Firebird headlight motor wiring - did factory use wire loom?
Old Jul 24, 2019 | 11:54 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Did the factory use wire loom to protect the headlight motor wires? I'm not finding any evidence of it, but it seems like it wouldn't have hurt to put it there. Anyone know?
Old Jul 24, 2019 | 01:30 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Firebird headlight motor wiring - did factory use wire loom?
On my 88, 91 and 92 there is loom on some of the wiring for the headlight harness, but nothing on the headlight door side motor wire stub, and I want to say not on the body side up to the connector, but I think it is on there across the radiator support opening area
Old Jul 24, 2019 | 02:09 PM
LiquidBlue's Avatar
Transmission: MD8
yes all of that is definitely there. the harness connector side is wrapped in tape. but the side leading to motor is bare. looks like it could bang around on bumper bolt threads. which is why i was asking.
passenger side
driver side
Old Jul 24, 2019 | 02:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Yeah, motor stub is bare on all my harnesses
Old Jul 24, 2019 | 02:35 PM
AmorgetRS's Avatar
Same, they've been bare on all of my cars
Old Jul 24, 2019 | 03:41 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I've had the pig tail rub through once and it fried my headlight module when it shorted out so adding some split loom isn't a bad Idea I did so after fixing it.
Old Jul 24, 2019 | 10:37 PM
LiquidBlue's Avatar
Transmission: MD8
any you guys have super low mileage car? the never drivens never show us this area. guess it’s kind of boring
Old Jul 25, 2019 | 12:56 AM
83AQ9's Avatar
Car: 1983 Recaro T/A
Engine: GMPP 350HO Carbed
I say this as a fan of the third gen... it's not a well-designed car.
My first 2 hours of working on it seriously, 1 hour was refusing to believe what I was seeing. "I must be confused, nobody would design something that does this it's completely stupid." After that I decided forget originality except for looks. Everything hidden is getting fixed, even if fixed means thrown in the trash, like in the case of my park lock cable which leaves the firewall and comes back in. That was apparently the intended, "correct" routing.
Old Jul 25, 2019 | 07:19 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Sounds like someone had their dirty beaters in your car,
I have to say there aren't many things where I could say I was baffled by the engineering on these cars
Old Jul 25, 2019 | 10:46 AM
83AQ9's Avatar
First part is true, but last owner assures me that was not changed and someone here told me that is stock routing on the old ones. The places it passes through are definitely stock holes with stock shaped grommets. I only have the dealer manual from an 85-92, and the cables appear to stay internal on the later ones.
Another example of questionable design is that joint in the steering that adds the slop, and there's the headlight motors always breaking.
I do like the power wire color scheme and the load distribution blocks that let you pull the harnesses apart more easily, wish they were on more cars.
All I'm saying is if you can't see it on the outside, and you are sure you can do it better, it's probably a good idea to just do it.
Old Jul 25, 2019 | 10:49 AM
GeneralDisorder's Avatar
My park-lock cable on my 86 was from the shifter to the ignition switch - totally inside the car. The plastic bits on the ignition switch end of the cable disintegrated and left my key stuck in the ignition. That was a fun day. I deleted that garbage.
GD
Old Jul 25, 2019 | 02:10 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My 89 Formula 350 Conv has wire loom going to the headlight assy... It is a 37K mile car...
John
Old Jul 25, 2019 | 02:36 PM
LiquidBlue's Avatar
Transmission: MD8
John
Thanks for chiming in John. did they tape each end of the loom? is the loom high temp with grey stripe? one more if you don’t mind. is it only the section from connector to motor?
Old Jul 26, 2019 | 09:18 AM
okfoz's Avatar
IIRC mine is taped by the headlight for sure. Ususaly they tape the unions as well, to keep the loom from chafing on the wires. NOW I have to look and make sure.
John
Old Jul 26, 2019 | 10:30 AM
LiquidBlue's Avatar
Transmission: MD8
John
What about your other cars? Did you buy the convertible new? Here is what I'm referring to just to be sure:
Arrow points to where taped - that is how mine is from factory
The red outline shows where I was wondering if high temp loom would be located and the stripes are the end sections that would normally be taped if loom was installed.
Not sure why it would have disappeared from both sides if it was ever installed, but stranger things have happened.......
Old Jul 26, 2019 | 10:50 AM
okfoz's Avatar
ooohhhh I was thinking of the larger wire loom... I would have to look at those.
dave w
Jan 3, 2013 09:46 PM
Drew
Mar 31, 2002 03:08 PM
breathment
Jan 14, 2002 01:48 PM
Z28 Boy
Aftermarket Product Review
Dec 24, 2000 10:27 PM
