88 iroc 9th digit means?
Old Oct 23, 2015 | 08:55 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Mines a 5 i think or an S and what does it tell me?
Old Oct 23, 2015 | 09:26 PM
JT's Avatar
JT
Community Administrator
Re: 88 iroc 9th digit means?
9th digit in the VIN is a check digit:
https://service.gm.com/dealerworld/v.../vincard88.pdf
Doesn't tell anything about the car itself:
http://www.carfax.com/guides/buying-...r/vin-decoding
Old Oct 23, 2015 | 11:59 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Check digit is always a number, so in your case it's a 5. This is how its calculated:
To determine check digit (9th digit) of your car you need to take the VIN and assignany letters in the VIN with a set numerical value as follows:A = 1, B = 2, C = 3, D = 4, E = 5, F = 6, G = 7, H = 8,J = 1, K = 2, L = 3, M = 4, N = 5, O = 6, P = 7, R = 9,S = 2, T = 3, U = 4, V = 5, W = 6, X = 7, Y = 8, Z = 9
Any numbers in the VIN remain the same (not replaced) and thus you have a 17 digit number.Then you must multiply each of the 17 digits by a set "weight" (multiplier). The weight applied to each digit is as follows:1st = 8, 2nd = 7, 3rd = 6, 4th = 5, 5th = 4, 6th = 3, 7th = 2, 8th = 10,9th = 0 (check digit), 10th = 9, 11th = 8, 12th = 7, 13th = 6, 14th = 5,15th = 4, 16th = 3, 17th = 2
After multiplying each VIN digit by the associated weight - add up the results of all 17 products.Then divide by 11, and the remainder is your check digit (9th digit).If the remainder is 10, then the check digit is 'X'.
Old Oct 24, 2015 | 08:46 PM
mjdavis68's Avatar
Why?
Old Oct 25, 2015 | 07:44 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Not sure why, but it may have something to do with security. It would be real easy to just pull a VIN # out of your a$$, but the check digit at least requires a minimal amount of math if you want to fake one up.
Old Oct 28, 2015 | 07:27 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The check digit is just that. It uses a formula based on other characters of the VIN to prevent people from just changing one number or letter to create a fraudulent VIN.
Old Oct 29, 2015 | 09:41 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I think somebody from the IRS made that up.
Old Oct 29, 2015 | 09:56 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Naaa. I see big brother playing defense on this one.
Old Nov 3, 2015 | 09:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
IRS? Seriously? the 17 Digit VIN was created to standardize the VIN system for all makes, models, etc. This in part was to reduce the chance of VIN duplication during production over the years. The Check Digit is a calculated number from 0 thru 9 and X, based on a formula of applying numbers or letters to create a unique VIN for that vehicle.
The check Digit is created in order to reduce the chances of fraud or from erroneous VINs from being reported to the DMV or insurance companies. It is not a conspiracy.
When looking at a VIN the following are NEVER used
The Letter I or the Letter O (possibly Q) as not to confuse them with the Number 1 or 0.
https://en.wikipedia.org/wiki/Vehicl...ication_number is an interesting link on the VIN system and how it works.
PurelyPMD
Members Camaros
100
Dec 15, 2020 06:38 AM
FlyinGTP
Jul 20, 2016 07:42 PM
Bs88ta
Feb 16, 2008 11:58 PM
cfirebird86
May 24, 2003 01:23 PM
mw66nova
Jul 11, 2002 04:03 PM
