1988 Trans Am RPO codes
Old 01-31-2024, 03:47 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Someone point me in the right direction if I'm missing it, but the most data I can find over my Dad's single owner Trans Am (27,800 mi) that is now mine.
For the longest time I knew the car was driven off the dealership lot when it was delivered, with Black Exterior, Black Rims.
I was always in doubt about the car coming from the factory with Black exterior paint 41U and Black Cross lace rims 19P, until I looked at the RPO's to Austin's 3rd gen size and see that sticker maintained the alignment.
I did see that in 1988 403 Trans Am's were produced with (Approx) the L98, interesting to see the motor choice so low.
The other options or not options to the car were;
Analog gauge set
No power Door locks
No power Windows
Power Antenna
Hard Top
WS4 &WS6 options
Australian 9 bolt
Aluminum drive shaft
I don't know what the seats are but they are non-powered and have the adjustable (fore and aft) head rest.
The photo of the cars is a few years old, I only say that because my Camaro is almost out from under the knife with updates for that are on the FM Thirdgen Firebird and Camaro page where I usually post a bit more.
But, I figured I would throw this out and see if anyone had better data to the combination since the VIN didn't come up in Compine or whatever that site is.
RPO Code+A1:B40 Description
AAA STANDARD EQUIPMENT
AK1 DELUXE BELT AND SHOULDER HARNESS
AM9 SEAT, REAR, SPLIT, BACK, FOLDING
AQ9 SEAT, FRONT BUCKET PASS, DRIVER RECLINE
A01 WINDOW, TINTED, ALL SHADED, W/S
A90 LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
BV3 ORNAMENTATION,INTERIOR,INSTRUMENT PANEL(BLACK)
BY4 ORNAMENTATION, INTERIOR, INSTRUMENTATION PANEL, NAME PLATE
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7L TPI
B20 ORNAMENTATION, INTERIOR, LUXURY TRIM GROUP
B34 OVERING, FRONT FLOOR MATS CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
B67 CONTAINER, RADIO CASSETTE TAPES B84 ORNAMENTATION, EXTERIOR MOLDING, BODY SIDE
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C49 DEFOGGER, REAR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
D3Y SPEEDOMETER DRIVEN GEAR
D34 MIRROR, VISOR VANITY
D35 MIRROR, OUTSIDE REAR VIEW
D81 SPOILER, REAR, AERO WING
D9B SENSOR, VEHICLE SPEED
E5Z SPEEDOMETER ADAPTER (DELETE)
E9Z KEY, SPEEDOMETER (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GW6 AXLE, REAR 3.27 RATIO
G80 AXLE, POSI-TRACTION, LIMITED SLIP
JG1 SHAFT, PROP, ALUMINUM
J65 BRAKE SYSTEM, POWER, FRONT & REAR DISK
KC4 COOLING SYSTEM, ENGINE OIL
K68 ALTERNATOR, 105 AMP
L98 ENGINE, GAS, 8 CYL, 5.7L, TPI (1987-1992 ONLY)
MD8 TRANSMISSION, AUTO 4 SPEED, 700R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER O
N33 STEERING COLUMN, TILT TYPE
N36 STEERING WHEEL, 4 SPOKES, SPORT
N64 WHEEL & TIRE, SPARE, SPACE SAVER, ALUMINUM
PB4 LOCK CONTROL, WHEEL
PW7 WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4 T
R9 LAMP, GROUP
T93 TAIL & STOP LAMP, SMOKED
T96 LAMP, FOG
UF6 LAMP, INTR, CONSOLE, COURTESY
UQ1 RADIO PROVISIONS, FOR STEREO
UT1 TONE GENERATOR, WARNING
UX1 RADIO, AM/FM STEREO CASSETTE EQUALIZER
U25 LAMP, INTR, RR COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U66 SPEAKER SYSTEM, 4 DUAL FRONT DASH MOUNTED, DUAL EXTENDED RANGE
U75 ANTENNA, POWER, RADIO
VAN ASSEMBLY PLANT, VAN NUYS, CA
VK3 LICENSE PLATE, FRONT MOUNTING PACKAGE
V73 ANTENNA, FIXED
WS4 MODEL CONVERSION, TRANS AM
WS6 PERFORMANCE PACKAGE, SPECIAL
WW4 APPEARANCE PACKAGE, AERO #4
W62 ORNAMENTATION, AERO PACKAGE
YS1 SEAT, REAR CUSTOM
YT1 BUILD UP DR & QTR
1SA PACKAGE, OPTION 02
19P 16 INCH BLACK CROSSLACE WHEELS W/LOCKING PACKAGE
19Q MOLDING COLOR, BLACK
41U PRIMARY COLOR, EXTERIOR, BLACK
6ZX SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
8NL SPRING, COMPUTER SELECTED, REAR, LEFTHAND
82D TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )
821 INTERIOR TRIM (DARK MEDIUM GRAY)
829 SEAT BELT COLOR, MED DK GRAY (91)
9NL COMPUTER SELECTED REAR RIGHTHAND SPRING
Old 01-31-2024, 04:41 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Re: 1988 Trans Am RPO codes
Here you go:
https://austinthirdgen.org/thirdgen-rpo-decoder/
StevenK (02-09-2024)
Old 01-31-2024, 04:48 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Originally Posted by pirateofms
Been there, the question is to the cars build with black exterior paint and black rims and the other little odd options to it is more the question. It's already been decoded.
