Anyone Ever See this (Wrong RPO Sticker)
Old Oct 6, 2021 | 12:37 PM
IROCIN's Avatar
Car: Irocs 87 Conv 5 spd & 87 T-Top auto
Engine: LB9/L98
Transmission: MM5/Auto
I posted this auction car the other day, but the more i dig into it, the odder it gets.....What tipped me off to start digging was the Z28 badge on the console that did not have the "Iroc-Z" below it. I stopped and physically looked at the car today, so the photos are accurate....
* The RPO sticker in the console lists the VIN# as 1G1FP87F0GN169617, but the VIN# on the car is 1G1FP87F2GN169618
The RPO Codes do not show that it is an Iroc, shows it does not have power locks, and has power seats. Below is the RPO sticker and some photos of the car.
Z28 badge
No Power Seats
145 MPH Speedometer
Car as it sits
16" wheels
Power Locks
Old Oct 6, 2021 | 01:35 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Anyone Ever See this (Wrong RPO Sticker)
The console has been changed.
Old Oct 6, 2021 | 01:47 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I'd agree, if the VINs weren't 169617 and 169618. Chances of randomly getting the very next sequence number down when buying a used console lid are slim to none.
Old Oct 6, 2021 | 01:48 PM
navy02ws6's Avatar
Oh boy, that's weird. The VIN on the RPO sticker doesn't even show a single record on Carfax other than the seatbelt button recall being issued in 1990, which makes me wonder if that VIN was ever even put on an actual car. Only other thing I can think of would be that the 169617 car hasn't been on the road in 30+ years. Plenty of records for your car (169618), all from IN, but none since 2014.
I would assume that this is just a simple factory mistake -- the cars were next to each other on the assembly line, and someone goofed and mixed up the center console lids. Never seen anything like this though (wrong options and VIN off by 1 digit). Nothing else would make sense, I don't think.
Old Oct 6, 2021 | 01:57 PM
OrangeBird's Avatar
Car: 1989 Firebird
Seeing how the last 6 numbers of both VINs are only one number apart (169617 VS 169618) I'd be inclined to believe the wrong SPID sticker got put on when it was being built VS the console being changed at a later date. Can you imagine the odds of some years down the road needing a console and buying one from a junkyard that was only one VIN number off?
Old Oct 6, 2021 | 02:01 PM
IROCIN's Avatar
Engine: LB9/L98
I spoke to a friend of mine that worked for GM, and his guess was as it went thru the factory being assembled, something got switched to the wrong car and somehow the RPO sticker of the car being built ahead of it got on this car by accident. The plate on the car shows it last being renewed in 2015, so it has sat a while.
Old Oct 6, 2021 | 02:08 PM
navy02ws6's Avatar
That certainly sounds plausible. As far as proving that the car you're looking at is an IROC, I would do some more digging. Off the top of my head, the only thing I can think to check is to make sure it has the Wonderbar up front, although that can always be added. Maybe check to make sure that the sway bars are the right size as well.
Old Oct 6, 2021 | 02:12 PM
IROCIN's Avatar
Engine: LB9/L98
Thanks. I appreciate your input. I'll check that at the auction on Saturday.
jkris53406's Avatar
Yup, ashamed to say I didn't catch that before I posted. I would agree with the consensus that these were obviously back to back on the line and switched RPO stickers by mistake.
Old Oct 6, 2021 | 02:17 PM
navy02ws6's Avatar
It was the obvious answer. I had to go back and re-type my response, I didn't catch it at first either.
Old Oct 6, 2021 | 02:25 PM
randyhummel's Avatar
Car: 1986 Iroc-z, 1968 Camaro RS-ss
Engine: 305, 396
Transmission: auto
apply for a dealer invoice for the car. That will help narrow down if it was ordered as an Iroc-z. Use the vin of the tag in window not rpo sticker.
