I do.
http://www.ebay.com/itm/GM-Pedal-Pad-14038638-/230590883457?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1991%7CModel%3ACamaro&hash=item35b049a681&vxp=mtr
Old Sep 2, 2013 | 11:46 PM
chazman's Avatar
Axle/Gears: BW 3.45
So much for the '87 connection. My '85, BTW, has the honey comb pattern.
Old Sep 3, 2013 | 10:10 PM
Stuart S's Avatar
Is your 85 a Van Nuys or a Norwood car?
Old Sep 3, 2013 | 10:11 PM
chazman's Avatar
Axle/Gears: BW 3.45
Van Nuys.
Old Sep 3, 2013 | 10:16 PM
Stuart S's Avatar
Van Nuys.
Does anyone have a Norwood car with the hex pads?
That may be the difference... Over the years I have had 5 thirdgens...
'86 Norwood IROC (sold) - no hex - auto, 4 wheel discs, LG4
'87 Norwood TA (still have) - no hex - auto, drum rear, LB9
'87 Norwood TA (sold) - no hex - auto, drum rear, LG4
'89 Van Nuys GTA (sold) - had hex - auto, 4 wheel disc, L98
'89 Van Nuys GTA (still have) - has hex - auto, 4 wheel disc, L98
Old Sep 3, 2013 | 11:18 PM
gt4373's Avatar
Mine's Norwood.
Old Sep 4, 2013 | 08:29 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
All my cars are 89 and up,
all honeycomb,
disc/drum auto 3cars,
disc/disc 5spd 1car,
disc/disc auto 7cars.
Old Sep 4, 2013 | 08:48 AM
chazman's Avatar
Axle/Gears: BW 3.45
Here's what I think...
I *think* that the honeycomb pads are standard for all 3rd gens from '82-'92, from both Norwood and Van Nuys. The other ones with lines I'm guessing, were in the parts chain, and were either used to fill in gaps in supply, or someone simply decided to use up that stock pile of parts during '85-'87. LOTS of '87s with them, it would appear.
Just my theory.....
Old Sep 4, 2013 | 09:18 AM
gt4373's Avatar
I Think You May Be Right,I Checked My Records I Bought This Replacement Pad In 2004,I Remember The GM Parts Man Saying The Honeycomb Was Superseded With The Lined Type.
Old Sep 4, 2013 | 05:58 PM
scottmoyer's Avatar
I think you have a replaced pad. What is your gas pedal style. They should match.
I have seen replacement pads that have the honeycomb pattern for autos and I found the lined pads for manual cars. I have not been able to locate lined brake pads for the auto cars. BTW, for anyone researching, my car is a Van Nuys car.
Old Sep 4, 2013 | 06:28 PM
Engine: 5.0 TPI
I have seen replacement pads that have the honeycomb pattern for autos and I found the lined pads for manual cars. I have not been able to locate brake pads for the auto cars. BTW, for anyone researching, my car is a Van Nuys car.
Who would have replaced it? I didn't. I bought the car new.
Old Sep 4, 2013 | 09:18 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I read somewhere, probably about ten years ago, that the lined pads were a one year only design, 1987. My 1987 Z28 convertible has lined pads.
Old Sep 5, 2013 | 08:46 AM
chazman's Avatar
Axle/Gears: BW 3.45
I does seem like all of the '87s have them.
Old Sep 5, 2013 | 10:14 AM
TTOP350's Avatar
The lined pedals were also used in 1st and 2nd gen cars but if memory serves me correctly, the gas pedal had horizontal lines that went top to bottom instead of just having that little lower section.
Old Sep 5, 2013 | 08:43 PM
JT's Avatar
JT
Community Administrator
Is this a difference between Camaros and Firebirds? From what I've seen, every 1987 and older Trans Am had the lined pads while 1988 and newer Trans Am had the honeycomb design.
Here's a screen grab from Knight Rider in 1983 showing the lined pedals on their Trans Am. While the car was obviously modified, I doubt they'd change the pedals from honeycomb to the lined for the show.
Old Sep 5, 2013 | 10:37 PM
TTOP350's Avatar
I thought the pedals in birds went from lines to honeycomb in 85 with the dash upgrade? Just a thought, I sure don't know, don't look at the pedals much.