Old 01-31-2024, 05:22 PM
JT
Community Administrator
JT's Avatar
Analog gauge set
No power Door locks
No power Windows
Power Antenna
Hard Top
WS4 &WS6 options
Australian 9 bolt
Pontiac records show 3049 1988 Trans Ams with the the black pw7 wheel. In contrast, I have a white 1988 Trans Am with white pw7 wheels. There was also a red pw7 wheel as an option on red Trans Ams.
Pontiac records also show 966 1988 Trans Ams with the the AQ9 seats, which are more commonly known as GTA seats since they were standard on the GTA but optional on the Trans Am.
All 1988 GTAs and Trans Ams with the 350 would be hardtop from the factory.
gixxer92 (01-31-2024)
Old 01-31-2024, 05:27 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Thanks JT!
Lots of nuances with the numbers. Where are your references coming from? I can't remember where I saw a number of 403 with L98, but it seems off a little if all TA/GTA came with the L98. lol
Old 01-31-2024, 05:36 PM
JT
JT's Avatar
My info comes from Pontiac's option analysis sheets. There is a book that also shares much of the same data.
It also shows 406 1988 Trans Ams with the 350.
I have records from Pontiac that contradicts each other so it's not always concrete but it's all we have.
Old 01-31-2024, 05:46 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Almost it's current state, btw. The heads are at the engine shop currently, compression was good.
Dad told me somewhere around the 18000 mi area it overheated, not sure how much, overtemp, but when I took the accessory brackets off the paint trapped behind the alternator bracket had completely dis-adheared itself from the head and fell to the ground in one piece.
If the heads are bad I'm probably going to set the original K member and trans to the side and put my fresh LY6 with a stage 2 TSP cam in and add a 4L80 to it.
Thinking this route currently because I have the money in a fresh motor and can come back and put all the emissions and original harness back in later.
I'm supposed to find out Friday what condition the heads are in to make the decision of keeping it 95% stock or having a second LS thirdgen. I'm hoping the heads aren't cracked to keep it nostalgic at this point...
T
P.S. the angle of the photo makes the car look like it's leaning back, it's not. the rear lift arms are on the LCA frame mount to counter the weight change.
Old 02-04-2024, 08:11 PM
shiftman's Avatar
Hi gixxer,
My book (shameless plug) can help you out with production totals. Page 76.
JT was correct: 406 L98 units for the 1988 Trans Am. To be clear, in 1988, all Trans Ams did NOT come with L98 engines. That model year, there were over 4,000 Trans Ams with the L03, and over 4,300 with the LB9. The 1988 GTA could come with the LB9 or L98 (3,439 / 7,779). Yours is kinda rare, no?
Good looking ride. Take care of it.
Best,
Robert
Old 02-06-2024, 04:09 PM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Austin page has so much bad information. It is close, but not exactly right. Also the RPOs they seem to have listed are lacking. For the Camaro RPOs it appears they just got the data from the Camaro White Book. Which is fine, but not a complete list.
gixxer92 (02-06-2024)
Old 02-06-2024, 05:46 PM
shiftman's Avatar
Hi John,
Oh, for sure that link used White Book text. Errors and all. Scanned and pasted, which is.....something I won't stick my nose into.
You're right, there are a lot more known RPOs for every year. The quantities may not be known, but the RPOs and definitions are known.
Hope you're good.