Old Oct 6, 2021 | 02:33 PM
Engine: 305, 396
Transmission: auto
I would also look for the build sheet under carpet under driver front seat, also look for white partal rpo sheet under carpet in truck you will need to take spare tire voer off and lift up caarpet to find. that will have a partal vin 3 on it
Old Oct 6, 2021 | 02:37 PM
Engine: 305, 396
Transmission: auto
its a late production car by 145 mph speedo.
Old Oct 6, 2021 | 04:08 PM
vorteciroc's Avatar
Top Answer: 1
These Cars did not necessarily come off of the Assembly-Line in numeric order...
But the chances of it happening are higher if several Cars were being built with very similar options.
Are the options on the RPO decal very similar to the options of your car?
Old Oct 6, 2021 | 04:12 PM
IROCIN's Avatar
Engine: LB9/L98
There are quite a few differences between the RPO and what is actually on the car.
Old Oct 6, 2021 | 04:39 PM
BIRD91ZRAG's Avatar
Same color interiors? I've seen Chevelles have the wrong build sheet in them. Same color of interior though.
Old Oct 6, 2021 | 05:21 PM
IROCIN's Avatar
Engine: LB9/L98
Yes, the interiors seem to be the same.
Old Oct 6, 2021 | 06:39 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Radio is not original to the car............. No power button and SEEK / SCAN should be next to each other to the far LEFT. My guess is that it's an 83 radio,.. maybe an 84 from a different model. Dash pad isn't original either.
Old Oct 6, 2021 | 07:17 PM
IROCIN's Avatar
Engine: LB9/L98
I don't see an issue with the radio, and what tells you that the dash pad is not original? Just curious...
Old Oct 6, 2021 | 09:31 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Not sure about this. Here's a photo of the radio that came in my 86 Z-28, purchased new in January 1986.
Old Oct 7, 2021 | 05:00 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Well, I'm surprised nobody has said that the dash emblem is not the right dash badge. Also, how does a car with 65k miles on it, still have VR50 tires? The dash pad is incorrect. It's hard to tell if that's an '82/83 dash pad, or it has a new cover on it.
Old Oct 7, 2021 | 05:59 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
That emblem on the dash is a rocker emblem.
Old Oct 7, 2021 | 06:05 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Oct 7, 2021 | 06:22 PM
dagwood's Avatar
Top Answer: 1
I'd like to know what that SPID decal is even for.
10th digit is G, so It's a 1986.
It doesn't have B4Z, and not even Z28. But it HAS LB9. WTF???
Old Oct 7, 2021 | 06:42 PM
IROCIN's Avatar
Engine: LB9/L98
So much of it has me baffled. Would it be plausible that as it went thru assembly, and the incorrect RPO codes, certain things were put on that should not have been on it. I don't know if all of this make the car even worth buying...?
Old Oct 7, 2021 | 06:46 PM
IROCIN's Avatar
Engine: LB9/L98
In the initial post, the Z28 emblem was what tipped me off that something was odd with this car. As for the VR50 Tires, I am assuming it was a 2nd set. The Carfax shows that in 1988, the car had 44K miles on it. After that, no mileage was reported thru 10/14, only registration renewals.
Old Oct 7, 2021 | 06:52 PM
dagwood's Avatar
Top Answer: 1
I wouldn't worry too much about it, really. Yeah it's a bummer about the SPID being for a different car, but the only thing that appears wrong is the dash pad and emblem. I wouldn't be afraid of it..
Old Oct 8, 2021 | 08:34 PM
yo soy el warg's Avatar
The SPID sheet in this car is the most unusual one I have ever seen! These are the things that make it so weird!
1.) It has RPO (DD9) Mirrors RH and LH break away painted, (Export)
2.) It has RPO (EXP) (Export)
3.) It has RPO (JE1) Brake system (Export), (Europe)
4.) It has RPO (ZK3) Identification Pull-A-Head design (Export) Could this be the code that triggers an export (Z28) ? Never seen this one.
