Requesting pics of hood to cowl weatherstrip
Old Oct 14, 2023 | 06:51 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Looking through my spare parts boxes today I found a new weatherstrip piece I had purchased back in 2008. Needless to say, it's been so long, I can't remember how the old one came off so that I could install this one in its place.
Anyone have slight distance and closeup photos I can use for reference?
Thanks in advance! (1987 Iroc)
Old Oct 15, 2023 | 02:59 PM
F-body-fan's Avatar
Re: Requesting pics of hood to cowl weatherstrip
Good Timing. I was in the shop removing the hood insulation, Took a break & I saw you post.
1989
Old Oct 19, 2023 | 06:38 PM
majobis's Avatar
Axle/Gears: G92
Thank you sir!
Old Oct 20, 2023 | 11:41 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The hood has small holes across it, about 1/8" diameter. And the molding has (should have) small plastic pins in it. Line-up the pins to the holes and push 'em in. But make sure the pins and the holes all match-up before pushing them in. If they aren't matching-up, then flip the molding end-to-end.
Old Nov 3, 2023 | 02:46 PM
majobis's Avatar
Axle/Gears: G92
I finally got around to installing today and thanks for the tip; there is a left and right although not marked.
For those of you who don't have one, it'll prevent a lot of debris from getting under the hood via the wipers area.
Old Nov 3, 2023 | 06:48 PM
F-body-fan's Avatar
New Hood insulation? Looks to be in great shape!
Old Nov 4, 2023 | 10:09 AM
majobis's Avatar
Axle/Gears: G92
Yes. My own personal NOS I created, as in buying it in 2010 and getting around to installing in 2023!
Old Dec 13, 2023 | 07:06 AM
F-body-fan's Avatar
I have the same, still in the Cardboard. I have never even opened it to see if its in there..... maybe 2005 ish I was cleaning & decreasing my 87 & managed to wreck the original.
So I removed it & ordered a new one. Still have not installed it.
BOTTLEDZ28
Jul 5, 2004 09:31 AM
kd5boc
May 19, 2004 06:37 PM
r90camarors
Dec 18, 2003 12:28 PM
Nasty_Bird_'90
Aug 5, 2002 11:22 AM