okfoz (02-07-2024)
Old 02-07-2024, 08:43 AM
okfoz's Avatar
8794 Trans Ams in 1988
8,157 - AAA STANDARD EQUIPMENT
6,512 - AK1 DELUXE BELT AND SHOULDER HARNESS
5,400 - AM9 SEAT, REAR, SPLIT, BACK, FOLDING
966 - AQ9 SEAT, FRONT BUCKET PASS, DRIVER RECLINE
8,737 - A01 WINDOW, TINTED, ALL SHADED, W/S
8,584 - A90 LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
8,794 - BV3 ORNAMENTATION,INTERIOR,INSTRUMENT PANEL(BLACK)
4,811 - BY4 ORNAMENTATION, INTERIOR, INSTRUMENTATION PANEL, NAME PLATE
406 - B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7L TPI
5,400 - B20 ORNAMENTATION, INTERIOR, LUXURY TRIM GROUP
6,746 - B34 OVERING, FRONT FLOOR MATS CARPETED INSERT
6,746 - B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
7,364- B67 CONTAINER, RADIO CASSETTE TAPES B84 ORNAMENTATION, EXTERIOR MOLDING, BODY SIDE
8,607 - CD4 WIPER SYSTEM WINDSHIELD, PULSE
6,443 - C49 DEFOGGER, REAR WINDOW, ELECTRIC
7,049 - C60 HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
406 - D3Y SPEEDOMETER DRIVEN GEAR
8,577 - D34 MIRROR, VISOR VANITY
2,649 - D35 MIRROR, OUTSIDE REAR VIEW
8,794 - D81 SPOILER, REAR, AERO WING
406 - D9B SENSOR, VEHICLE SPEED
8,794 - E5Z SPEEDOMETER ADAPTER (DELETE)
8,794 - E9Z KEY, SPEEDOMETER (DELETE)
4,811 - FE2 SUSPENSION SYSTEM, RIDE HANDLING
406 - GW6 AXLE, REAR 3.27 RATIO
5,608 - G80 AXLE, POSI-TRACTION, LIMITED SLIP
3,158 - JG1 SHAFT, PROP, ALUMINUM
437 - J65 BRAKE SYSTEM, POWER, FRONT & REAR DISK
437 - KC4 COOLING SYSTEM, ENGINE OIL
4,758 - K68 ALTERNATOR, 105 AMP
406 - L98 ENGINE, GAS, 8 CYL, 5.7L, TPI (1987-1992 ONLY)
7,688 - MD8 TRANSMISSION, AUTO 4 SPEED, 700R4
7,688 - MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
8,167 - NA5 EMISSION SYSTEM, FEDERAL, TIER O
8,607 - N33 STEERING COLUMN, TILT TYPE
2,489 - N36 STEERING WHEEL, 4 SPOKES, SPORT
3,158 - N64 WHEEL & TIRE, SPARE, SPACE SAVER, ALUMINUM
8,794 - PB4 LOCK CONTROL, WHEEL
4,411 - PW7 WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
3,981 - QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4 T
8,592 - TR9 LAMP, GROUP
8,794 - T93 TAIL & STOP LAMP, SMOKED
8,794 - T96 LAMP, FOG
8,592 - UF6 LAMP, INTR, CONSOLE, COURTESY
8,767 - UQ1 RADIO PROVISIONS, FOR STEREO
8,592 - UT1 TONE GENERATOR, WARNING
3,612 - UX1 RADIO, AM/FM STEREO CASSETTE EQUALIZER
8,592 - U25 LAMP, INTR, RR COMPT, COURTESY
8,592 - U29 LAMP, INTR I/P, COURTESY
7,118 - U66 SPEAKER SYSTEM, 4 DUAL FRONT DASH MOUNTED, DUAL EXTENDED RANGE
4,335 - U75 ANTENNA, POWER, RADIO
8,794 - VAN ASSEMBLY PLANT, VAN NUYS, CA
6,763 - VK3 LICENSE PLATE, FRONT MOUNTING PACKAGE
8,351 - V73 ANTENNA, FIXED
8,794 - WS4 MODEL CONVERSION, TRANS AM
4,811 - WS6 PERFORMANCE PACKAGE, SPECIAL
2,046 - WW4 APPEARANCE PACKAGE, AERO #4 BLACK
8,794 - W62 ORNAMENTATION, AERO PACKAGE
5,400 - YS1 SEAT, REAR CUSTOM
5,400 - YT1 BUILD UP DR & QTR
2,444 - 1SA PACKAGE, OPTION 02
3,049 - 19P 16 INCH BLACK CROSSLACE WHEELS W/LOCKING PACKAGE
1,939 - 19Q MOLDING COLOR, BLACK
2,046 - 41U PRIMARY COLOR, EXTERIOR, BLACK
661 - 82D TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )
6,151 - 82I INTERIOR TRIM (DARK MEDIUM GRAY)
5,795 - 829 SEAT BELT COLOR, MED DK GRAY (91)
The following 2 users liked this post by okfoz:
DynoDave43 (02-07-2024), gixxer92 (02-08-2024)
Old 02-07-2024, 09:11 AM
okfoz's Avatar
Where did you get this information:
R9 LAMP, GROUP
T96 LAMP, FOG
V73 ANTENNA, FIXED
Old 02-08-2024, 10:51 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
It was pulled from Austin's thirdgen site
Old 02-09-2024, 07:31 AM
okfoz's Avatar
Ok, so you basically just copied and pasted each RPO code. I thought that something did it for you.
John
Old 02-09-2024, 08:42 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
You are welcome to send me fixes and I can adjust the site. I got this information over 20 years ago from random places around the internet and put it all in one place. Feedback is welcome, as is volunteers to adjust and fix any incorrect information.
gixxer92 (02-11-2024)
shiftman
09-21-2018 04:41 PM
J0hn_J0hn08
03-16-2015 07:59 PM
falcone1969
03-22-2013 10:33 AM
lsd88ta
09-13-2011 04:09 PM
russ84HO
05-30-2001 02:30 PM
Quick Reply: 1988 Trans Am RPO codes
