Where can I get this factory thermostat housing bolt???
Transmission: World Class T-5
Axle/Gears: BW 3.45
Where can I get this exact factory bolt?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Where can I get this factory thermostat housing bolt???
Try this place ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
they handle almost everything.the only downfall is,you have to buy in bulk.
The parts book is saying it's a stud,it doesn't list the size or part no.
This is just example.
http://www.clipsandfasteners.com/7_1..._2_p/a9711.htm
Transmission: T-5, TH350, T-5
Does it need to be NOS or perfect? More than likely the most abundant source will be a donor car.
And I don't know who's engine compartment that it, but it's gorgeous.
Axle/Gears: BW 3.45
I didn't see it on that site, but I'll sure keep that link for future needs.
Axle/Gears: BW 3.45
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
It's discontinued, but the GM Part Number is 14091545 and has the following description: STUD, CLNT OTLT (3/8-16X25/32)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use a stud and a flange nut and nobody will ever tell the difference.
Axle/Gears: BW 3.45
Axle/Gears: BW 3.45
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The stud in post #5 appears correct. I don't a have an old 70's SBC near by to verify, but my guess is the stat housing bolts on those are also 3/8 course thread so you should be good with that one.
Axle/Gears: BW 3.45
Thanks Lurbie for the part number! Found a Chevy dealer in Michigan who had 4 in stock and I bought all 4.
Car: 89 Camaro
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
