9 Bolt BW brake lines
Old Sep 18, 2018 | 11:36 AM
brp88gta's Avatar
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
Hey guys, I am going to be rebuilding and detailing the undercarriage of my 88 GTA this winter and was planning on installing stainless steel brake lines while I'm at it. The only problem is I can't seem to find a vendor that sells the brake line that runs across the rear axle for a 9 bolt rear. Everything I find is for the 10 bolt rear. Any ideas on where I can find this line pre bent for a 9 bolt with disc brakes?
Thanks,
Brian
Old Sep 18, 2018 | 12:17 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 9 Bolt BW brake lines
I don't think anyone does since it was a low production item. I need to weld some brackets to my 9 bolt for the ends of the tubes, but the 10 bolt lines work well enough for the disc application on the 9 bolt
Old Sep 18, 2018 | 12:44 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I used a set of 10 bolt disc brake lines on my 9 bolt build and just had to tweak a little here and there for a precise fit.
Old Sep 18, 2018 | 03:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The braking systems between the 9- and 10-bolt are the same. Check out the following:
https://braketubes.com
FRA8602SS- 84-88' CHEVY CAMARO/ PONTIAC FIREBIRD, W/ J65 REAR DISC BRAKES, W/ HOSE ON RIGHT SIDE (NO LEFT HOSE), REAR AXLE BRAKE LINE SET; STAINLESS
JamesC
Old Sep 18, 2018 | 05:05 PM
Drew's Avatar
Que? The brackets are generally just bolted down with big sheet metal screws.
Old Sep 18, 2018 | 05:57 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
There are no brackets at all for the ends of the tubes, where they meet the hoses. I was going to make some and weld them on
Old Sep 18, 2018 | 06:05 PM
GeneralDisorder's Avatar
Buy the line, tubing bender, and flaring tools and do it yourself.
Old Sep 18, 2018 | 06:35 PM
JamesC's Avatar
The expense and inconvenience probably outweighs the $55.20 for the above lines.
JamesC
Old Sep 18, 2018 | 08:06 PM
Drew's Avatar
By all means, fab some brackets, but sheesh, bolts are plenty sturdy, no need to fire up the welder.
Old Sep 19, 2018 | 10:42 AM
brp88gta's Avatar
Engine: 305tpi
I will be purchasing the 10 bolt s.s. line in the near future. Thank you guys for all of the responses and for clearing that up for me.
-Brian
Old Sep 19, 2018 | 01:30 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Then I have to break out the drill, tap and die set. Burning the MIG for 2 seconds for each bracket is a lot less work
Old Sep 19, 2018 | 04:50 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
I believe Classic sells what you need.
https://www.classicindustries.com/sh...=brake%20lines
Old Sep 19, 2018 | 07:06 PM
brp88gta's Avatar
Engine: 305tpi
I thought I checked Classic industries before but I guess I didn't look hard enough. That is what I am looking for. Thank you!
Old Sep 19, 2018 | 08:41 PM
Drew's Avatar
Whoa! Let's not get carried away here.... You're forgetting the time to open the gas bottle valve, purge the air out of the line, set the ***** and twisties, strap on your personal protective gear, etc...
Cordless drill, drill pilot hole (it might actually already be there), set drill driver torque clutch to "kill", insert square drive adapter, snap on the socket, line up the self tapper with the hole and squeeze the trigger until snug. Wham, Bam, Thank you Black & Decker.
Old Sep 20, 2018 | 09:21 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Purge the lines?!? Strap on gear?!? Please, I am not welding a bridge here, just tacking a bracket to something. Auto darkening face mask and 2nd degree UV burns are what I do when I weld. Plus the MIG is right there accessible all the time, I have no idea where my drill is ATM :P Plus, I've not had good luck with self tapping screws into thicker metal like the bracketry for the rear axle.
Old Sep 21, 2018 | 07:55 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
A word of warning on the S/S lines the metal is so hard you need to tighten, loosen, tighten tighter, loosen TIGHTEN tighter to "seat" the flare or they will leak! I wont ever buy stainless lines again
I know the steel lines rust but do any of you still drive in the winter? I'd get steel lines and paint them with clear and they will last a good long time just stay out of the salt
Old Sep 21, 2018 | 08:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You are correct, they need to be seated properly by doing this. I don't know why you would never buy them again though, they are wonderful. I put stainless on all my projects and will continue to do so in the future.
Old Sep 24, 2018 | 09:46 AM
brp88gta's Avatar
Engine: 305tpi
I appreciate the heads up. I have used stainless steel lines in the past on other vehicles and I have encountered the same issues to get them to seat properly, but for me the extra work/frustration installing stainless lines was worth it for the end result. The car is never in the rain, but my garage isn't heated,so I'm going with the stainless so I don't need to worry about surface rust on the lines or having clear coat yellow over time.
Old Sep 24, 2018 | 03:19 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
https://www.summitracing.com/int/par...0/applications
jrz28
Brakes
May 26, 2011 08:21 PM
ebmiller88
May 28, 2007 04:34 PM
MechCD
Aftermarket Product Review
May 5, 2005 10:09 AM
crazynights
Oct 20, 2003 06:57 PM