5.) It has RPO (VC5) Label-shipping exceptions, US possessions, or Japan Label (Export)
6.) It has RPO (VD1) Provision option Europe (Export)
7.) It has RPO (V78) Vehicle statement (Delete) (Export)
8.) It has RPO (V95) Vehicle Preparation (Export)
9.) It has RPO (1AA) Sales incentives retail amenities (Delete) order modifications to existing inventory (Export)
10.) It has RPO (KC4) Cooling system, Engine oil, NOT AVAIABLE TILL 1987 ?
11.) It has RPO (C41) Heater, outside air with fan and defroster, No RPO (C60) A/C (but has vents) RPO (C41) on 4th gen camaro is for air condition (Delete) ?
12.) It has RPO (K90) Generator, 108 ampere I haven't seen this on any?
13.) It has RPO (GU5) 3.23 performance rear gear ratio only available with RPO (Z28) equipped with the LB9 engine as the (G92) performance gear ratio in 1986. .
14.) It has RPO (LB9) Engine, 5.0L TPI only available with the RPO (Z28) coupe which it doesn't have.
15.) It has RPO (G80) Rear axle, limited slip which required RPO (J65) 4 way disk brakes in 1986 ?
16.) It has RPO (N90) Wheel, 15x7 (Cast Aluminum) which didn't come on an IROCZ in 1986 ?
17.) It has RPO (P20) Cap, styled wheel hub not on an IROCZ.
18.) It has RPO (QAC) Tires, P235/60 R15 Black wall available on RPO (Z28) not on an IROCZ ?
19.) It has RPO (UM6) Radio, AM/FM stereo cassette, ETR, includes clock not available till 1987?
20.) It has RPO (DX4) Stripe, 2 sides.
21.) It has RPO (NK3) Steering wheel, sport, soft rim, leather only on the Z28?
What the car doesn't have is RPO (B4Z) the IROCZ package which came with RPO (G92) 3.42 gear ratio in 1986 and no RPO (Z28) anywhere on it? Could they have built a Z28 to export to some other country and keep it within that country's laws? If this is what happened they did it piece by piece. It shows on the SPID sheet's weird combination of RPOs that you couldn't get on a non-export car without ordering the Z28 option. After completing the build were they so confused with what they had created that they had to put the next Vin# in the sequence on the car to be able to title the car in another country? Was somebody able to get this car built the way the SPID indicates then it didn't get exported so they had to change the Vin# on the car to the next number in the sequence to title it here? Who knows?
Old Oct 9, 2021 | 01:57 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Someone on thirdgen needs to buy this strange beast, just to preserve and study it. Otherwise some 18 year old kid gets it, drops a junk attempt at engine upgrade into it, runs out of money halfway through a bunch of half *** modifications, and parks it in parents front yard to slowly rot away over the next 20 years.
Old Oct 9, 2021 | 06:47 AM
LeonardS's Avatar
I agree! Buy this car so we can learn more about it. It sounds very interesting and would be a fun car to own and study. Hopefully it sells for a price that you’re willing to pay. Good luck!
Old Oct 9, 2021 | 07:58 AM
IROCIN's Avatar
Engine: LB9/L98
We’ll see how it goes, but thanks.
Old Oct 9, 2021 | 11:00 AM
What got me interested in this car is that I own a 1988 White V6 sport coupe and a 1988 White IROCZ Convertible and they were built one Vin# apart from each other. So they did build IROCZ verts right along with V6 sport coupes. I think the paint color is what determined what they built on any particular shift. I bought the sport coupe about 10 years after buying the IROCZ vert. It really surprised me when I looked at the Vin. numbers on the titles. It is about as rare for this to happen as winning the lottery!
Old Oct 9, 2021 | 11:11 AM
IROCIN's Avatar
Engine: LB9/L98
car went for $9500….a few grand more than I was willing to go.
Old Oct 9, 2021 | 11:19 AM
LeonardS's Avatar
Were you able to connect with the buyer? It would be nice for him to join this site and update us on the car.
