Iroc Engine Sizes
Old Feb 14, 2002 | 09:27 AM
un4givin89's Avatar
Iroc Engine Sizes
Every IROC I have looked at has an crappy lil 305TPI in it. WHat years am I most likely to find a 350 in an IROC-Z? If the rear bumper don't say 5.7 tuned port anymore I don't even bother.
Old Feb 14, 2002 | 10:01 AM
Drew's Avatar
87-90
Old Feb 14, 2002 | 01:33 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Re: Iroc Engine Sizes
There's no arguing with Drew, just confirming.
....crappy lil 305TPI in it.... If the rear bumper don't say 5.7 tuned port anymore I don't even bother.
Hmmmm. I did "bother". My sig tells all.
Old Feb 14, 2002 | 01:50 PM
un4givin89's Avatar
that should help narrow down my search, thanks guys.
Old Feb 14, 2002 | 02:15 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
i wouldn't go by the rear bumper cover as your end all...never know what's happened to a car over the years. Look for the 8 in the 8th digit of the vin number, that's your best indication.
Also, a 305tpi/5 speed car is pretty quick. I wouldn't rule that out til you drive one. Assuming you drive stick or care to learn.
Old Feb 14, 2002 | 02:40 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Wraith has a good point...a lot of road tests I have seen show that the 305 TPI 5 speeds, with proper gearing, were only a tick or two behind a 350 TPI in both 0-60s and 1/4 miles. Plus, you get the fun factor of buying a stick too!!
I used to be of the same opinion about 305 TPIs until I really looked at the raw #s...and there's a lot more 305s readily available too. Don't count them out.
Old Feb 14, 2002 | 05:13 PM
ToFastTooCare's Avatar
Speeking of 305/5-speed cars, does anyone have an accurate 0-60 time for them in their stock forms.
Old Feb 15, 2002 | 09:49 AM
Drew's Avatar
That's a pretty wide open question... considering an LG4 or L03 with a 5 spd would pull anywhere from mid-high 16's and a 90-92 LB9 5 spd might pull mid 14's. Then you get into the peanut vs L98 cam argument and the variations of different years, etc.
From my experiance the 89 Formula LB9 5spd I test drove was just a hair faster than my LG4 auto, and quite a bit slower than my 87 Iroc 5.7L auto which is a hell of a lot slower than my 91 Formula 5.7L auto... Between that experiance and the lack of 5spd V8 cars around here, I don't put much faith in the LB9 T5 cars.
Old Feb 15, 2002 | 10:23 AM
un4givin89's Avatar
I found me an IROC with 350 and made offer, trying to seal the deal, I'm very excited!!!
Dude has doen some work to it already
Old Feb 15, 2002 | 10:25 AM
un4givin89's Avatar
Did 305 TBI ever come in an IROC and second was the LO3 ever found in an IROC-Z?
Old Feb 15, 2002 | 11:32 AM
Drew's Avatar
Iroc and Iroc-Z are the same thing.
yes the L03 was available in all platforms except the GTA in some years.
Old Feb 15, 2002 | 02:28 PM
SlowCamaro88SC's Avatar
Re: Re: Iroc Engine Sizes
I gotta agree w/ Willie, the one time I talk to him he told me all about it. awesome car.
BTW Wille, how are those DRL's coming along? did you forget about me?
Old Feb 15, 2002 | 04:25 PM
iroc22's Avatar
For the 305TPI speed density a reasonable 0-60 for a stock one would be 6.5 or so maybe a little less. As for did the L03 come in an IROC-Z? Check the sig.
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
knight72
Aug 10, 2015 09:32 PM
