Some have vats in 88, if you post the letters on the memcal or prom I can see if I have the file to check to see if it has vats . If it’s tbi it wouldn’t have vats some tpi did. Another way to tell is if there is a blue wire in pin b6 of the ecm if it’s tpi.
its factory 350tpi roller. Does the non vatts have the small white wire on the lower column. I will look to see if the ECM is even in it
ECM long gone. To the far left there are two white connected to one white and one orange.they look a little big. On column there's a black sheath wire with 2connectors with about 4 wires leading off them. I have had some cars with vatts and don't see any wires like I had in them
gota change out messed up ignition switch at a minimum. Po broke the key off in it. They damaged the plastic ring at the base where it meets the dash
If your going carb you don’t have to worry about it. If you do find the leads you can ohm them to see the stuck keys resistance.
You can buy the matching key and cylinder on eBay.
