Help with learning my cars history.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Help with learning my cars history.
It's a 92 Camaro with a TBI 305. Not sure how to tell an RS, but somebody else will know.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Be nice to know what the factory color was also.
I know the car isnt stock, it has a 350 crate in it. The body has ground effects and it has a wing on the hatch, curious if that stuff was stock, or added over time.
I dont know which direction I'm gonna go with the car yet, and this info may
help guid my decisions, especially on paint.
Thanks,
Paul
Thanks,
Paul
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Just curious if I'm missing something, I just checked the Compnine website and it looks like they want a minimum of $10/month.
Engine: V6, V8
Ok, thanks for verifying. There was another link for checking vins that changed recently too.
If it's for your listed 1985 and 1986 Camaros, you'll likely not get results with Compnine unless those are exported Camaros since Compnine's database generally doesn't have anything older than ~ 1990 unless it's an export.
You'd need to go through GM Media Archive for an invoice instead:
http://www.gmmediaarchive.com/
Thanks JT
Guys, I'm not a car guy, if fact, this is the 1st one I've owned, I'm a truck guy,
any additional info would be usefull, for example, what models have the effects kit.
Would it be sacralidge to speak of removing it for better clearance?
Thanks,
Paul
Thanks,
Paul
Transmission: 5-Speed Manual
Thanks,
Paul
Thanks,
Paul
Ground Effects Were Standard,Rear Aero Wing Only Came On The Z28
Engine: V6, V8
I appreciate the info because I would have been wasting my money if I had paid to check.
This website aslo has some information here (found from the home page):
https://www.thirdgen.org/1992-chevy-camaro
https://www.thirdgen.org/Camaro-Rally-Sport
The RS has the ground effects, however removing them might require a new front and rear bumper as well. If you don't like ground effects you may want to look for a sports coup. I prefer sports coups after '85 myself. It's pretty common for people to modify Thirdgens and there's a lot of modifications on this website as well, so don't feel bad about that. The only thing that bothers me personally is modifying one that's unmolested as there aren't as many as there used to be.
Edit: BTW, do not remove the black piece along the bottom in the front (air dam), it's not part of the ground effects. It is needed to keep pressure in front of the radiator and it's common for the engine to overheat if it's removed.
Car: '84 Z28
Engine: L69
Definetly an RS, it's got the Y86 option code. I'm staring at a SPID sheet on your car right now. Originally a 305 TBI (RPO L03), auto trans, 2.73 rear gear, rear drum brakes (RPO J41), hardtop, Med. Quasar Blue paint (80U), black base cloth interior (19B), soft ride suspension (FE1). The rear spoiler, and ground effects were standard equipment as mentioned earlier. Car was built March 13, 1992.
9192camaro
16
Feb 3, 2019 12:21 AM