Old Oct 9, 2021 | 01:42 PM
IROCIN's Avatar
Engine: LB9/L98
No offense to anyone, and I am no spring chicken (52), but the guy that bought the car was probably 80 years old. He was a nearby farmer, and didn’t seem to know much about the car. My guess is that he was just looking for something to spend money on. I did tell him about the oddity of the car and the interest from our group and gave him our site address. I highly doubt we will hear anything from him, but who knows.
Old Oct 9, 2021 | 01:44 PM
IROCIN's Avatar
Engine: LB9/L98
wow, that is really ironic to have two cars that are built one after another!
Old Oct 9, 2021 | 01:46 PM
LeonardS's Avatar
It might pay to stay in touch with him. You may get another chance to own it in the future.
Old Oct 9, 2021 | 02:31 PM
IROCIN's Avatar
Engine: LB9/L98
True…. And Leonard, I do owe you an apology from my post the other day. You are a well respected member of this community, and I am fairly new and I should not have replied to you as I did. I took your comment incorrectly, so for that I do apologize.
Old Oct 9, 2021 | 02:45 PM
LeonardS's Avatar
Thank you, but no worries! I also should have chosen my reply more carefully……it’s hard to come across jokingly on a forum, especially when we don’t know each other. Good luck finding another Thirdgen!
Old Oct 9, 2021 | 06:07 PM
vorteciroc's Avatar
Top Answer: 1
Well...
I was going to say to PM me the VIN on the Car and the VIN on the RPO-SPID.
...and I will send them up the Chain of Command to get an idea of what was going on.
O well.
Old Oct 10, 2021 | 08:29 PM
I still own both cars. I have owned the white 1988 IROCZ convertible for 28 years and the 1988 white V6 sport coupe I had thought for 10 years, but now that I have looked at the bill of sale it has been 15 years. I can't believe its been that long ago. They were originally sent to 2 different dealerships in my area about 30 miles apart according to the factory invoices and paper work I got with them. They were both one owner cars when I bought them. Yes, it is quite a coincidence!
Old Oct 10, 2021 | 10:10 PM
  #42
Well...
O well.
In the first part of the tread this is listed. The RPO sticker in the console lists the VIN# as 1G1FP87F0GN169617, but the VIN# on the car is 1G1FP87F2GN169618
I did a check digit calculator on both Vin# and they both checked out as correct. Here is the link I used to check them.
Old Oct 11, 2021 | 07:31 PM
  #43
vorteciroc's Avatar
Top Answer: 1
According my contacts (friends still with GM SPO... technically now called CCA) these two Cars did go down the Line one after the other.
Obviously both Cars were built as:
-Built in USA.
-General Motors product.
-Division of Chevrolet.
-F-Body.
-Camaro (Non-Berlinetta).
-Two Door Coupe.
-Manual Safety-Restraints.
-LB9 Fuel-Injected TPI 5.0L V8 (Automatic Transmission Only).
-The Fraud Detection Digit shows to be Authentic/ No Fraud.
-1986 Model Year.
-From Norwood Ohio Assembly Plant.
Old Oct 11, 2021 | 09:31 PM
  #44
I wonder where the export one that got its SPID into the wrong car actually went? That would have been one of a kind car the way it was built with all the weird combinations. They did things to build that car that you never see on a car that was built to stay in this country. It must have been a very late 1986 summer build to have two RPO that you couldn't get till 1987. I'll bet there are some very rare 3rd gens built for export that are one of a kind. They will eventually surface someday!
Old Oct 28, 2021 | 01:49 PM
  #45
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I suspect one was exported.
fastsspr
Mar 4, 2019 04:23 PM
Clint Partain
Sep 2, 2018 06:46 PM
96LT4c4
Aug 25, 2009 12:23 PM
bd_slim
Aug 12, 2007 08:48 PM
84L69TA
Aug 5, 2001 06:05 PM
