so the center console is missing from the 86 trans am i just bought, i was wonder what options i have to try and get the rpo codes this car came with
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
Sometimes the dealer can get them from the VIN. Not sure how far back they go to.
I don't think they can check the VIN that far back, I know the service parts identification label on my 91 RS was in the rear locking compartment. You can also try looking for your build sheet, but if it isn't in the car you may be screwed
TTOP350
close
- Join DateOct 2001
- LocationIl
I got them for my 89 several years ago, I had the rpo code sticker and for fun we checked it out.
ill try a dealer, would PHS have the ability to source most of the rpo codes.
I don't think many had success for ThirdGens older than 1989 as that appeared to be the cut-off year. Unless the car is an export.
PHS can provide an invoice with major RPO codes but not every single one.
Quote:
Originally Posted by midge54
ill try a dealer, would PHS have the ability to source most of the rpo codes. okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
I 2nd this... The dealer invoice will tell you anything important, like what the original paint 7 interior colors were, the engine, transmission, wheel options, tire options, etc. However in some cases standard things are not listed, nor are things like the RPO for the springs. It will indicate the performance package if equipped. If they are not listed then you might have to go through the dealer books and figure out what was standard for your car and go from there...Originally Posted by JT
I don't think many had success for ThirdGens older than 1989 as that appeared to be the cut-off year. Unless the car is an export.PHS can provide an invoice with major RPO codes but not every single one.
Some of the RPO's on the SPID are useless anyway, they had several different RPO's for springs, but for aftermarket sales they lumped them together...
It would be so awesome for history sake if the 82-89 had not been purged...
im mainly trying to find out the major rpo codes for the car ie wheel option rear end suspension and such
GTA50
close
The problem is that GM had two systems - one for the US and one for Canada. In Canada you can trace back to about 1980! In the US, it was somewhat of a dealership thing as to whether or not they wanted to subscribe. I've tried to source rpo codes for US cars many times from here in Canada to see if there was some cross-over, but come up with nothing.
okfoz
close
- Join DateMar 2001
Only thing not purged as far as I can tell was the Canadian sold 3rd gens from 82-89... All others were wiped from their system for some unknown reason.