Old Sep 6, 2013 | 07:32 AM
Stuart S's Avatar
Originally Posted by TTOP350
I thought the pedals in birds went from lines to honeycomb in 85 with the dash upgrade? Just a thought.
No, pretty sure it changed in 1988
Old Sep 8, 2013 | 08:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
My 86 TA came with these,maybe it has something to do with 4 wheel disk brakes(WS6).
Old Sep 9, 2013 | 02:38 PM
scottmoyer's Avatar
Mantaguy, I wonder if that brake pad is an OEM pad. Notice the font size and layout compared to the rest of the "disc brake" pads listed. It just doesn't look as clean and crisp as the others.
Old Sep 9, 2013 | 03:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
It is a replacement,I forget were I got it,but it was sold to me as OEM, OER.or NOS.maybe Ebay,GM Direct or GM Parts Cheap.If it's not,it sure is close to what was on their.
Old Sep 9, 2013 | 05:33 PM
dmk250's Avatar
Car: 1985 Trans Am WS6
Engine: LG4
Axle/Gears: 3.27 Posi Disc
I was curious, so I snapped a picture of mine. I have no reason to believe that any of these have been replaced. 1985 Trans Am WS6.
Old Sep 9, 2013 | 08:06 PM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
1982 Pontiac Firebird Trans AM WS7. All original car with 24K actual miles on it. These are the OE pedals, however you can see 31 years of wear from starting the engine each week.
Old Sep 9, 2013 | 08:09 PM
86WS6's Avatar
1986 Pontiac Trans AM WS6 with 30K actual miles. Again like the 82, there is 27 years of wear and tear from starting the engine each week. These are the OE pedal pads.
Old Sep 10, 2013 | 12:16 AM
Administrator
It seems true that the lined pads were available throughout almost the entire Third Gen randomly on disc cars. I think the style is from the late 60s-late 70s cars mostly. Possibly leftovers? Back then some had chrome inserts also. It's definitely true that the replacement Disc Brakes font is slightly different than the original pads.
Old Sep 10, 2013 | 01:22 PM
kymmee's Avatar
Per chazman's request-1982 Firebird base 24k. Its a Van Nuys car, built in month of April, 1st or 2nd week.
On an interesting side note-86WS6 has an 82 TA with the maroon interior-but look at the vinyl piece near the gas pedal. His has a more reddish maroon look as mine is darker maroon.
Old Sep 10, 2013 | 01:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
I went threw my parts & illustration catalog and it is only listing one automatic peddle pad for 82-87,P/N 15522095,then it list P/N 14036125 for 88 and up.Then I found this on ebay
http://www.ebay.com/itm/Buick-Cadillac-Chevy-GMC-Olds-Pontiac-w-Automatic-Transmission-Brake-Pedal-Pad-/370732721239?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5651646457witch is a after market replacement for P/N 15522095.witch it shows the Disk Brake Logo.
So their may be some truth to left over parts being used by GM back then
Old Sep 10, 2013 | 01:41 PM
mantaguy's Avatar
Engine: 5.0 EFI
Old Sep 10, 2013 | 03:25 PM
86WS6's Avatar
My 82 is a late year build Norwood car.
Old Sep 10, 2013 | 07:34 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
My 87 IROC (from the top post with the red gut) is a Norwood car, I checked my 87 GTA, it also has the lined "disc brake" pad
Old Sep 12, 2013 | 01:41 PM
  #42
83 Crossfire TA's Avatar
Well, not that this helps but:
83 TA, aluminum drums- lined
87 Formula 350, disk rear- lined
87 TA, cast iron drums- lined
you can tell norwood or van nays from the vin, correct? if so I have scans of the titles and I can check them all from here if you want.
Old Sep 13, 2013 | 08:02 AM
  #43
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Same pedals in my 1984 Trans Am, I doubt they've ever been changed as she spent most of her life in the UK and you don't find official GM stores that carry 3rd gen parts there.
Vintageracer
Jan 10, 2020 05:33 PM
bigdavesiroc
Sep 14, 2015 10:51 PM
19irocz85
Aug 30, 2015 10:03 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
